After every 5 min one erroer has come on the display as -- oracle RDBMS kernel executable encountered a problem and need to close. plz tell me the solution
    Scholar:
  • 142 Answers
If you go to ADD and Remove programs in the Control Panel please check to see if the program is installed there if it is simply Uninstall.
If it is not then you will need to take the PC to get serviced and you will need to tell them of the error so they can clean it up.
Posted on Sep 21, 2009
What is SQL?
It is a special purpose programing language. Computer language you will never use, unless you are into servers or programing type software
Jan 27, 2015 | Oracle 10g Database Standard (ODBSEONUPP0)
My PowerPoint giving this error "PowerPoint has encountered a problem and needs to close" then what should i do?
After it closes, try running PowerPoint again. Open the PowerPoint Options >Resources>Diagnostics. Execute the diagnostics and see what it tells you.
Jan 27, 2014 | Microsoft PowerPoint for PC
WHAT IS REENTRANT KERNEL?
A reentrant kernel enables processes to give away the CPU while in kernel mode, not hindering other processes from entering kernel modes.
If the kernel is not reentrant, a process can only be suspended while it is in user mode(to be more precise, it could also suspend the process in kernel mode, but would block kernel mode execution on all other processes).
The reason for this is that all kernel threads share the same memory and corruption would occur if execution would jump between them arbitrarily.
That is, if the kernel is reentrant, several processes may be executed in the kernel mode at the same time when the process is suspended.
A typical use case is I/O wait.
The process wants to read a file.
>>When the kernel is not reentrant :
It calls a kernel function for this to stop the inside the kernel function. Disk controller is asked for the data. Getting the data will take some time and the function will block during that time.
With reentrant kernel,the scheduler will assign the CPU another process until the interrupt from the disk controller indicates that the data is available and our thread can be resumed.
Hence with this concept, throughput of the system increases rapidly.
A kernel that is not entrant needs to use a lock to makee sure that no two processes are executing in kernel mode at the same time.
Oct 14, 2010 | Computers & Internet
How do I boot my machine. The erroer mesage, missing DLLs kernel keeps coming up
it sounds like your OS systems file is currupted.. u can either take it to a computer repair shop and thay can restore the file for u.. or u can just reinstall the OS ... thats what i ussually do...
Sep 23, 2010 | Computers & Internet
I executed simple C++ program but when i executed graphics program like to print circle,then the window closed and displayed a following message. 16 bit MS-DOS Subsystem C:TC BINTC.EXE The NTVDM CPU has...
If your operating system is win 7 or vista,
1,Locate c++ program file right click and goto properties
2,Untick or unselect RUN IN FULLSCREEN option.
Then your problem will be solved.
Jul 27, 2010 | ASUS M2N-MX Motherboard
Problem installing the ORACLE on ACER Altos G510
may be u require a different version?so download it
Mar 17, 2010 | Acer Altos G510 Server
Showing boot erroer some times ,some it starts shows no data but i stoers 755mb data in that my i pod series is SONY NWD-B103F so plz check and help plz its so urgent plz send mail for same
if you have the initial executing files that were on your mp3 when you bye,
Format your Mp3 on PC by FAT32 format and copy those on your Mp3 player folder
Sep 13, 2009 | Sony Walkman Bean NW-E307 MP3 Player
Vb 6.0 to oracle connectivity problem
Your SQL query does not look valid. Test the query in SQL Query analyzer, and then once it is working, copy it into your VB source. You will of course then need to make the query a string that VB will accept.
Mar 23, 2009 | Microsoft Computers & Internet
Oracle Error
if it occurs after imported, it's because ctx'preferences was not imported. Try to get preferences from source (by reverse engeneriing or see with ctx_report.create_index_script package).
You will get severals scripts to execute on target db
Sep 08, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
How to connevt visual basic with oracle(sql)
You need to install oracle client on client machine, and than you can use datasource (ODBC) to connect from vb to oracle.
Jan 23, 2008 | Computers & Internet
Computers & Internet Logo
168 people viewed this question
David Payne
David Payne
