Question about HP LaserJet 5000 Printer
HP laserJet 5000 Printer continually printing same page
I send a job to the printer, and it just prints the first page non-stop. I have to cancel the job to clear it. Then I send the job again and it sticks on the first page which is repeatdly printed out until I cancel it again.
Thank you for helping me
  • 3 Answers
Laserjet 5000 printer A4 size printing right side line not printing .why?
Posted on Jan 15, 2009
  • bins_koshy Jan 15, 2009
    pls check the printer display panel in printing menu option number of copies how much you selected .pls change to 1 number
Printer is just printing rubbish and will not stop. Can I do a reset to fix this? If so, how?
Press cancel print job.
unplug from the wall, count to 10 and reconnect. It is not the printer that is faulty it is the print job you are sending. Disconnecting will get the job out its memory.
Feb 12, 2016 | HP LaserJet 1320tn Printer
Tip
HP LaserJet LJ 4350 locks up when duplexing
Symptom: Your LaserJet 4350 prints just fine until you try to print a double-sided page. Then you see the page start to exit, pull back in, then stop. The Data light continues flashing green, and the display reads, "Processing..." There is no error indication, but the machine won't print the second side and continues to hold the half-printed paper in the duplexer. If you open the top cover and close it again, the printer will eject the page, then try to print the whole thing again, unless you're quick enough to cancel the job first.
Cause: The printer is expecting a different sized paper than what it's running. Often it's not the menu settings, but a little lever in the paper tray itself. Pull out the paper tray you're trying to print from and look for a little blue lever on top of its right-hand side. The lever is labeled "Standard/Custom." Flip it to Standard (parallel to the tray side) and your problem should go away.
on Mar 17, 2010 | HP LaserJet 4350dtn Printer
How to stop printing
While your question is not quite clear, I will provide a couple of suggestions. Usually when you press the cancel button, it pauses the printer and then you must use the arrow keys to select cancel job and then press the checkmark. Also check any computers to make sure that they do not have a job in their print queue. If the printer does not send back a job complete command, sometimes the computer will keep resending the job. Failing all else, restart your computer and your printer. Are the pages that are printing gibberish or is it the correct print job? If gibberish, you might have a corrupted print driver or the file you are printing might be corrupted.
Jul 15, 2014 | HP LaserJet P4014n Printer
I can't stop a printing job
Hi dcshout,
Open the printer folder, and then double click on the printer to open the printer queue. Once the queue is opened you can then click on printer, and then cancel all jobs.
Apr 12, 2012 | HP LaserJet 1600 Printer
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Jan 14, 2011 | HP LaserJet 1150 Printer
I am having HP 2300 LaserJet printer. From Yesterday it started printing continuously. When you give one test page from XP It will print that Test continuously without stopping. I need to cancel the Job...
Hello .
First select the configure device menu by up & down arrow keys in display select them by pressing green button find no of copies in sub menu change this value to 1 & set them by pressing the green button.Your value set to no of copies to 1 & your problem will be 100% resolved.
Sep 19, 2010 | HP LaserJet 2300d Printer
Printer prints blank pages.
 it a transfer belt issue....there is a test you can perform to confirm. When the first page comes out of the printer blank, open and close the back cover. If the next page comes out with print on it, then the transfer belt is the issue. One thing you can try is take the old belt down to a service station with a good air compressor and then use the air compressor to blow the heck out of the belt until no more toner comes out.
Mar 04, 2009 | HP Color LaserJet 4550n Printer
Continues printing pages
sound like u have setting problem with either the program your printing from or the driver. It could be set to print 2 copies of print job. If your using windows XP there a printer driver in there for the printer. If your using an older version of windows you can used HP laserjet II driver. HP always made there printers to be able to print with LJ II driver.
Sep 25, 2007 | HP LaserJet 6L Printer
HP LaserJet 5000 Printer Logo
265 people viewed this question
Ben Johnson
