Question about Viking VCSB483 Side by Side Refrigerator
Freezer temperature is not low enough (soft icecream)
After about 6 months of fair performance freezer temperature got warmer to the point that icecream is in semi liquid condition, water ice cubes freez up but I think it takes a long time (overnight- is that to long?)
  • Anonymous Mar 05, 2008
    having the same problem,but i don't have a freon leak.i found the condensor clogged with dust.hope that fixed my problem.
Check condensor it might be clogged with dust
Posted on Mar 05, 2008
Did you have a refrigerant leak? Where ?
Posted on Sep 27, 2007
Upright Freezer not cold enough
Honestly it sounds as if you have a sealed system issue, most likely low on freon.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 13, 2012 | Freezers
Hi I am from Greece. I have a problem with my freezer. Every summer the alarm sounds of the freezer and the freezer temperature display flashes. At the temperature display a bar is lit up and the...
You need to have the freon checked. It may be enough for colder months but when warmer months come it is just not enough to keep it cool enough. Goodluck
Oct 21, 2017 | Miele KF7654 SNEed
The frezer temperature is not getting set low enough. Foods amd icecreams reamin soft
ck the back of freezer for frost build up and if so the defrost system has failed . look for burned out heater or bad terminator .. these are most common .. mm
Aug 18, 2010 | Amana Refrigerators
Freezer is not cold enough
Here are normal temperatures - Freezer should not be warmer than 10F. Normally it should be 0F, however optimal temps are -10F and for hard icecream - I recommend -10F or colder since it gives a better recovery after a power failure.
Refrigerator temps no warmer than 4F - optimal should be 34F.
After ruling out door gasket seals and dirty condensers, the most common cause is a bad defrost system. If you remove your freezer panel you can look for over frosting on the evap coils - (after shutting down unit of course) try manually defrosting with a blow dryer until everything is melted - place back panel and run for a couple of hours. If cooling is back to nromal, your issue is defrost timer components / control board.
Make sure the evap fan is working properly as well. as your condenser fan (if applicable).
Sep 23, 2009 | Kenmore Refrigerators
Freezer does not freeze fast enough, icecream gets soft
Faulty Cold control (Temperature Control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
If the control is not closing, the compressor and all fans will cease to operate. Check the control for continuity.
This is usually not a do it your selfer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 25, 2009 | GE GTS22KBP Top Freezer Refrigerator
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer cold but not freezing
Check the settings for the freezer control. Refrigerator temperature control normally controls the run time of the compressor. if the freezer control is set to low the refrigerator temperature will be fine and the freezer will be warmer. Setting the freezer control to a colder setting will hold back more cold air in the freezer and reduce the air volume supplied to the refrigerator. Check and make sure the condenser coil is clean.
Jun 08, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Model EHT-201ZH
Check to see if the condenser is clean. Also that the compresser is getting enough clean air.
Apr 24, 2008 | Whirlpool ART535 Top Freezer Refrigerator
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Viking VCSB483 Side by Side Refrigerator Logo
354 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Jay Finke
Jay Finke
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
