Question about Oracle 10g Database Standard (ODBSEONUPP0)
Loading images into Oracle database
How can i load images into oracle database? I want my procedure to load images into the database from a predefined folder.
  • mailtovamsid Jan 14, 2009
    Thanks very much
    But i want ot default a folder on my local machine,such that when ever my package runs it should get images from that folder path.
    vamsi
    It is not VB or Java. But i want to call this in Oracle Forms. So my entire code should be in Oracle. I want to set the path in oracle pl sql.
  • 258 Answers
You need to use a blob or cblob field to store a jpg file in Oracle
see this site http://asktom.oracle.com
Posted on Jan 14, 2009
I installed oracle 10g express edition.now I dono how to remove it. please let me kno how to uninstall it.I even stopped the oracle services but i dino abythin further.
Follow these steps:
  1. Open the Windows Services utility: From the Start menu, select All Programs, then Administrative Tools, and then Services.
  2. If any of the following Oracle services exist and have the status Started, then select each of the services, and click Stop:
    • OracleXE
    • OracleXETNSListener
    • OracleJobSchedulerXE
    • OracleXEClrAgent
    • OracleMTSRecoveryService
  3. Exit Services.
See also the Microsoft online help for more information on stopping services.
7.2.2 Step 2: Remove the Oracle Database XE Registry Editor Settings Follow these steps:
  1. Log on to Windows with Windows administrative privileges.
  2. Ensure that you followed the instructions under "Step 1: Stop the Oracle Database XE Services" to stop the Oracle Database XE services.
  3. Start the Registry Editor at a command prompt:
    SYSTEM_DRIVE:\> regedit
  4. Go to HKEY_CLASSES_ROOT.
  5. Delete the following keys:
    • NEED TO CONFIRM THE XE-SPECIFIC ONES.
  6. Go to HKEY_CURRENT_USER\Software.
  7. Under Microsoft\Windows\CurrentVersion\Explorer\MenuOrder\Start Menu\Programs, delete the Oracle Database 10g Express Edition key.
  8. Go to HKEY_LOCAL_MACHINE\SOFTWARE and search for the ORACLE group key.
  9. Expand the ORACLE group key and then delete the KEY_XE and OracleMTSRecoveryService keys.
  10. Go to HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBCINST.INI.
  11. Expand the ODBCINST.INI key and remove the Oracle in XE key.
  12. Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services.
  13. Delete the following keys:
    • OracleServiceXE
    • OracleXEClrAgent
  14. Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Eventlog\Application.
  15. Delete the Oracle.xe key.
  16. Exit the Registry Editor.
  17. Restart your computer.
7.2.3 Step 3: Update the System Variable Path Follow these steps:
  1. Open System from the Control Panel.
  2. In the System Properties dialog box, click the Advanced tab, then click the Environment Variables button.
  3. Select the system variable Path and edit the Path variable to remove the Oracle Database XE entry. For example:
    C:\oraclexe\app\oracle\product\10.2.0\server\bin;
  4. Save your changes and then exit the Control Panel.
7.2.4 Step 4: Remove Oracle Database XE from the Start Menu and Desktop Follow these steps:
  1. Select Start, then All Programs, and then Oracle Database 10g Express Edtion.
  2. Right-click Oracle Database 10g Express Edtion and from the menu, select Delete.
  3. On the desktop, right-click the Get Started with Oracle Database 10g Express Edition icon and from the menu, select Cut.
7.2.5 Step 5: Remove the Oracle Database XE Directories Follow these steps:
  1. Ensure that you have followed the instructions under "Step 1: Stop the Oracle Database XE Services" to stop all Oracle Database XE services.
  2. From the Windows Explorer, navigate to the directory where you installed Oracle Database XE, for example, c:\oraclexe.
  3. Right-click the Oracle Database XE installation directory and from the menu, select Delete.
7.2.6 Step 6: Install and Run the Windows Installer CleanUp Utility Run the Windows Installer CleanUp utility to remove the Windows Installation configuration information for the Oracle Database XE installation. You can download it from Microsoft at:
http://support.microsoft.com/default.aspx?scid=kb;en-us;290301
he deinstallation completes, click Finish.
Sep 14, 2010 | Oracle Database 10g
Hi, New to Oracle, what resource would you reco...
http://psoug.org/
PSOUG.org is an Oracle community resource dedicated to supporting users and developers of the Oracle database. lots of great code samples.
http://www.iselfschooling.com/
offers free training. It's a great site for new users / dbas
May 20, 2010 | Oracle Database 10g
I want to install oracle 8i in windows 7, how i do this?
sir, i have a window7 in all in one hp but there is a software called mstar which run on oracle 8i when i install the oracle 8i there is a problem and show dll file corrupted. Pls tell me the solution because my client want it very urgently and i am not able to install and run the programm.
Feb 26, 2010 | Veritas Cluster Server for Solaris Oracle...
How to retrieve database of ORACLE using c sharp code
You will need either Orcale data provider or ODBC driver. Once either one of the above is setup, you can access your Oracle database using ADO calls. Please refer to this site for more info: http://www.csharp-station.com/Tutorials/AdoDotNet/Lesson01.aspx
Sep 21, 2009 | Oracle Database 10g
Uninstalling oracle 10g from vista
To uninstall oracle from your PC,
first you should run the oracle setup from the installation disk.
The installation setup will automatically detect the oracle products installed in your PC.
After checking the list of installed products, mark the programs you want to uninstall & then click on uninstall.
Apr 11, 2009 | Oracle Database 10g
Application that support for oracle 10g
How can load and save image into oracle database
Mar 23, 2009 | Oracle Database 10g
Uninstall oracle 10g database
hve uninstalled oracle 10g from xp!! but still one program is left over say oracleserviceXE, that i could not find!! how to remove this, to install the s/w again!! plz kindly help me regarding this
Jun 01, 2008 | Computers & Internet
How to develop a tool for conversion the database from sybase to sqlserver
ahh..sudeep...it is a truly glorious day for this work. The detailed solution is to call Larry Ellison, at Oracle, and enquire if you can have his code.
Apr 23, 2008 | Computers & Internet
Oracle 10g Database Standard (ODBSEONUPP0) Logo
1,146 people viewed this question
Top Oracle Computers & Internet Experts
CNewton2
CNewton2
Level 1 Expert
cwradio73
Bonded Repair
Are you an Oracle Computer and Internet Expert? Answer questions, earn points and help others
