Question about Microsoft Xbox 360 Console
XBOX360 20g Hard Drive not working?
OK, so i start up my XBOX360 and my profile is not there.
So i got to my system settings, Memory, and my 20g hard drive isn't showing up, its plugged in and everything.
I've tried taking it out and playing the 360 without it. it works fine. Then when i plug my Hard drive back in it still doesn't show up!?
Does anyone know what the problem is?
Or a solution to solve it or fix it?
  • loststallion Jan 14, 2009
    I have the same problem. My console wont read my hard drive. I bought a new hard drive but I can recover my gamertag from that hard drive(with all my achievements) because it has been so long I cant remember my email & password for my gamertag!!
  • 79 Answers
That because the hard drive or unpluged console.
Posted on Jan 14, 2009
How do i know my hard drive is working properly?
If you are using an external hard drive you should go into settings then memory to format it because it is the safest way of storing data on your external hard drive and if the games or apps you have on it load you are fine.
If you are using the hard drive built into the xbox 360 it should be the same kind of thing. Games load, profiles load all the kind of stuff. but you don't need to format the internal obviously.
One thing you could check would be to check the dates of saves put on the hard drive or updates. To do this just go into settings then memory and go into your hard drive and open any game in hard drive and check the dates and see if they make sense
Apr 11, 2014 | Microsoft Xbox 360 Console
Tip
Performance tip: Do you have more that 1 hard drive in your Computer?
If you have 2 or more hard drives in your computer you can increase performance by moving your swap file (an old operating system trick to artificially create more memory space used by Windows, also called virtual memory or page file).
In XP(Other Windows OS's are similar):
Start Button -> Control Panel -> double click System icon.
-In the System Properties Box select Advanced.
-In the Advanced tab select settings located under Performance.
-In the new box select the Advanced tab.
-In the Advanced section select change located under Virtual Memory.
-Under Drives select the drive that has have your Operating System in and choose No paging file, click on set.
-Next select any other drive and select System Managed size, click on set. Click OK,OK,OK OK to restart.
Usually the bigger the drive the faster. The faster the better.
Windows can now access the swap file on 1 drive as it accesses data on the other instead of waiting for data from 1 drive.
This tip applies if you have 2 physical hard disk drives, not 2 drives in 1 disk.
If you are a gamer get another disk and do this trick.
on Jan 08, 2010 | Computers & Internet
There is something wrong with my microsft account its not letting me log in and the code is 8015d003
You see the following error message when you try to sign in to Xbox Live:
Sorry, something's wrong with your Microsoft account. Go to https://account.live.com for help.
Status code 8015D003
This may mean that there's a problem with your Xbox profile.
Solutions
To resolve this issue, try the following solutions.
Solution 1: Verify your Microsoft account security information
  1. Go to Microsoft account. If you forgot your password or it doesn't work, reset your password.)
  2. Click Edit security info.
  3. Verify your security information. For example, verify the Phone number, Alternate email address, and Security question information.
  4. Sign out of your Microsoft account, and then sign in again.
  5. Try to sign in to Xbox Live again.
Solution 2: Clear the system cache
  1. Press the Guide button on your controller.
  2. Go to settings and select System Settings.
  3. Select Storage or Memory.
  4. Highlight any storage device, and then press Y on your controller. (It doesn't matter which storage device you select; the cache will be cleared for all storage devices.)
  5. Select Clear System Cache.
    Note Repeat this step three times.
  6. When you are prompted to confirm storage device maintenance, select Yes.
  7. Repeat steps 4-6 three times to fully clear the cache.
Solution 3: Move and then redownload your Xbox Live profile
Note If you want to use a USB flash drive or a USB hard drive to complete these steps, you must format the USB flash drive or USB hard drive for Xbox storage. (See USB flash drive support for Xbox 360.)
  1. Move your profile to a USB flash drive or USB hard drive. To do this, follow these steps:
    1. Plug the USB drive into your console.
    2. From the Dashboard, go to settings and select Storage.
    3. Select All Devices.
    4. Select Profiles, and then select your gamer profile.
    5. Select Move.
    6. Select the Memory Unit that you want to move your profile to.
      Note A Memory Unit can be a USB flash drive, a USB hard drive, or the Xbox 360 Hard Drive. Be sure that you move the profile to a USB flash drive or a USB hard drive.
    7. Remove the Memory Unit from your console.
  2. Redownload your profile. For details, see Download, move, or delete your Xbox Live profile.
Sep 27, 2013 | Thorogood Boots 534-6333 Womens Code 3...
My ps3 is saying the hard discs file system is corrupted and will be restored i press x for ok and it says its restoring it restores turns off then comes on and says the same thing can u please help me or...
if it cant restore the drive then you will have to format the hard drive.. you will need the console serial number as it will ask you to enter it to format. You can find the serial number in system settings and to format it go to memory in system settings. Be warned you will lose everything on the hard drive by doping this. Any downloadable content will have to be redownloaded and your profile can be retrieved from xbox live
Apr 14, 2011 | Sony Playstation 3 (PS3) Console
There isn't a paper jam there is ink in the cartridges, i have selected the printer. when it prints the paper comes out blank
Make sure that the computer has available hard drive space
Printing requires the computer to have a certain amount of available hard drive space to process print jobs and to send them to the printer. Step one: Check the virtual memory settings Virtual memory is the temporary disk space on the hard drive that processes print jobs. It usually requires at least 200 MB of disk space but might require more or less depending on the printer. Insufficient virtual memory might cause the issue. Follow these steps to check and modify the amount of the virtual memory available.
Click Start , right-click My Computer , and then click Properties . Click the Advanced tab. In the Performance section, click Settings . Click the Advanced tab. In the Virtual memory section, click Change . For correct configuration, the Initial size and Maximum size settings must be less than the Space available on the hard drive. If the Space available on the hard drive is less than 200 MB , skip to the next step. Follow the instructions to clear space on the hard drive, and then start these steps over. The Initial size setting is the amount of space reserved for virtual memory on the hard drive. The Initial size setting should be about 200 MB, and greater than or equal to the recommended paging file size shown in the lower section of the dialog box. The Maximum size setting can be any number greater than the Initial size setting, but it should be at least twice the Initial size setting. Change the settings as necessary to conform to the information in this step. Click Set , and then click OK . Try printing again. If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step
Step two: Run Disk Cleanup to remove temporary files Follow these steps to run Disk Cleanup. Click Start , click Programs , click Accessories , click System Tools , and then click Disk Cleanup . Disk Cleanup prompts you to select a drive to clean. Select the hard drive, and then click OK . Disk Cleanup analyzes the hard drive and presents a report. Select the following items from the report: Temporary Internet Files Downloaded Program Files Recycle Bin Temporary Files Click OK . If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step. Step three: Remove unnecessary software programs Follow these steps to remove unnecessary software programs. Click Start , click Settings , click Control Panel , and then click Add/Remove Programs . Select a software program to remove, and then click Add/Remove . Repeat these steps for all software programs you want to remove. If you remove large software programs, run Scan Disk and Defrag on the hard disk drive. Look for these options in the System Tools section of Accessories
Mar 03, 2011 | HP PhotoSmart C4280 Laser Printer
I've had my console for about a year now, and a couple weeks after i bought Halo Reach, as i was playing online, it said "Could not write, possible problem is that you have removed the hard drive or memory...
the problem may come from the hard drive which means that it may have a virus like a computer or that the hardrive may have a malfuntion and cant be able to read to the xbox 360 so it is considered to buy a new hardrive and recover your profile/ enter xbox.com to get all the downloads that was on the last hard drive
Sep 30, 2010 | Microsoft Xbox 360 Hard Drive (120GB)
Putting data from an offline xbox profile to an xbox live profile
i am afraid you cant merge the two but if you have a hard drive and a memory unit you can put the memory on the unit then transfer it to the profile you want on the hard drive
Jun 24, 2009 | Microsoft Xbox Live 12 Month Gold...
Profile problem with changed hard drive.
Hmm..
The hard drive probably isn't configured with the system. Go to System Settings > Memory Settings and you should see the option
Apr 14, 2009 | Microsoft Xbox 360 Arcade
I can not sign in or made profile
Hi my name is Juan not all 360 have a hard drive on it look on the model # and see which one you got the core model has no hard drive and this is probably why is asking you for a memory card or usb drive so the best solution is to go to settings and see if you have a hard drive and if you do you can probably formatted and see if this way the system will detected thanks and good luck
Mar 17, 2009 | Microsoft Xbox 360 Console
Virtual memory
Your hard drive is getting to full for it to be used as virtual memory
When normal memory gets used up windows uses the hard drive as memory ans if insufficient room on hard drive is not available you get this message.
Solution.
1) delete programs from hard drive to create more space
2) Install new hard drive and transfer programs to it. creating more room on C drive
3) If hard drive is already partitioned and 2nd partition has a lot of free space transfer Virtual over to it.
Go to Start / Control panel Open The System folder go to "Advanced" "performance settings"
Then to "Advanced " Click on change and set Virtual memory to new disk.
Set maximum and minimum the same at 3 times the amount of normal memory you ave
Jan 05, 2009 | Computers & Internet
Microsoft Xbox 360 Console Logo
813 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
