Question about Canon PIXMA MP210 Photo All-In-One Printer
Error code e27
Please help  me to reset west ink
While pressing reset, press and hold power.
Release reset.
Press reset 2 times.
Release power.
Press reset 4 times
Press power 2 times for shutting down MP210
Power up MP and test...
If E13, E3, E16, E6 ocured, press and hold reset for 5-10 sec
Enjoy (Flores - Romania)
Posted on Mar 07, 2009
Hi, my printer mp145 show error E15 after I reset the error E27. I hope you can help me. Thanks.
This maybe will help
http://electronics-repairguide.blogspot.com/2011/07/error-e27-on-canon-mp198mp258-ink.html
Mar 04, 2014 | Canon Office Equipment & Supplies
My canon MP160 error 27. I've tried the trick in service mode.. But still can't reset it.. please help me..
E27 is the WASTE INK ABSORBER FULL error message. Try send it to service centre to do the WASTE INK ABSORBER replacementjob & waste ink counter reset job.
May 19, 2010 | Canon PIXMA MP160 All-In-One InkJet...
GETTING ERROR CODE E27, INK ABSORBER FULL
Canon error e27 ink absorber full/reset process
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
May 13, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Absober waste ink is full. Pls help. error code
you need to replace the absorber waste ink pad and service the printer
Nov 17, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error E27
Removing & Cleaning the Absorbent pads.
The printer has 2 ink absorber pads that are located under the ink cartridges.
With power off the head assembly / cartridges can be moved into the middle for access.
Each of the 2 ink absorber pads are seated in a rubber retainer. The pads can be easily removed cleaned or replaced.
Carefully remove the pads using long nose pliers or tweezers.
Clean the using with running warm water, or use an isopropyl alcohol bath, or an isopropyl alcohol based aerosol if they are really dirty. DO NOT USE ANY SURGICAL SPIRIT OR ANY OIL BASED CLEANERS. At a push you can use a warm water mild washing up liquid bath but be sure to thoroughly rinse out the solution after cleaning. The pads should be white when they are clean.
Dry the pads – it may take some time and placing them in a warm environment or near a warm radiator will speed this up.
Clean away any ink on the retaining rubbers using a cotton bud or clean and soft lint free cloth.
Replace the DRY pads in the rubber retainers.
Replace the Ink cartridges.
Power on the printer and print a test page and clean and realign the heads as required.
If the E27 error message reappears then you will need to reset this.
Clearing procedures for E27 or Error 27 Code.
Power on the printer by pressing the Power button while pressing and holding the Stop/ Reset button.
When the Power led is green press the Stop/Reset button two times while pressing and holding the Power button.
When releasing the Power and the Stop / Reset buttons the printer will move into a service mode and will be Waiting for a menu selection.
When the Power led is green, press the Stop/Reset button 4 times for waste ink counter reset.
Oct 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Erro code on printer
Error code means
E27 = Waste ink absorber full or platen waste ink absorber full
Yes, you can do this yourself.
YOu can do a search on here for the error code, there are instructions on how to reset the error and clean the absorber..
Or you can do a search for the "SERVICE" manual for your printer and order it, then follow it's instructions to clean the pads and reset the error.
Let me know if you can't find the solution on here, and I will post it for you.
Aug 31, 2009 | Office Equipment & Supplies
My printer MP140 shows error E27. Can I to reset this error
How to clear E27 Waste ink absorber full
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times
3. When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)
Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5.Turn off the printer.( it must be turn off) then turn it on again
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 04, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer show E 2 7.
Hi zaris79,
The E27 code means that the waste ink absorber is full. You'll need to clean the absorber pads and reset the error code. Here's how:
The absorber pads are on the right side of the printer, under the ink cartridges. With the printer on, lift the top to expose the cartridges. They will automatically move out of the way (you can move them to the left by hand if the printer is off). You might need a flashlight to see the pads - each is positioned in a rubber retainer.Take the pads out of the retainers with tweezers and clean them with warm water. If there is ink in the rubber retainer, wipe it out with a paper towel. Finally, put the clean pads back into the retainers.
If the printer does not realize that the absorbers are clean, it may still give you the error code - here's how you reset it:
1)With the printer powered off but connected to a power source, hold down the Stop/Reset button and press Power (the power light should light up).
2) When the Power is lit, hold down the power button, and press the Stop/Reset button two times (then release both - the printer should enter service mode. (Waiting for menu selection)
3) Press the Stop/Reset button 4 times to reset the waste ink counter.
4) Turn off the printer, and turn it on normally. That should do it.
For your reference, here is the complete list of error codes for the MP150:
E2 No paper (ASF)
E3 Paper jam
E4 No ink
E5 The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera-Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Dec 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
E27 Error Reset
E27 Waste ink absorber full or platen waste ink absorber full.
Download the MPTool from this site. It is a resetter utlity for the MP series printers.
http://pcprinter.blogspot.com/2008/02/mptool-multi-resetter-for-canon-mp.html
copy and paste the complete link into your browser.
Thanks, Joe
Nov 19, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP210 Photo All-In-One Printer Logo
2,114 people viewed this question
old marine
old marine
