Question about Panasonic AG-DV1000 Mini DV VCR
NO Power My Panasonic DV1000 deck no longer powers on. I checked the fuse & it is fine. Any Help out there? Does this deck just stop working after a period of time, it has over 900 hours on it.
    Novelist:
    Champion:
  • 254 Answers
If you have a voltmeter and some tech savvy, you could check the power supply section for the presence of the required voltages. You should see a +5, and one or more other voltage sources, like +12 volt. If your power supply is dead, then a component failure in the power supply is likely, or there could be a short/overload elsewhere that is keeping the p/s in protective shutdown.
Posted on Jun 15, 2007
    Champion:
  • 221 Answers
There are several fuses on the main board in this machine, including one that you need to remove the mechanism to find. I've had a couple DV1000s that had that fuse blown; it's in the supply to the fan motor, and when the fan shuts down, the micro in the deck senses it, and powers the deck down.
Posted on Jun 27, 2007
Hi, my sony ta-fe370 has stopped working. All fuses seem fine and there is no obvious visual problems inside. The red led next to the power button comes on but then goes out again. The source selection...
What power are you meaning that Also, all of the other decks connected to this also have lost power Is this mains power If so check the power on the switch
Oct 12, 2013 | Sony TA-FE370 2-Channel Amplifier
Powerloss on a panasonic sa-pt160
hi, how about the power supply board have you been check is their any sign of bulging capacitor or burn component parts ?. check also the power cord might have loose connection.
Mar 22, 2012 | Panasonic Televison & Video
I have a AG DV1000 mini DV deck I can't turn it on no powerat all, how can ai fix it , where have to send it?
Hello, thanks for using Fixya.com
I would check another power source, if it still does not turn on you might have a bad fuse inside the unit witch would need to be replaced and inspected for cause of blow out.
Panasonic would take it under out of warranty bases you might want to give them a call and ask about a local factory repair shop. Most VCR and TV repairmen in your local area if you cannot find a factory service center would be your best bet.
I would not open the unit unless your knowledge fits your budget because of hazards and other occurrences can occur.
Give this website a shot for parts and service locations
Please let us know if you have any further questions,
Best regards,
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 14, 2011 | Panasonic AG-DV1000 Mini DV VCR
JVC KD-G310 stopped working after battery change
have you pulled the deck and checked the built in fuse beside where wiring harness plugs in
Oct 19, 2009 | JVC KD-G310 CD Player
No power in either turntable
maybe the power source that goes into the deck itself has dissconected, but it is strange that niether would work...so im guessing the decks are fine...it might be your extension cable...or u have had a power surge, if that has happened...then you need to seek profesinal help...and unfortunally, your decks may have died. But check your plugs/extension cables...etc....it should be a basic problem, and easily fixable
Aug 03, 2009 | Technics SL-1210 Turntable
No power windows working,My temp readout on overhead no longer
Many power window systems have relays in addition to fuses look for and check the relay Good Luck!
Jul 19, 2009 | 2002 Jeep Grand Cherokee
Stop working
IS IT POWER UP.
please rmoove the cover and check the fuse also.
is it work?????
nuwan
Jan 11, 2009 | Panasonic NN-S540BF Microwave Oven
Will not power up at all!
check the main board for bad solder connections near the power connection.
Oct 28, 2008 | Panasonic AG-DV1000 Mini DV VCR
Hp pavilion dv1000 power fault
your power pack look at the voltage/ohms/stuff like that and check them with the under side of the computer
Aug 16, 2008 | Computers & Internet
AG-DV1000P that powers off when tape is put in.
hi sir one of the reel or capstain motors should be not allowing to work something prevents it from rotating check with hands for fluidity of capstain or reel motor that power off is a conclusion of a short while motor tries to spin check for any thing broken in the guides or the path regards please don't forget to rate ,thx
Mar 30, 2007 | Panasonic AG-DV1000 Mini DV VCR
Panasonic AG-DV1000 Mini DV VCR Logo
210 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
