WHERE CAN I FIND EXTRA CODES FOR A ROSS TVRC4-RS 4IN 1 REMOTE
I NEED A CODE FOR A "PACIFIC" DVD PLAYER, NO CODES ARE LISTED WITH THE REMOTE
  • PRINTERMAN09 Jan 24, 2009
    I HAVE THE SAME PROBLEM FOR A WHARFEDALE (ASDA TV) CAN ANY ONE HELP PLEASE
3 Suggested Answers
minteker
  • 52 Answers
SOURCE: need code for panasonic remote
Hey, here's a link to the user manual for the EUR7603Z10:
http://service.us.panasonic.com/OPERMANPDF/EUR7603Z10.PDF
Pages 7 and 8 have codes for the VHS/DVD players...
If that doesn't work, here's the manual for the DMR-E75V... http://service.us.panasonic.com/OPERMANPDF/DMRE75V.PDF
Posted on Mar 12, 2008
blueextc3221
  • 15935 Answers
SOURCE: Comcast remote code or an generic code that might work
CLICK HERE to select the style remote you have and view the manual - including code lists.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 26, 2009
  • 1779 Answers
SOURCE: I have a Sanyo DVD
Remotes.com has it for $54.99
Posted on Nov 20, 2009
How do I change my remote for TV to Input Video 1?
There should be a button on your remote denoting "Input." If you connect the DVD player to the TV on "video input 1" then push the input button on the remote or TV itself until the DVD appears on your TV (which will be Video 1). Some TVs must have the component (in your case) the "DVD" player connected to the TV before the TV will recognize it. Make sure the DVD is powered up and then push the input button until the DVD player appears on the TV. Depending on your TV inputs, there may be multiple inputs like, Video, Component, DVI, or HDMI. The above are listed in the respective order of "quality." HDMI being the best. Whatever input you hook the DVD player up to on the TV will be the "input" you will look for when pressing the input button. Hope this helps.
Oct 26, 2009 | Mitsubishi WS-48515 48" Rear Projection...
I am in Australia and have just bought a DMR BW500. I have a dvd from Japan which won't work on it and I have been told that if I unlock the region code, then it will work. So how do I unlock the region...
The following works on a region 4 player. With no disc in the player and the drawer closed, press stop, stop, setup, then 3,8,8,8,3 and the desired region code, (0 for multiregion). Nothing will appear on screen. Then switch the player off and back on. It should now play discs for any region
Sep 04, 2009 | Televison & Video
I need a code # to program my Universal RCA remote for my Prima TV and my DVD player
I own a One-for-All universal remote, and my booklet says the setup code for a Prima TV ( without a built-in DVD or VCR) is one of the following numbers: 0761, 0783, 0815, 0817. I can not guarantee these numbers will work with your remote, but it is worth a try.
I assume your DVD has been attached separately, and not built into the TV. In some cases, you might not need an additional setup code. Once the TV has been turned on, you simply push the DVD button on your remote, to activate the DVD. The instructions which came with your remote and your DVD should provide you with more details. If the instructions indicate that an additional DVD setup code is required, then please respond by telling me the brand name of your DVD.
Jul 04, 2008 | Televison & Video
Need to program a ge universal remote control to operate a Magnavox Total Control System TV
here is the 3 digit codes ive found to try 586, 651, 720, 666, 731, 800
MAGNAVOX ............ 0062 0004 0009 for digit codes
........................... 0456 0183 0226 0288
........................... 0008 0068 0075 0141
Manually turn on the device (TV, VCR, DVD, etc.) you wish to
program.
2. Press and hold the CODE SEARCH/SETUP button on the remote
until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming
(TV, VCR, DVD, etc.). For AUX, press AUX then the device button
you are assigning to AUX. The INDICATOR LIGHT will blink then
remain lit.
4. Enter the three or four digit code for your device using the number
buttons in the GE Universal Remote. After your code is entered the
INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the
POWER button. Your device should turn off.
Note: If your device does not respond to the first code listed,
repeat steps with the next code. If none of the codes listed for your
device work for your device or your brand is not listed,
try the Code Search method described below.
USING CODE SEARCH FUNCTION
If your TV, VCR, DVD, etc. does not respond after you have tried all the codes
for your brand or if your brand is not listed, try searching for your codes by
following the steps below.
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR
3. Press and release the device button for the device you are
programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will
blink once then remain lit. For AUX, press AUX then the device
Jun 21, 2008 | Televison & Video
Need set up instructions and codes for one for all remote urc-3220
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH+, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
CHECKING THE CODES
If you have set up the remote control using the Searching For Your Code procedure
as above, you may need to find out which four-digit code is operating
your equipment. For example, to find out which code is operating your
TV:
then release SET.
3. Enter 9 - 9 - 0.The LED will blink twice.
4. To view the code for the first digit, press 1 once.Wait 3
seconds, count the LED blinks (e.g., three blinks = 3) and
write down the number in the leftmost box in the TV
code boxes on page 8.
NOTE: If a code digit is “0”, the LED will not blink.
5. Repeat step 4 (on the previous page) three more times for
remaining digits.Use 2 for the second digit, 3 for the third
digit, and 4 for the fourth digit.Write down the code digits
in the remaining TV code boxes on page 8.
6. To check for codes of other devices, repeat steps 1
through 5 (starting on the previous page), but substitute
the appropriate device key for each device you are checking.
Write down the device’s code digits in the appropriate
I could not find the codes but you can follow these instruction to program without codes
Jun 19, 2008 | Televison & Video
Need code and instructions to program my JVC TV for a One For All URC-4220
The code is 0053.
1. Turn on the device you want to set-up (ie: TV, DVD, etc).
2. On the remote control, press the device key for the device to be set-
up. For example, to set-up a TV, press the TV key; to set-up a DVD,
press the DVD key, etc.
3. Press the "SET" key and hold until the small light ("LED") on the
remote control blinks twice, then release.
4. Enter the Code for your device. If you've done it correctly, the "LED"
light will blink twice. (Note: 'Codes' are listed in the instruction booklet).
5. Press the "POWER" key and the device will turn off.
Apr 26, 2008 | Televison & Video
My grandmother needs the code her GE universal remote to operate her Sharp TV. Thanks
MANUALLY ENTERING CODES
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to
program.
remain lit.
device work for your device or your brand is not listed, try the Code
Possible codes, seeing as each tv is different you will have to try until one works, the third list is for models bought before August 2002
found all of the below info at http://www.jascoproducts.com/support/universal-Remote-codes.asp
SHARP .... 0079 0123 0063 0020 0004
....... 0009 0226 0266 0006 0095 0122
SHARP
591, 604, 729, 671, 679, 684, 809
Sharp
004, 006, 012, 029, 095, 111, 112, 113, 122, 171, 173
Let me know if you have any questions, please don't forget to rate my solution after you fix the problem
Apr 25, 2008 | Televison & Video
I need the remote control code so that my oneforall (URC-7930 remote control) will work on my Pioneer (XV-HTD1) DVD player as I have lost the remote (XXD3033). Thanks for any help
Go to this page, the download of the manual of your remote will automatically start. From page 123 you can find the codes for several brands. On page 129 you can find the codes for Pioneer. Just try them until you find one that works.
The manual also explains how to set up the remote for your dvd-player.
Apr 03, 2008 | Televison & Video
Apex Digital GB4308 remote
Programming the Remote Control Remote-control switchover Press VCR/DVD, SAT/CABLE or AUX to select the device you want to control. To program the remote control Press and hold VCR.DVD, SAT/CABLE or AUX for over 2 seconds until the LED on the remote control turns off. Release the button the LED will light again (the remote control enters the PROGRAMMING mode). Enter three-digit code number for your equipment. If the correct code number is entered, the LED blinks three times. If you enter a code not listed below, or you press any other buttons than SEARCH and 100+, the LED turns off. To search codes Press ad hold VCR/DVD,SAT/CABLE or AUX for over 2 seconds unil the LED turns off. Release the button (the LED wil light again) and the remote control enters the PROGRAMMING mode. Press SEARCH. Press CH+/- to search codes downwards or upwards. Each time you press CH+/-, the code number decreases or increases by 1 while the remote control sends the code number for POWER button on your device. If the desired code number is found,press 100+ to program the code for your device until the LED blinks three times.Then the remote control exits from the PROGRAMMING mode and returns to norml operation. Or press any other button to exit from the PROGRAMMING mode after the LED blinks rapidly eight times, and the operation is not active. To check the current code number Press and hold VCR/DVD, SAT/CABLE or AUX for over 2 seconds until the LED turns off. Release the button (the LED will light again) and the remote control enters the PROGRAMMING mode. Press 100+ . You may read the code numder according to the LED display status as follows. * If there is no operation within 20 seconds during the steps mentioned above, the remote control will automatically exit from the appropriate operation. Code Number First - digit 0 1 0 1 Second - digit 0 0 4 5 Third - digit 0 6 3 0 First - digit Blinks rapidly once Blinks once Blinks rapidly once Bliks once Secod - digit Blinks rapidly once Blinks rapidly once Blinks four times Bliks five times Third - digit Blinks rapidly once Blinks six times Blinks three times Bliks rapidly once
Jan 05, 2007 | Apex Digital GB4308 43" Rear Projection...
Televison & Video Logo
519 people viewed this question
Top Televison & Video Experts
Electro Med Services...
