Question about Canon ImageRunner 1600 Copier
E100 Canon ir1600 probleme E100
  • Anonymous Apr 14, 2009
    E 100
  • 26 Answers
Salut.
E100 means :
When the scanner motor is started up, the BD input signal does not arrive within a specific period of time.
When the scanner motor is started up, the motor rotation is too fast, and fails to reach a specific revolution within 20 sec at time of deceleration.
While the scanner motor is rotating at a specific speed, the BD input signal cycle is not within a specific range (±2%) for an equivalent of 10 mm (print distance).
While the scanner motor is rotating at a specific speed, the BD input signal cycle is not as indicated (±2%).
During the WMUPR period after the power switch has been turned on or the front cover/left cover has been opened/closed, the drum unit is absent.
Possible cause: The wiring is faulty (short circuit, open circuit). The laser scanner unit is faulty. The DC controller PCB is faulty. The drum unit is not installed.
Posted on Jan 14, 2009
  • 1,219 Answers
Replace whole drum unit.CEXV5
Posted on Jul 07, 2010
    Problem Solver:
  • 11 Answers
Check whether drum unit is engaging properly in its position, if yes check for the spring tension for white lever on the laser unit. As soon as the drum unit engages its position the lever on the laser unit should move with the spring tension.
Posted on Mar 11, 2009
Check the drum unit tab it amy be broken
Gajendra
I Just replaced the toner in my CANON IR1600 PHOTOCOPIER and now have the Error code E100. I put the old one back in to see if it was different but it still said E100. How can I fix this? Thanks
Hi carolyn ,
I am a professional canon service eng . My Name Is D K Kumar . e100 is not related to toner at all . it is the indication that the develper unit has not been detected . remove the left side cover . you will be able to see the top of the develpoer unit. On the left top portion of the developer unit u can see a white coloured accuvator . it is a small white plastic piece ..whhen the side door is closed te white piece should get pressed or should move forward . if the moving action is not happening then the m/c will give u E100 error. in your case the reasons /problem could be :
!) The spring connected to the white plastic accuvator is missing or spring action is not happening.
2) the white accuvator it self is broken or missing.
3) the plastic stick /piece which protudes from the side door and pushes the accuvator is broken.
4)lastly you have not closed the side door properly or not closed at all.
Carolyn if u r able to understand my above tips thn u can do it your self , if not call a your local canon enginer.
best of luck God Bless u
P.S. Carolyn if my solutions have helped u then i request u to kindly reply to me at my enail id: narkumar81@rediffmail.com
Apr 10, 2011 | Canon Office Equipment & Supplies
Canon copier iR1600 machine giving code E100
A E100 is the laser shutter is not opening. There is a spring that most likely came off. It is actuated by the door closing. You may have to get a service technician to repair it for you.
Jan 24, 2011 | Canon iR 1600 Laser Photo Printer
My copie canon ir1600 give problem code E100?
check the drum unit, does it fit well? if not replace it else laser unit is faulty. replace it
Dec 30, 2010 | Canon Office Equipment & Supplies
Canon IR1600 - E100 error
Delete the softwere from control pannel then install it again using the CD provides with the Printer
Feb 13, 2010 | E-Games Fax & Photocopy Full Version for...
Sir,My IR1600 dosnt fuction or now dosenot start to work
Hi, do you have an error message like E100 ? Please be specific.
Mar 22, 2009 | Canon imageRUNNER 1600 Laser Printer
SYSTEM ERROR E100
Hey
How can I solve this error code(IR1600) on my canon copier by myself?
Nov 27, 2007 | Canon imageRUNNER 2000 Copier
487 people viewed this question
old marine
old marine
