Afficio 450 hi cogz i have desame problem with moody.. everytime i run a copy 50 to 100 the copy become gray or more lighter.. i always push the toner supply (2207)... what u mean to adjust the settings in service mode ATDC
  • 92 Answers
You need developer 7734748865
Posted on Jun 28, 2009
How to calibrate the dv and toner...afficio 450.or gestetner 3245
Hello sir; Just follow the steps;
1, dump entire dv use vaccunm cleaner to cleanup don't leave any dv inside.
2, thorughly clean out magnet roller by rubbing alcohal.
3, pour in new dv evenly.
4.Do simulation 2801 & 2805, the procedure as follow;
press"clear mode", "107", press and hold "clear/stop" key for 3 seconds, then press 1 for copier sp then enter2801 press start, after that go to 2805. same procedure. Let me know the resolve.
Mar 02, 2009 | Ricoh Aficio 450 Copier
Afficio 450 olridy change developer but the copy is stil faded
There are two service codes that you need to run 2801 and 2805 after you put the developer in the machine.
Press the yellow button on the copier. press 107 on the keyboard. Press and hold the clear button. Then run the service codes.
You have to run the codes first after changing the developer. You might have to replace the developer again to get the correct mixture.
Jan 26, 2009 | Ricoh Aficio 450 Copier
Afficio 450 copy faded in some area...
If the image is good in parts, but light in others it is most often toner build up on the laser exposure glass which can be easily -but also VERY CAREFULLYremoved. If you lift the green handle for the toner bottle, you should see a narrow piece of glass protruding just underneath. You can grasp it with you fingers and slide it out for cleaning. Sometimes these have been removed (or broken) so they are not there. If the machine is also a printer, you should see much improvement (if this was the cause). If regular copying is still light in areas, then you may want to remove the copier glass - 2 screws on left scale, and 3 screws on rear scale (POWER OFF ON MACHINE), remove glass and clean with glass cleaner, then slide scanner to the left and clean the mirrors.
Hope this helps.
Jan 17, 2009 | Ricoh Aficio 450 Copier
The copy of afficio 450 become lighter
You may want to consider putting developer into the unit. What is the copy count on the machine?
Jan 15, 2009 | Ricoh Aficio 450 Copier
Gestetner 3245 get lighter wen run 50 to 100 pgs
the amchine runs a density patch every 50-75 prints if you run long jobs it cannot run patch till job is finished which is why your copies get lighter the longer the job
Jan 14, 2009 | Office Equipment & Supplies
Afficio 450e gray copy or lighter copy
Look into replacing the developer in your copier. It has to be replaced every 125,000 cycles.
Afficio 450 seeting
Auto setting. If you are getting light copies, you might need the developer replaced as well.
Aug 21, 2008 | Office Equipment & Supplies
Developer....
When developer goes bad you use more toner for one thing, but the main sign is a gray background in your copy. The print should be black but appears to be gray. The ricoh 350/450 was always noted to leak toner and developer as it runs. Check your machine and see if you see any small piles of toner, which also has developer in it, in the machine. Ther are small seals made of felt that need to be replaced if you have this problem. These seals rub against the drum sides....Good luck.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Fuser..?? afficio 450
The fuser probably will not help. I think you probably will need a PCU, and a service call.
Rico afficio 450
Dev. initialize should only be done when replacing dev.otherwise it will not add the correct amount of toner to the dev.Replace developer and run sim.2-801 in service mode.
Jul 19, 2008 | Ricoh Aficio 450 Copier
54 people viewed this question
jasbo
jasbo
