Question about Kenmore 43142 Front Load Washer
My washer won't fill and sounds like it's draining.
I have been doing laundry and when I started this wash, the water won't fill and it just makes that grinding sound it makes when it is draining. I've checked the water hoses and they aren't kinked, I've checked the drainage hose and it is where it's supposed to be. My washer has been working fine for over a year. Is this something that is just due to happen or is it something I can fix? I need my washer to work, I have 5 kids and a pile of laundry.
This usually shows an error code of 21. I've heard that this is partly because of poor pump design. Anyway, a few things to try: Start by taking the lower panel off the front of the machine. There should be 3 1/4 inch hex head screws. Now, look for the round thing about 3 inches in diameter with a horizontal plastic piece in the middle. This plastic piece unscrews (counterclockwise) to reveal a filter. Remove all the coins, buttons and other junk from this area and from the rubber hose that you can see after taking the filter out. You might also try removing the large rubber hose that connects to the pump and remove all the junk from it. It's a little tricky getting the hose clamp back on, so consider buying a screw type clamp to replace the original spring type clamp. Put everything back together and see if it works better now. If not, you may need to replace the pump assembly. Disconnect three hoses, then remove two 5/16 inch hex head screws (access from the bottom of the machine). Slide the pump assembly to the right and it will come out upward. My pump was bad-- it still ran but the electric motor part was full of water and detritus (junk). A new pump assembly should cost $60.00 or less -- it's the same assembly used in MAYTAG and some other brands, so you don't have to go back to Sears to get it. You should be able to get a replacement from your local repair shop. Reassemble with the new pump and, if you're lucky, it will work "good as new" for another six months or so.
Posted on Sep 25, 2007
    President:
  • 1,294 Answers
Check to see your inlet water pipes are not clogged. Then see that your outlet drain pipe is approx 30 inches or more from the floor level. Your pump pumps the water up over the level into your wall drain or whatever. The water mark is usually marked somewhere at the rear of the machine. See that your inlet valve is closed before you check for your blockages; after you've fitted it back after cleaning, open your valve.
Posted on Jun 13, 2007
My admiral washer does not work on wash cycle. It will rinse and spin on any cycle but wash
hi Marilyn.
this is what i have found but not sure if this will help you out,if not go to the link at the bottom and see if it helps you out.
Step 1
Make sure the washer's cord is plugged in to a functioning outlet if the Admiral washer won't fill with water. Check your circuit breaker to make sure the power is on and reset it if necessary. Reset the dial and start the washer again. Turn both of the washer's faucets on to full power. Untangle any inlet hoses to remove clogs. If this doesn't work, your hose filter screens could be clogged. Disconnect the hoses from the washer and clean the screens of any residue.
Step 2
Close the washer's lid completely if the Admiral washer will not agitate. The washer will not start if the lid is open. Restart the washer by setting the control dial to the desired cycle. Momentary pauses during cycles can be expected. You may need to wait a minute or two to see if the washer starts. Check the circuit breaker to make sure the washer is getting power. Reset the circuit breaker if necessary.
Step 3
Check and reset the circuit breaker as above if the Admiral washer will not spin or drain. Untangle any of the washer's hoses to allow water into the machine. Check your drains for clogs that may be preventing water to move into the washing machine. Close the lid and restart the washer. The washer will not start if the lid is not completely closed. If there are excessive soap bubbles in the washer, the washer may have locked up because of this. Wash the load again without adding detergent.
Step 4
Rearrange the laundry so it is evenly distributed if the Admiral washer stops or if laundry is still wet at the end of a cycle. Untangle any laundry from the center post in the wash tub. Select the correct water level for the amount of laundry. Select a normal spin cycle for jeans, towels or other heavy loads. Close the lid and start the washer.
Step 5
Check the hoses to make sure they are tightly connected to the Admiral washer if it leaks water. If they are loose, tighten them with a screwdriver. Make sure the drain hose is secured to the drainage area. Avoid putting too much laundry in your machine or soaking laundry for over 30 minutes.
Step 6
Make sure the Admiral washer is on a level plane if it is excessively noisy. If it is not on even ground, move the washer so that it is level. Remember that some washer noise is normal. Thin floors can cause the washer to vibrate and move about and the noise level may rise and fall depending on the speed of the cycle.
admiral washer does not work on wash cycle Google Search
Nov 25, 2017 | Washing Machines
Washer won't drain and spin
Drain pump is cloged. What kind of washer is it . and you said stacked and laundry center. stacked is 2 seperate units and laundry center is one whole unit with both so whatcha got?
Feb 17, 2013 | Frigidaire Washing Machines
Washer will not stop filling up with water and won't agitate
Is the standpipe for the drainhose at least the height of the basket or control panel?
May 26, 2012 | GE Washing Machines
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
My water is draining out of my machine as it is filling, Why?
This is a condition known as syphoning. Your drain hose on the washer needs to go up before it connectes to the house drain. It needs to rise as high as the washing machine top then hook over the drain pipe. If the drain hose is pushed too far into the drain pipe this can also cause syphoning.
Here are some tips to help describe this better.
Is the drain hose extending more than 8" (20.3 cm) into the drainpipe?
The drain hose may be too far down inside the drainpipe (standpipe) or laundry tub. Drained water can siphon back into the washer if the drain hose extends too far. Make sure that the drain hose does not extend more than 8" (20.3 cm) into the drainpipe or laundry tub. Using the U-shape drain hose form (as described in the Installation Instructions), will provide the correct length of drain hose in the drainpipe or laundry tub.
Drain hose form
Is the drain hose taped onto the drainpipe? Is top of the drainpipe covered in tape?
Do not seal the drain hose into the drainpipe with tape. The drain hose should be loose, yet secure. There must be a gap between the drain hose and the drainpipe to allow air to flow. The air gap will break the suction. This will keep water from being continuously sucked out of the machine (siphoning) as it fills.
Is the drainpipe (standpipe) less than the minimum height of 39" (99 cm)?
Make sure that the top of the drain is at least 39" (99 cm) high (as measured from the floor.) If the drain is below 39" (99 cm), the water will start to flow out of the machine due to gravity. The flow of water can create suction (siphon) and the water will continue to drain out of the washer.
Apr 19, 2010 | GE Washing Machines
Water won't drain and washer does nothing
pump is stuck or bad located under washer most are not hard to change
Dec 06, 2009 | Dryers
Softner Compartment won't drain
this may be a faulty valve that allows the water to fill the softner compartment.to check the draining capability remove the drawer and take it to a sink make sure it remains level you you sink tap or a cp of water and fill the compartment almost to the top and it should start draining once it starts to drain stop putting water in and watch it. it should finish draining by itself there will be some water left in it but only a small amount. if it does not drain clean it out.
Sep 24, 2009 | Samsung WF337AA Front Load Washer
Keeps on filling and wont drain
please follow the steps which i give to find and rectify the mistake (1) First check the wash load/laundry. If it is unevenly distributed in the tub making it unequal, rearrange it, close the lid again.
(2) Make sure your washer is leveled and you have filled sufficient water in the tub for that size of wash load/laundry. Insufficient water can make imbalance.
(3) Make sure the power cord/cable is plugged into the working electrical wall socket.
(4) It is better to check the appropriate circuit breakers or fuse of the fuse box and reset if necessary.
(5) Inspect the drain hoses and remove any bends. Inspect the drain system, too - if it's clogged.
(6) Then close the washer lid and pull out the knob to start it. For your safety, the washer will not spin unless the door is closed.
(7) Excessive foam can also cause this problem. If you find it to be the solution, rewash the clothes with plain water. For future, ensure use of correct amount of detergent with low-foam.
(8) It is possible that the lid switch, that prevents the washer from spinning when the lid is open, could be malfunctioning. If that happens, a built-in mechanism – brakes will be applied and washer will stop washer operations until the lid switch is repaired/replaced.
Jun 13, 2009 | Washing Machines
Washer will not fill to appropiate levels
If " Washer will not fill to appropiate levels " this has nothing to do with drain pump and control board is unlikely.
That sounds like a water level switch that is malfunctioning, or a badly connected control board, call back the technician and tell him to double check the job done on control board.
Jan 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Water comes up into our tub when washer drains
The washer puts out a lot of water when spinning/ draining, sounds like the house drains are not of sufficient size or possibly blocked causing water to backup into your tub, check house drains for blockage or install seperate drain for washer into main drain that your tub goes into.
Oct 27, 2008 | Admiral AW22 Top Load Washer
Kenmore 43142 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
