Question about Microsoft Windows Vista Ultimate Edition
Chkdsk is not working in the comandprompt. It replies as: Access denied as you donot have sufficient privileges. You have to invoke your utility running in elevated mode. What i shoud do to solve this problem? Please give me full details of the solutions available
    Guru:
  • 859 Answers
As a user on the system do you have limited or administrator privilegeds?
Let me run down the procedure and you can tell me first if you are doing it this way or not. OK?
To run Check Disk
Press at the same time the Windows Logo key + R, this launches the Run Command Dialog box at the bottom left of the screen.
In the text area of the run command dialog type: cmd
This opens a Command Window
With the Command Window open type this exactly:
chkdsk /f /x c:
The command is "chkdsk" without the quotes
Then there are operators known as switches. These are invoked using the forward slash (or slash) more commonly known as a "switch" in programming language.
There are several operators that can be invoked. To see them all type:
chkdsk /?
That will list all the possible operators you can invoke in the chkdsk command. This is useful should you need to refresh your memory of what to do.
The operators invoked with the slash switch may often be substituted with the dash symbol (-) without the parenthesis.
In our case we want Check Disk to check drive C and access the drive exclusively. As the C drive has the operating system running it has open handles. Open handles are executable files running to allow the function of Windows. By invoking the /x switch this forces Windows to execute your command in the only exclusive mode possible which is during bootup.
The switch /f tells Check Disk to fix any errors. Should you suspect you have damaged areas of your hard disk you would use the /r switch which instructs Windows to attempt to repair any damaged sectors and if unable to mark them as unusable and move that data to another area of the hard drive. The /r switch implies the /f switch.
Normally you will not want or need to use the /r switch unless you are told by Windows that there are damaged areas of your hard drive.
So, in our case the /f (to fix sectors and files) and the /x (to do this in exclusive mode) and then lastly typing the drive letter to check in our case c: instructs Windows to act immediately.
In order to run this command you do need permissions called security descriptors for your user account. Simply put, your account would be an Administrator account and not a limited account. Most accounts in Windows are administrative. To change a limited account to an administrator account you need a logged on Administrator who can access your limited account and change your privilege to Administrator. If you have none, you need to bootup in Safe Mode log in as Administrator (usually no password, or it is "Admin" without the quotes and either upper and lower case or all lower case.
In conclusion, should you press Windows Key + R, the run command line dialog appears; next you tye CMD to gain a command window; you then type in "chkdsk /f /x c:" without the quotes. Windows should attempt to obtain exclusive mode which it can't and will then ask you if you want to run this on the next boot. That is the normal response. You would then answer Y for yes and Windows will reboot or you will have to tell it to reboot using the Restart Sequence.
Should non of this happen and you do have an administrator account, then you probably have a virus infection hiding in a sector on your hard drive where Check Disk will remove it. There is a way around this if this is the impediment you are facing. More on this at the end if you are locked out.
Reboot your computer and on restart Press F8 like a piano key, you may be asked from where do you want to boot? Choose your Hard Drive and then immediately, immediately press F8 again like a piano key. This will bring up the Safe Mode boot options. Here is where you would usually choose Safe Mode. However, in this case, choose Safe Mode with Command Prompt. Once it boots up and you have half the screen occupied by a command window, type out the command once again to run Check Disk with the switches
chkdsk /f /x c:
needed to fix your hard drive and repair your security descriptors. From this Safe Mode Command Prompt you will have privledges and the command should execute with no problem. If it doesn't you have a serious problem on your hand and will require running a thorough Virus Scan specifically from an online Virus Scanner.
To run an online Virus Scanner follow the instructions in this Tip I wrote here:
After you attempt this and if you still have a question or should you run into trouble use the comment text box below or the Ask Me button to respond to me directly. I will then receive an email alert and will respond at my soonest. Note that I am away from my desk a great deal of the working day and am at it in the evenings though.
Regards, and good hunting,
Worldvet
Posted on Jan 14, 2009
  • 258 Answers
When going into the CMD prompt, right click and select run as administrator
chkdsk should then run successfully
Access privileges error message (-5000) while creating "Grooves" while translating MIDI Operation Data
During installation, I receive "Error creating file. 1008:5,-5000 Access denied error".
I share a link please visit and read web page i hope solved your issue.
http://support.dataviz.com/support.srch?docid=13157
Thanks,
Mac Support
May 28, 2014 | Apple iMac Computers & Internet
Denied access to hard drive
Well, I assume that you are using Windows? As you have not declared this.
You plug in the device and check what drive letter is reported.
Open "Cmd" in Admin mode then type
chkdsk <DriveLetter> /F
CHKDSK Wikipedia
Oct 26, 2017 | Computers & Internet
Insufficient privileges to access this directory
You can remove or change the Window's User or administrator's password and privileges. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Mar 30, 2013 | Office Equipment & Supplies
I had a Wireless and suddenly disappeared from the Information Bar appeared these words some of the controls in this property sheet are disabled because you do not have sufficient privileges to access or...
Check if you have administrative privileges on notebook.
Restart and boot in control panel and check in user accounts.
Goto network and internet and try connecting to wireless network.If still not working try creating a new user account with administrative privileges and check.
Thankyo
Sep 09, 2010 | HP Smart Buy Notebook
ACCESS PROBLEM TO E-MAIL, MY DOCUMENTS
HI
1) Bringing up the Task Manager (CTRL - ALT - DEL)
2) Then click File -> New Task / Run
3) Browse to "C:\Windows\explorer.exe" (it may just say "explorer")
4) Click OK
This should bring up your desktop long enough to run the malwarebytes software, which will fix this issue, once you complete the scan.
link for malwarebytes
http://www.malwarebytes.org/mbam.php
Hope it can resolved your isue
Thanks you for using Fixya
Mar 22, 2010 | Computers & Internet
My father recently " Backed up" my Macbook and when he gave it back my desktop was wiped and when I went into the finder and clicked on the desktop folder it said it couldn't be opened because I didn't...
Simplest way is to run disk utility and hit the repair permissions button.
If you want to get all fancy about it you can use the terminal (also in utilities folder) and use chown or chmod. If you want to learn those commands type "man chown" or "man chmod" The man command brings up the manual page.
Much easier to use disk utility though.
Jan 10, 2010 | Apple aluminum 13-inch MacBook laptop-...
Access denied when installing win xp service pack 3
Are you logged in as an administrator on your PC? Access Denied is almost always an indicator that the current logged in user does not have sufficient permissions to install applications. Let us know if this is not the case. Hope this helps!
Dec 28, 2008 | Microsoft Windows XP Home Edition
Cannot delete photos - access is denied
Turn off the device then turn it back on. that should solve the problem. normally this is because a program on the Palm is still associated with that picture. turning it off and on severs that association.
I hope this has answered your question sufficiently. If you have more questions please post a reply and i would be happy to assist. Thanks.
Oct 05, 2008 | Palm Treo 750 Smartphone
Microsoft Windows Vista Ultimate Edition Logo
142 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
