Question about Sharp AR-407 Copier
I have Sharp AR-407 Grayscale Copier and i got the problems in it . it showing me the E7-11 code . i dont know how to solve this problem . can any one help me to solve it thnx
  • 29 Answers
This is ccd white correction , clean the opitus really good and under the plat on the right side make sute there is no condisation or dirt on white plate
Posted on Mar 10, 2009
How to fix Sharp Ar-407 Code F2
There are a lot of choices for F2-?? Hold down the Start button to see the remaining digits.
Sim 22-6 will print all jam codes & error codes. It should be a process control code. F2-31 or F2-37, Drum mark or image density. You can execute 44-6. This should show which is out of range. Pull the drum unit out & clean both sensors. Check that the blade is cleaning from end to end that the DM is visible to the sensor.
Dec 26, 2010 | Sharp AR-407 Copier
Sharp AR-407 message F1-00 - Do I really have to call service? What is it trying to tell me.
The F1-00 deals with the sortor / finisher. It means there is a communication problem with the finisher and copier. What you can try is to turn the copier off & unplug the finisher from the copier and turn it back "ON" and is the code gone??? If so turn the copier OFF and plug the sotor back in and turn it back ON. If it works you are all set. You may also have a problem with the stapler unit? Will the code only show up with that funcation? If so, don't use the stapler. If the problem is still showing up leave the sortor unpluged. If that will not work for you, you may need a repair rep to vist.. Good Luck
Jul 06, 2010 | Sharp AR-407 Copier
Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Aug 26, 2009 | Sharp AR-168D Copier
Sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Apr 28, 2009 | Sharp AR-407 Copier
Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Apr 11, 2009 | Sharp AR-407 Copier
Sharp AR-407 Copier Logo
114 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
