Gorenje PS400GX Shorting
It seem that this washing machine is shorting, it tripped my house fuses and ebnen though thre power light is on nothing is happening when I try to start a new load.
  • 15,935 Answers
Likely the motor has developed a short. It may be wet from a failed tub seal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Fisher & paykel washing machine has no power
it was probably the pump shorting / overheating, and running it has caused it to blow the fuse in the motor controller.
Nov 08, 2013 | Fisher Paykel EcoSmart GWL15
Hotpoint wml540
Wire or component is shorting out. You may have to hire someone to find and repair it.
Nov 20, 2017 | Washing Machines
Hoover 1400 AAA washing machine tripping house fuse
Possible that the control panel is short and so is tripping the fuse. Remove the connection to the panel and check if there is short , also remove the motor and check and this can confirm the case.
Jul 03, 2012 | Hoover Washing Machines
Bosch 1200 classixx trips fuse unit
Possible that the program controller unit is faulty, it is possible that the power supply is short and so trips the fuse.
Remove the power panel and check for shorting, if so the program controller must be replaced.
Jun 27, 2012 | Bosch Exxcel WFO 2264 Front Load Washer
No heat in dryer
Thanks for using FixYa. If your dryer isn't working or isn't getting heated up, you'll need to check the following to be sure what exactly the issue is--
Blows fuses or trips circuit breaker —ELECTRIC Models:
• The amperage readings are at 240 volts. One line will be 24 amps and the other line will be 21 amps. The neutral line will be at 3 amps. If the above amperages are not present, then the house wiring, fuse box or circuit breaker should be suspect.
• Shorted heating element to housing.
• Incorrect wiring or a wire shorting to ground.
• Drive motor winding shorting to ground.
Blows fuses or trips circuit breaker —GAS Models:
• If igniter is not glowing, check for 120 V at igniter.
• Igniter harness may be loose and shorted to base.
• Incorrect wiring or a wire shorted to ground.
If it runs for a few minutes and then stops, then check for the following:--
• Empty dryer.
• Check motor spins freely.
• Lint buildup around drive motor.
• Low voltage present.
• Blower impeller blocked in blower housing.
• Drive motor - start switch contacts stuck closed.
Please do rate the solution and revert for further assistance.
Nov 12, 2009 | KitchenAid Dryers
Hotpoint Aquarius WMA42. I was using the machine when there was a bang and the electrics tripped. I reset the fuse box, checked the plug fuse and the socket but still nothing. No lights so presumably no...
It more than likely is the motor that has shorted. Remove lower rear panel, remove belt. Undo 2 screws that hold motor in place, remove motor plug, lever motor back to remove same,
Remove carbons and check for wear, also look at armature and see if there is any sign of shorting, clean armature with emery paper, fit new carbons, refit motor and belt, test.
If it still does not work, then in all probability it will have blown the main control board.which would require replacing.
Dec 23, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Machine fuses house RCD if a drying cycle is selected
Suggest you turn the power off, remove the top cover, diconnect the live and neutral connections to the dryer element (likely to be two of each flavour of connection if the machine has high and low dry settings). Pop a bit of insulating tape around the wire ends so you don't short anything out. Now try to put the machine through a drying cycle. If it works (albeit cold) without tripping the house power, you need a new dryer element. If the house power still trips, turn the power off again and without reconnecting the element wires, disconnect and tape the live and neutral wires from the blower motor. Again, try to run a drying cycle. If this stops the house power tripping, then it looks like a motor problem (though this would be quite unusual). If the house power still trips, you need to have a careful look at all the wiring between the main timer, the dryer timer, any hi/lo heat switch, the blower motor and the element with its associated thermostats and thermal cutouts (all located near the element on the air duct). Look in particular for chafes where wires go round corners, and where wiring crosses from the case to the suspended machinery in the middle of the machine. Pop any follow-on queries in the comments section of this question - I'll keep half an eye on it. A.
May 19, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
