Question about Hotpoint Aquarius WF000 Front Load Washer
Aquarius Hotpoint.. keeps doing rewash after rewash.. door won't open when i switched the washer off its like its trying to either empty water, but making a noise when its trying it.. what wrong and can it be fixed easily
  • 716 Answers
Unplug First!!!!
You Can Pry The Top Off With A Big Flat Head Screw Driver Where The Seam Meets The Casing.
Then You Can Check The Belt Thats What Is Most Likely Your Problem. Take The Broken Belt To Your Local Auto Part Store And Tell Them you Want One That Size And Replace.
Posted on Jan 14, 2009
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint aquarius wma58 1400. Full of washinh. Full of water.
pull your washer out. put near door if poss then put the waste pipe down to floor level to empty the water. if there is to much water in the drum it will not spin try your pump
Jun 21, 2009 | Washing Machines
Hotpoint Aquarius wf320 door won't open.
what you need to do is say 'abracadabra' 3 times , then swear allegience to the queen always remembering Glasgow Rangers are the best ..hee hee
May 04, 2009 | Hotpoint Aquarius WF000 Front Load Washer
On and off light and energy save and reduces creases lights flash
Hi Snarey, it sound like your door lock has passed away, you will need to make sure the appliance is unpluged, empty the water out of the drum, and check the vacuum switch which opperates the lock.
Mar 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Why do the lights just keep flashing?
Try unplugging it and rubbing the plug on a soft dry cloth, static electricity can cause problems.
Try opening and closing door acouple of times, if still no luck , suggest you call engineer
Dec 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Door won't open
Usual reason for this is not emptied correctly. The filter on this model is in an awkward place so try lowering drain hose into a bowl to check if water still in.
Nov 11, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Wd63 door
The main cause with this model is water still in machine. Try a spin and look for water in drum. To empty manually lower drain hose into bowl untill empty. Door should then open.
Nov 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF000 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
