Question about Nintendo DS Lite Console
Nintendo ds lite
I have a nintendo ds lite and bought after market parts to fix it but in the process of putting it back together broke the wifi antenna would this cause the system not to come on if the wifi antenna or wifi board is left out if so can I soldier the antenna to the wifi board?
Doubtful, though I've not had one with a gimped antenna so I can't say for sure...
Probability is very high that failure to start is related to the ribbon cable(s) not being seated properly into the connector(s). This is a common issue during re-assembly. Often, these cables LOOK like they are re-seated properly - but they are not.
First suspect is the ribbon cable that passes through the hinge. Where it connects into the top board is where I encounter problems often. If this cable is not seated deeply enough into the connector - and perfectly perpendicular - your reassembled DS will NOT boot.
I always temporarily snap everything together and test boot prior to screwing everything back together. Even with care and experience I have to go back to this connector and re-seat the cable about 1 out of every 2 times.
Good luck...
Posted on Jan 14, 2009
Nintendo ds lite keeps shutting off
you probably have a power shortage when you move the screen. the only way to fix this is to open the ds, make sure everything is in the right place, and put it back together. i cant promise this will work, but it should.
Jan 13, 2010 | Nintendo DS Lite Console
My nintendo wont turn on what do i do
If you get no power at all, then you likely have a blow F1 or F2 internal fuse. This can be repaired by Nintendo. You can also do this yourself IF you are good at taking things apart and putting them back together. Don't take this undertaking lightly as the DS Lite can easily be damaged further if you don't know what you are doing. However there are many tutorials that can be found by using google to guide you through the process.
Dec 29, 2009 | Nintendo DS Lite Console
Where is NINTENDO DS Lite code located?
it should have been on the bottom of the DS, check maby your kids took it off, or contact NINTENDO
Oct 16, 2009 | Nintendo DS Lite Console
Nds lite wont turn on
if you have another nds lite try switching batterys if that dont work then its broke, sorry.
Sep 21, 2009 | Nintendo FOR NINTENDO DS LITE NDS AIRFOAM...
Nintendo ds lite wont charge or power on.
i think ur problem can be solved on utube. for ex, the parts that u bought. some people show those and they fix their DS with them. this is good since it is in video and u can follow the steps at home .too.
Jan 24, 2009 | Nintendo DS Lite Console
Nintendo DS Lite
If you want get some tools and take the ds apart.make sure all the pieces are straight and are put together right.if there not straight,make them straight.if there not put together,put them back together.Hope it works.
May 23, 2008 | Nintendo DS Lite Console
Nintendo DS Lite top screen broke on one side
The only way you can repair this properly is to replace the casing with a new one... the hinge is a common problem and over 90% of my customers on the DS and DS Lite need a new case due to broken hinges. Once the plastic bit has broken then it will only get worse. The small bit that you say fell out was the actual hinge itself (a small black part with a silver end that twists and locks your console into place when open). Hope that helps!
Aug 21, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
60 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
