Question about Sharp LC-19SB25U 19 in. LCD HDTV
The tv is blank and has sound
You can change channels and raise volume. you can not see anything even when you push menu.
  • 2 more comments
  • Anonymous Feb 01, 2009
    didnt work..do i hold the power button on the tv or the remote?
  • Anonymous Feb 18, 2009
    cant see but i can hear my xbox when i turn it on
  • Anonymous Mar 10, 2009
    No picture, but have sound, solution didn't work.
  • frmmm Apr 07, 2009
    I have sound but no picture
  • 716 Answers
Try Unplugging The Tv And Holding On/Off For 30 Seconds Then Release And Plug It Back In. This Will Confirm If Its The Settings Or Not.
Posted on Jan 14, 2009
How can I change to channel 3 to view cable?
The TV has no manual channel change buttons on it? I have never seen this on any TV ever.
Mar 19, 2016 | Sylvania 6513DF 13" TV/DVD
I just switched to an HD receiver. The sound on the HD Channels is lower than the sound on the regular channels. How can I fix this? Dishnetwork has aready checked their end.
Some Sanyo TV's have a feature called Dynamic volume, this feature can be enabled by just pressing the dynamic volume button on the factory remote. We happen to offer a similar feature called volume leveling on our VIP 722k, 612, and 222k receivers. This is a recently released feature that will keep the volume even, during commercials or when changing channels. To access this press menu 6-1-6 and select enable under volume leveling.
Daniel Busa
DISH Network
Customer Service
Oct 03, 2010 | Sanyo DP37647 37 in. LCD TV
The sound level keeps going back to zero when you raise it. can it be reset on 32GT60
check your menu by pushing menu on your remote ,go to the sound/audio settings see if there is a auto volume level . if so, set it to about 60%. yoou should then be able to lower and raise the volume. if this doen't solve it call for service.
Apr 21, 2010 | GE 32GT660 32" TV
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Low volume output and very low volume when digital broadcast
if you are using a digital converter along with a standard tv , you have one volume level low making the unbalance sound a humming sound, if it is directlly into your tv, check your settings on your tv bass, trebile, by the sound of it you probably have a digital converter , if this is so, raise the volume of your TV to mid point that raise /lower your volume on the converter and it should be fine, also make sure your ouput channel is not the same as your broadcast channel in your area, example,,if your area uses channel 3 for broadcast, set your rf output to chann 4 , and vice versa.
Aug 21, 2009 | Televison & Video
Philips 21RF vardaan there is no sound but everything works fine
just open the service manual & change the option to 1-128 ,2- 215 , 3- 065 , 4- 000 , 5- 192 , 6- 129 , 7- 112
By-Rajan
Jul 01, 2009 | Philips 32PW6506 32" TV
Concierge Hotel TV - Volume Control
If there are no chasis numbers on the outside you may want to open the cast and check for numbers there. Then you might be able to google the number and find a manual. some TV's willl enter the menu or rest by pushing two buttons at once on the set. This could change your channel selection however.
Nov 14, 2008 | Televison & Video
Demo mode
Try pressing the vol up and vol down buttons on the tv at the same time(not on the remote)
Sep 09, 2006 | Philips Magnavox MT1905B 19" TV
Sharp LC-19SB25U 19 in. LCD HDTV Logo
175 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
