Question about Microsoft Windows XP Professional for PC
How to remove a second installation of a windows o/s
I recently installed Windows XP Home Edition on my pc and now I have 2 o/s - Windows XP Home and Windows XP Professional. I want to remove Pro. I have the instructions, but how do I know both o/s are on the same partition? When I boot up, both are listed in the boot menu with Home being the first one highlighted and the one I want to keep. Does that mean they're both on the same partition? Instructions say to find the Windows folder I want to remove in Windows Explorer. I have 2 Windows folders - one in the 'c' drive and one in the 'd' drive. Is the one in the 'd' drive the one I remove? If both o/s are on the same partition, does that mean that both o/s are on the 'c' drive? If so, what is the Windows folder in the 'd' drive? Also, if I remove the Windows folder in the 'd' drive, does that mean I lose all of my files in the 'd' drive too?
    President:
  • 2,961 Answers
You would not have been able to install xp home over xp pro as pro is an upgrade from home, so xp pro will be on a different drive partition, so the last version you put on will be on the 'C' drive as thats the one that is bootable. Follow your instructions, or simply use your xp disc to format the drive and install XP home.
Posted on Jun 13, 2007
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
Microsoft Windows XP Home Edition
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
I have a problem with my PC: When I try to turn off the windows XP home edition SP3 the pc don't stop he restart, but i think the HDD C: where windows is install stop and then restart all sistem (like in...
It Seems Some System Files are Corrupted or Deleted By Antivirus Application in the Process of Removing Virus from your System ....
Method 1:
1. Put your Windows XP CD in your CD-Drive
2. Open RUN Dialogue Box From Start Menu
3. Type "SFC /SCANNOW" -- Copy and Paste the Command exactly
With out Quotes
4. Wait Until It Completes everything...
5.Restart and Check your Problem ....
Method 2:
1.Login to your Windows XP
2. Put your Windows XP Home CD in your CD-Drive
3. Click Install Windows XP From Autorun Window.Start Windows XP Autorun Screen if its not opened, by Clicking on the Windows XP CD Drive icon under your My Computer ...
4.Select Same Drive as your Windows XP Now Installed then Select Upgrade Method to Install...
5.Complete Installation and Restart your System ...
Note: in Upgrade You'll never lost your Installed Programs and Files ...
Feb 20, 2010 | Microsoft Windows XP Home Edition
I have recently had to reinstall windows xp on my pc but it wont accept my product id code for the install and finish off the instalation
HI,
THIS A PROBLEM WITH URS PRODUCT ID ,,
IT WOULD BE A IMPROPER SERIAL KEY WHICH U R TYPING,
VERIFY THE SERIAL KEY ,,,,
ELSE U HAVE TAKEN A PIRATED WINDOWS XP EDITION
TNKS
RABBANEES
Nov 12, 2009 | Microsoft Windows XP Home Edition
Occasionally I receive a message when I am trying to download or install a programme etc. The message tells me to insert the Windows XP Home Edition disc? The problem is that my PC was purchased (from PC...
I think you have these options:-
1. Explain your problem to PC World and see if they can help.
2. Borrow a Windows XP Home Edition disc from a friend.
3. Download a Windows XP Home Edition disc from the internet. I don't know how legal this is, but as you have already got the legal copy installed and are only using the disc to install other programs you might be OK.
Oct 30, 2009 | Microsoft Windows XP Home Edition
I need to repair windows xp home edition
u need to install foxit redaer in your pc or u need to intall adobe acrobet reader in your pc here u can download acrobet reader & install in your system acrobet reader
Jan 16, 2009 | Microsoft Windows XP Home Edition
Help me..whats going on with windows xp home edition
When installing a new operating system, all file saved will be deleted. Since you've lost all data, you might as well format the entire drive, and then reinstall the vista inspirat thing. Then, download an Avast! anti virus form avast.com. Download the home version, which is free and scan the computer for any viruses. Delete every last one of the suckers.
Jul 03, 2008 | Microsoft Windows XP Home Edition
Windows Xp Home edition Installation
Hi tross202;
Is that an original XP home edition installer? You may try another cd installer if you can secure one.
Jun 01, 2008 | HP Compaq Presario SR1420nx...
Acer Aspire T180 PC Desktop
if you have windows 98 boot disk put that in, the firt thing you do is to go to f-disk and change the partions in it, then format c: drive. take out disk in A drive put in New windows XP CD and restart. the disk will run and install itself. and thats it. right now your partions are set to read only windows 95, 98, there are 2 options to choose from I belive the one you need is 32.
Dec 17, 2007 | Acer Aspire™ T180 PC Desktop
Multiple windows XP OS removal on an LG P1-J211E1 laptop
I take it your solution to this problem was to reformat and reinstall the operating system based on your more recent question here: http://www.fixya.com/support/t162859-formatting_laptops_c_drive. If you still need assistance with this one let us know.
Aug 01, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional for PC Logo
193 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
