Question about HP PSC 950 All-In-One InkJet Printer
I have a hp psc 950 printer fax scanner and cpier but the display screen keeps saying (door open) and the 2nd line is written (close print cartiridge access door) everything is closed i dont know what is going on
  • Anonymous Jan 15, 2009
    1. i have hp psc 950 printer fax scanner copy but before i used xp now i changed to vista but fax scanner and copy dose not work what can i do can you help
    President:
  • 2,692 Answers
First user Look atFAQ
http://h10025.www1.hp.com/ewfrf/wc/product?product=60259&lc=en&cc=us&dlc=en〈=en&cc=us
Second user download and insatll VISTA drivers.
Posted on Jan 17, 2009
Problem with printer or ink system
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
Dec 28, 2015 | HP Officejet 6600 e-All-in-One -...
Hp 2210 all-in-one printer fax copier scanner-keeps saying remove door and remove paper jam and there is no paper jam. How do i clear this?
You can't I have the same printer and it is the stubbornest thing in the world. Just hit enter and keep printing.
Nov 18, 2009 | HP PSC 2210 All-In-One InkJet Printer
My problem is with the HP PSC 950 series printer, fax, scanner, copier. The fax and copier work sporatically, sometimes producing a copy or fax and most times not. Please help
faxing,scanning and copying use the same mechanism,thts the scanner,if its doing it intermittently you can try a reset on the printer.see if tht works.
Jun 24, 2009 | HP PSC 950 All-In-One InkJet Printer
Message sez
Check this out. See if it helps...http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu00657&cc=us&lc=en&dlc=en&product=422000
Jun 09, 2009 | HP PSC 2355 All-In-One InkJet Printer
Have no manual; need help using scanner and fax
Here is the link given to the user manual. that contains the optimum solution to your problem and maximum guidance.
http://www.devicemanuals.com/guide/All-in-One%20Products/HP/HP-PSC-950-All-in-One-Owners-Manual-==TVRFME56VTI=.html
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=18972&prodSeriesId=34579
May 27, 2009 | HP PSC 950 All-In-One InkJet Printer
Is wireless operation possible
hoow do i send a fax with an hp psc 950 combination printer, fax, scanner and copier machine?
Jan 13, 2009 | HP PSC 950 All-In-One InkJet Printer
HELLO...WE HAVE AN HP PSC 950 PRINTER, COPIER, SCANNER , FAX AND IT PRINTS SUPER SLOW...THIS HAPPENED BEFORE AND I PUSHED A BUTTON TO CORRECT THE PROBLEM BUT IM NOT HAVING THE SAME LUCK THIS TIME...HELP!!
I would seem the quality is set to high instead of normal or draft (even faster). Right-click on the printer in the Printers and Faxes folder and select Properties. Under Printing Preferences you can set the default quality. When printing photos you can override this setting.
Dec 30, 2008 | HP PSC 950 All-In-One InkJet Printer
I have a hp psc 950 all in one printer, and it says press enter to align cartridges. I've did everything. Where can i go to get another cd to redownload everything? I misplaced the download cd.
If this is the message being displayed on the Computer, open the HP Solution Center/Director, Click on Settings, Print Settings, Printer tool box and then search for the Print Diagnostic report option. After the diagnostic report is printed, restart the printer and check if the same message is appearing again.
Dec 05, 2008 | HP PSC 950 All-In-One InkJet Printer
Hp psc 950
see
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=Hp+psc+950&submit.x=5&submit.y=10
Choose the correct product and the manuals and setup instructions are in the column on the left
I believe this should help.
Dec 08, 2007 | HP PSC 950 All-In-One InkJet Printer
HP PSC 950 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
