Question about Garmin nuvi 205W GPS Receiver
Garmin 205w wont find satellites
I just barely started using my new nuvi about 2 weeks ago and just recently i tried to get directions somewhere and it cant find satellites no matter where i go . right now im trying to put in a new addy and its stuck at the previous map from before where i had no satellites. is there a way to reset or to fix it?
    New Friend:
  • 9 Answers
Hi, Please check to make sure the GPS is set to USA and your time zone etc do this in the tools menu, then see if it will load the map.
check for updates @ "my.garmin.com"
you can also download a manual at garmin.com if needed.
Make sure you are clear nearby buildings, depends on satellites currently visible, and the length of time your GPS has been on.these may have an affect on getting a satellite signal but mostly they are suppose work just fine.
You may need a car adapter with a reciever in it.they cost about $119.00 at bestbuy. ouch! e know if this helped at all.
I would try to exchange it for a new one, it hasnt been that long that you have it.
Hope this helps, let me know what happened. good luck!
Posted on Jan 14, 2009
I baught a nuvi 255w but the SD card has no data in it, where i can download it cheapest or free please.
The following is the nuMaps Guarantee on page 8 of the nuvi 205W series quick start manual that would have come enclosed in the packaging of your recently bought nuvi 255W...
nuMaps Guarantee
To receive one free map update, register your nuvi at http:/my.garmin.com within 60 days of acquiring satellites. For more information, go to www.garmin.com/numaps
Apr 11, 2011 | Garmin nuvi 255W GPS Receiver
Tip
How to Perform a WebUpdate of the Garmin Nuvi 205 and 205W System Software
Does your Garmin Nuvi 205 or 205W get stuck or freeze at startup or when loading maps?
One trick to try when your GPS is acting up is to perform a Hard Reset.
Occasionally, your GPS may not start properly at all, and display a 'System Software Missing" message. Today's tip will describe how to restore your Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your PC and update the system software of your GPS.
Your Garmin Nuvi should be running as good as new.
on Jan 17, 2010 | Garmin nuvi 205 GPS Receiver
First time using my garmin 205W and it only holds satelite service for about 10 minutes
I recommend you replace the firmware and system software using webupdate. Updates in the Nuvi 205 firmware has increased its satellite reception and accuracy.
I hope that helps.
Apr 01, 2010 | Garmin nuvi 205W GPS Receiver
Garmin Nuvi 205w and now it wont turn on.
You can restore the Nuvi 205 system software to its factory condition by running Garmin's WebUpdater service. You may also want to try a hard reset of your Nuvi.
I hope that helps.
Dec 28, 2009 | Garmin nuvi 205W GPS Receiver
My Garmin nuvi 205w turns itself off. I switch it on, fully charged, and go through steps, first screen loading maps, press "agree" on next screen, picked address (recently found), map comes up with...
Sounds like your battery is getting weak.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility probably at Garmin.com. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Nov 17, 2009 | Garmin nuvi 205W GPS Receiver
Garmin nuvi 205w CAN'T UNLOCK MAPS don't have codes it is used...
You are out of luck. Garmin will only talk to and assist registered owners. The registered owner has to deregister the device before a new owner register it and update the maps.
Mar 17, 2017 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi not acquiring satellite
I am having the same problem with my nuvi 350 and its about the same age. I read on another post it may need a new battery but you need to send it to garmin. I am going to contact garmin directly.
Aug 20, 2009 | Garmin nuvi 350 GPS Receiver
How do i register my garmim nuvi 205w
This may be a repeat message. I am a Senior Citizen, not to bright with these systems. Can you help me Register my new garmin 205WT and find out how to down load most recent data.
Purchased today at Curry's
Thank you in advance
Ernest
Jan 17, 2009 | Garmin nuvi 205W GPS Receiver
Unable to register garmin nuvi 205w series on line this product number does not appear on the list
I just registered my 205W two days ago; the model number may not be in numerical sequence in the drop-down list, however (I don't recall). But it's there somewhere.
Dec 30, 2008 | Garmin nuvi 205W GPS Receiver
Garmin 205 w - I cant connect usb driver .I need the driver
you have to download a third party software to upload the maps, I used GPSsendmap, can be obtained free from cGPSmapper.com.
Just download sendMap20 rev. 6.0 for windows. It works.
Dec 27, 2008 | Garmin nuvi 205W GPS Receiver
Garmin nuvi 205W GPS Receiver Logo
469 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
