Question about EliteGroup P4VMM2 Motherboard
Usb for P4VMM2
My usb ports got screwed. non of them work, is there anything i can do other than installing a new usb card(pci). a faulty usb devise caused the problem.
  • jofp joef Feb 19, 2008
    i also have a problem regarding my USB... my board is also P4VMM2
    before i reformatted my pc, everything (all devices) were doing fine.. but after the reformat and installation of winXP there is no USB being detected, no USB controller can be found in the device manager... is it the same with kalp's problem?
    thank you!
I alsa have a problem regarding my USB... my board is also P4VMM2
thank you!
Posted on Feb 19, 2008
  • 125 Answers
USB is powered by a current limited 5.0 volts supply. Normally even if there is a short circuit, the port is well protected but if a higher voltage is applied from outside (defetive USB device) the port can be damaged. There is a very small fuse or fusible resistor in the PCB. Unless it is burned, it is difficult to find. You can try to look near the area of the USB socket. If you were lucky enough to find it, you can replace it. Another possible solution - connect a USB hub with external power supply to one of the USB ports in your PC. If the datalines of our internal USB is still OK, then you can use this HUB. The power will come from the externel supply. Connect the USB devices on the hub and not on the PC.
Posted on Jun 13, 2007
Good day! just want to know how can i have sata connection with my p4vmm2?
You can use a sata controller card similar to this one.
That will fit in one of the PCI Slots (white)
You can purchase them with 2,4,6, and 8 sata ports.
Mar 01, 2011 | EliteGroup P4VMM2 Motherboard
just plug the card and insert the cd and install it...
May 30, 2008 | Televison & Video
Lost install instructions for Hi-speed usb 2.0 5-port PCI card.
The drivers are here. You shouldn't need to do anything to install the card other than plug it into a PCI slot in your computer and install the drivers.
Hope this helps. Thanks for using Fixya!
Feb 19, 2010 | Belkin Hi-speed USB 2.0 5-Port PCI Card [...
I am using an older PC with a ASUS CUSL2 AGP Pro/4X Motherboard as a intra-offfice server devise. I'd like to add USB 2.o or change out the 2 rear USB prots to 2.0. I've tried doing this witha USB 2.0 PCI...
You have two options
One is to replace the whole motherboard but that would probably also entail new ram, cpu, cooler, graphics card, even maybe a new PSU.
Two is to fit a pci usb 2.0 card.
You said you did TWO but it didnt work. I am not sure why without more details but if you are using windoes 95 or less than that would be a major problem.
Only the later windows 98 and above can really make full use of USB 2.0 and even with 98 and win ME you would need to make sure he correct drivers were installed too.
Nov 09, 2009 | ASUS Intel 815E Chipset CUSL2 Motherboard
How difficult is it to put in a new USB root hub in an EMachine W3622
Quite easy buy one from fry's online a 4 port pci slot type and remove the two screws on one side pull the safety plate off the PCI slot off the case and install the PCI card into the mother board and install screw and run the DVD to make the usb ports work and pt lid back on and your set to go.
Jun 19, 2009 | Logitech QuickCam Express 5-Pack Personal...
Onboard LAN detected , drivers properly installed but not responding
The Problem is in your onboard LAN, get PCI LAN card, plug into your PCI slot, install the driver of that PCI LAN Card..
Apr 27, 2009 | Computers & Internet
ASUS P4SDX USB Ports not recognized as USB2 HS Ports
The message comes up when a USB 2 device is connected to a slower USB 1 or 1.1 port. It is only to advise you that the devise will operate faster on a USB 2 port. If your computer has only USB 1 or 1.1 ports, you will always see the message. You can buy and install a card with USB 2 ports and install it. It will come with the USB 2 drivers. Install the card and the drivers and then connect your USB 2 device to the new hardware and you should not see the message anymore.
Good luck, And let me know ho it works out for you.
~ Spoem
Mar 30, 2009 | ASUS P4SDX Motherboard
All USB ports dead....
Try removing the PCI USB Adaptor and clean the gold contact with dry brush, then place it back again. If this still doesn't work, try moving the PCI USB Adaptor into other available PCI slot.
I hope this procedure solves your problem.
Jun 11, 2008 | Gateway GT5228 PC Desktop
Black screen
To view the pictures on the computer, remove the card from the battery compartment and put it in a card reader connected to your computer.
Jan 17, 2008 | Canon PowerShot A540 Digital Camera
USB port malfunction?
Oh God i have the same exact problem. I run XP Pro and USB ports all malfunctioned, after tyring EVERYTHING I reloaded windows and it worked.......for about 8 months, now I'm back to I can't use my printer, storage devices ANYTHING that plugs into the USB ports. I'm at my wits end. I'm thinking of throwing the compter out the window
Jan 12, 2008 | Computers & Internet
EliteGroup P4VMM2 Motherboard Logo
282 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
