Question about Maxtor One Touch II (EO1E200) 200 GB Hard Drive
Windows-virtual memory minimum too low
Hello,,what are the problems associated with this warning?
will extra ram overcome the problem?
is the pc life reduced because of the virtual memory problem?
  • 716 Answers
Not Necessarily Not Enough Drive Its Your Virtual Memory May Just Be Set Low. Go To Your Start Menu And Right Click On It Scroll Down To Properties and Click It. Then Once The Prompt Box Pops Up Select The Advanced Tab. Your Gonna Wanna Locate The Performance Settings Button And Click It. Now Select The Advanced Tab And Go Down To Where It Says Virtual Memory, Click Change Up The Number Mines At 384 top and 1500 bottom. Now Click Set After Changing The Numbers And Select Ok,Ok,Ok On All Three Tabs. This Will Do It
Posted on Jan 14, 2009
My pc is running low on virtual memory when i use the internet
In general, you want to set your minimum virtual memory to about 3 times the total amount of memory installed in the machine.(3072MB for each gig of ram) The maximum should be 4096 more than the minimum setting.
To check this, right-click on "My Computer" and choose "Properties". Click on the "Advanced" tab and click the "Settings" button in the "Performance" section. On the "Performance Options" panel, click the "Advanced" tab. The virtual memory button is at the bottom (on xp machines). Selcect "custom" and then set the values according to how much ram you have in the machine. For more, check here.
http://www.thermwood.com/forums/viewtopic.php?f=3&t=897&hilit=virtual+memory
Oct 08, 2011 | Computers & Internet
Tip
Virtual Memory too low Warning Trouble in win xp and vista
When there is less physical memory than needed, then some virtual memory (virtual RAM) is created on the disk. When there is a limit set to the size of virtual memory usage and there is not enough of it present there is a warning that frequently comes "Virtual Memory too low". Solution 1 : This problem occurs when physical RAM + Virtual RAM (usually created on hard disk) together are not sufficient to take care of the currently needed RAM size, or this situation is about to arise. This usually happens when some fixed upper limit for Virtual Memory has been set. To solve this problem, you can either upgrade you physical RAM on your computer (recommended), or you can set the Virtual Memory to system managed size or you can do both. Setting Virtual Memory to system managed size means windows will set it to higher size whenever needed automatically,for this, <br /> Right click on My computer --&gt; goto properties, goto advanced tab, click on performance settings, now click on advanced, now click on advanced, now click on change button for Virtual memory. <br /> On this screen select the System managed size, press OK. After this re-start your computer. This will solve the virtual memory too low problem. Solution 2: Recommended solution is to upgrade your physical memory (RAM) according to requirements of the kind of applications that you run on your computer. If you upgrade RAM or not, the following procedure will help prevent this warning by increasing the virtual memory limit. <br /> Right click on My computer icon and click properties. <br /> This will show system properties window. Click on a advanced tab and click on the settings button under heading performance. This will open performance options window. Click on advanced tab and click on change button under heading virtual memory. Check if the space available is set to some custom value or double the RAM size ? If it is not double the RAM memory size , then select the size option set the virtual memory size double the RAM Size and press set button and press OK button. Restart the computer
on Apr 04, 2011 | Computers & Internet
When i playing online games on my computer it shows a massage of virtual memory low....and the system go to hang.....hw can i solve ths problem...
Virual memory is an area on the Hardrive that "acts" like memory when your RAM gets too full
If your gaming--its better to increase RAM -but here is how to increase the Virtual memory
Go to START> right-click on MY COMPUTER>PROPERTIES>ADVANCED click on SETTINGS under the Performance area-- then click the ADVANCED tab -and you should see an area to change(increase) your Virtual Memory
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this.
Jan 05, 2011 | Computers & Internet
My system says, (RAM) radon access memory low cpu intel (r) pentium 4 cpu, version 2.80 ghz. RAM 256 mb. What can I do to resolve this problem. Dell 4700 dimension
Windows XP requires a "bare-minimum" of 128MB of RAM, works "OK" with your 256MB of RAM, if you don't open too many programs at the same time, and if you close/re-open Internet Explorer about once an hour of usage.
But, Windows XP would be _much_ "happier" if you added 256MB or 512MB of RAM, because it is telling you ("available random access memory is low") that it is using all the RAM.
Add more RAM -- your computer will run much better.
Jun 15, 2010 | Dell Dimension 4700 PC Desktop
At power up get messge "virtual memory minimum too low". Ho wdo I correct that?
Start, programs, accessories,system tools, Defragment, it may take hours to defrag if you haven't been doing it. Also run a registry clener if you have one,
Mar 07, 2009 | Computers & Internet
My acer aspire 5600 warned that I am running out of memory. My "D" drive says there is 30g of free space. How do I use it?
I think the computer actually said you were running low on Virtual Memory ... memory is the physical ram installed in your machine ... virtual memory is an area of hard drive the computer uses to store data when in runs out of "real" memory .....hard drive space is nothing to do with memory.
Ok, that got that cleared up :-) .... now the quickest way to get over low virtual memory problems is to install more RAM. For XP you should really have a minimum of 512mb .... 1gb is probably optimum. For Vista you should really have a minimum of 2gb.
So if your laptop has less than 512mb(xp) or 2gb(vista), the first thing to do would be to upgrade the memory.
Virtual memory problems should only ever crop up when you are running multiple applications .... so just try and keep the amount of programs you have running to a minimum. Instead of just minimizing programs, try to close them down to save memory.
Jan 01, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Windows Virtual Memory Minimum is Low
fairly normal occurrence but you should have a look at your performance settings
go to control panel
double click system icon
click the advanced tab at the top
by performance click settings
in pop up window click advanced tab
at the bottom you'll see virtual memory
click change
most common option now is to set the radio button to system managed size
you should then ok each window.....
Dec 30, 2008 | HP Pavilion a620n (PC028A) PC Desktop
I have an IBM thinkpad T20 running windows 2000. The computer is on and booted up but the monitor is not lighting up. It is running on 256mb ram and I was getting a lot of virtual memory is low warnings...
To determine if the laptop has a problem with the inverter of low virtual memory issues, plug an external monitor in to the laptop and you can change the virtual memory by following these instructions, right click on my computer, select properties, then select advanced, click on virtual memory and change the settings to system detemined, save settings and reboot the laptop without the external monitor to see if it is virtual memory or inverter.
Please keep me informed
kind regards and please don't forget to rate us
Dec 03, 2008 | Computers & Internet
Virtual Memory error
Dear
Right click on My Computer icon .. go to Properties->Advanced->Setting->advanced->Change..
THan Select Drive go to Custum Size Fill Minimum an Meximum virtual ram size remember u fill double ammount to ur actual ram size like 512-1024
Click Set ok  and restat ur pc
Oct 19, 2008 | Computers & Internet
I get the warning virtual memory minimum too low how do i fix this
Very simple .just goto control panel >Double click on system >Select Advance tab >Under Performance tab click on Settings >Select Advanced >Under Virtual Memory tab click on Change,
Now select custom radio button
Now you will some thing like this
Initial size(MB) = 768
Maximum size -1024
Now here comes the main point and to enter proper values under Initial size (MB) =
and Maximum size =
suppose your ram is of 512 mb than initial size will be
Initial size = 768 ( 512 * 1.5 = 768)
Maximum size = 2304 ( 512 * 1.5 * 3 = 2304)
just enter the values according to calculation and your problem is solved ..if you want you can increase more 'Maximum size' value for faster system optimization .
_____________________________________________________
Was this solution helpful .Show your appreciation by rating it.
dilipbagdi - Technical Associate
Jun 08, 2008 | Computers & Internet
Open Questions:
Maxtor One Touch II (EO1E200) 200 GB Hard Drive Logo
430 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
