Question about D-Link DPR1260 Rangebooster G Multifunction Print Server (790069283475) Print Server
I am trying to install D-LINK. have tried many times and failed.
I have windows vista on my laptop. i want install the d-link wirleless printer server to an hp officejet 5600 all in one printer. i have hooked the ethenert line from the d-link to a att 2-wire-gateway wireless router,,i am probley all wet but that where i am at. help
  • 728 Answers
Hi unioncharlie,
What you've done so far is fine, next connect the printer to the d-link with a wire, and allow the d-link to recongize the printer. Once that's done, you'll need to log into the d-link and get the IP address that it's assigned the printer. Then on your laptop, add a new printer and assign a new port using an IP address port, and put in the IP number you got from d-link, and the laptop should find it. Once that's all done, you can disconnect the wire from the printer to the d-link, and everything should still see each other. If not then you've got some settings either on the d-link or the laptop wrong. That printer acts just as a pass through for IP assignment.
Good Luck,
Mark
Posted on Jan 14, 2009
WPSM54G linksys printer server software does not install on windows 7. Need a driver.
win 7 has some problems with networking equipment. there is a method for installing the wpsm54 on vista and win 7. go to this link it has a good clear set of directions. good luck, aokcomputer
http://www.ehow.com/how_5396340_set-vista-vista-windows-linux.html
Jul 23, 2010 | Linksys WPSM54G Print Server
Vista cannot connect to xp printer
It sounds like your are using your Windows XP computer as the print server, and you are trying to connect your Windows Vista machine to the Windows XP print server. Your Vista machine is trying to download the XP drivers from the Windows XP computer to your Vista machine. This won't work. Windows XP and Vista print drivers are not compatible.
If the printer is truely networked (it has it's own IP address on the network, it has its own ethernet connection). Then instead of trying to map out to this shared printer, add new printer to the Vista machine using Vista drivers for the HP Deskjet 3940. The type of port you would need is a standard TCP/IP port. To get this address, print a settings page from the printer. Look for either a TCP/IP address or IP address on this print out. This is the port address you want to create and then connect to.
May 04, 2009 | HP Computers & Internet
Need to print from Vista 64 bit laptop - no drivers.
try this link http://esupport.sharp.at/html/driver/index.php?StartRec=0&ListLimit=10&TemplateLang=nl&Lang=%&ProdLine=34&SortOrder=DESC&OrderBy=Title&OS=%&EMU=%&SearchString=arm207
Apr 14, 2009 | Sharp AR-M207E Black and White Copier
D-Link DP 301U Print Server not continuous print from vista
Make sure you have byte counting enabled if you are printing through LPR.
Dec 11, 2008 | D-Link DP 301U (DP-301U) Print Server
D-Link 301U Printer Server using Windows Vista
As shown here on the Dlink website, there is no support for either Vista 32bit or 64 bit
Hope this helps - remember to rate!
Oct 02, 2008 | D-Link DP-301U (790069251979) Print Server
Can't finish printing first page of wireless print
try updating latest firmware on print server so windows vista could be compatible.
Jun 13, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Vista Compatibility with DI-704P
The print server software does not need to be installed in order to print to the printer attached to the 704P from Vista. I went out to D-LINK's website and there are step-by-step instructions for configuring port 192.168.0.1 and associating a printer with that port.
See the following link:
http://support.dlink.com/faq/print.asp?productid=794
These instructions are for 2000/XP but they are very similiar to what you need to do for Windows Vista. I tried it and it worked fine. It did take me several tries however, as I should have read through the steps completely first.
May 29, 2008 | D-Link DI-704P Router
Linksys WPS54G
Hi Scott.
Make sure your firewall is set on the Vista to allow the network discovery. Follow this link, click on Networking>File and printer sharing. It will tell you how to setup Vista to work with printer
http://windowshelp.microsoft.com/Windows/en-US/networking.mspxsharing.
This link should help, too. It is just for your Printe server.
http://www.experts-exchange.com/OS/Microsoft_Operating_Systems/Windows/Windows_Vista/Q_22960040.html
Good Luck!
Jan 05, 2008 | D-Link DP 300U (DP-300U) Print Server
D-Link DPR1260 Rangebooster G Multifunction Print Server (790069283475) Print Server Logo
662 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
