Question about SanDisk Sansa e260 MP3 Player
Sansa media player e260 deleting files
I can't delete any video files from the mediaplayer in either MTC or MSC modes. In fact in MSC mode, no video files other than the 2 that came with the player appears. I've read the suggestions on your site to fix this, but it seems that to format the player will mean that I will loose everything and I don't know how I can back up the files when I can't even see them? Please help!
    President:
  • 2,559 Answers
Put it in MSC mode,Plug into you computer,open My Computer,(The player will show as a drive)Open up the player,open the folders and delete what you want deleted.Then when you want to add more songs,Open it the same way as above and drag and drop them.You do NOT need to use a media player to load or remove items.And Please rate this solution.
Posted on Jan 14, 2009
  • 54 Answers
Since I'm not to familiar with your device I would suggest it would be best to plug the device in to your computer with its data cable and browse the devices file system for the files you wish to remove. Chances are if the device reads that it has less memory the files are on there but not in the correct file format. Some mp3 players for example require a certain video format and usually the program to translate the videos comes with the device software. If you wish to remove them from the device or simply check to see if they are there, etc. This would be the best way to do that.
  • Sean McGettigan
    Sean McGettigan Jan 14, 2009
    Oh yes because my answer was completely inappropriate and the other answer was totally different right? Way to go.
My device isnt displaying all of the media clips on it?
The Sansa player can hook up to a computer in two different modes. Through normal use it can switch modes on it's own, although rare it can happen. Now stuff added in one mode can not be seen in the other mode and you can not delete the files. So you have MSC mode which means Mass storage class and is the best mode to use. Then MTP mode means Media transfer protocol, you have to use this mode if you use Napster and such to download MP3's with protected content (DRM) you have to set the player to one mode or the other, to see the files and delete the files you want to delete or to find the missing files. MSC makes your player look like a thumb drive, and is easy to use. Another reason you cant see video clips would be due to the extension name of the file. or the type of file it is. The Sansa players can see AVI, MPEG-4 (mp4) video types. If you have a fla video loaded on the player can not see it.,
Jun 22, 2010 | SanDisk Sansa c240 MP3 Player
Delete songs from mp3
1) Go to Settings/USB Mode and change to MSC mode which make it works as a flash drive/memory stick 2) In Windows explorer, you should see two drives in My Computer, one for the unit, one for the card slo 3) As for a 'normal' PC, you can now just delete any files/songs from your Sansa directories in either drives! (you can also move existing or add new files). note: if your normally use SanDisk Media Converter program or Windows Media Player, you must change the USB mode setting on your Sansa back to 'MTP' before those programs can see your device.
Dec 20, 2009 | SanDisk Sansa e260 MP3 Player
Sansa E260- Cannot delete songs/ won't respond to modified files.
In order to sync the files with media player the device must be in MTP mode MSC mode is used for drag/drop file updating. try setting MTP and then sync it or just open the drive file in my computer in either mode to update the file list.
Apr 11, 2009 | SanDisk Sansa e260 MP3 Player
Can't delete video files from Sansa MP3 player
There's actually another mode, MTP. Files in this mode won't show up in the other mode.
Jan 16, 2009 | SanDisk Sansa e260 MP3 Player
RCA Pearl TH1101A Mp3 Player
Hi there.
There are 2 ways to delete songs from your Sansa E260: By browsing the folders containing the songs, or by formatting the player.
To browse the player, it's important to know first that the player has 2 modes: MTP (Media Transfer Protocol) and MSC (Mass Storage1.gif Class). Music files saved on one mode would not be seen in the other mode when browsed through Windows Explorer.
You can switch modes by navigating your E260's menu using the following:
Menu >> Settings >> USB Mode
Next, plug your player in your PC and open Windows Explorer. You should first set your Explorer to "Show hidden Files1.gif and Folders" by going to the "Tools" menu (located on menu lists on Windows Explorer window), then choosing "Folder Options", then enabling the "Show Hidden Files and Folders" radio1.gif button
Deleting Music files under MTP Mode:
1. Your player should appear as a Sansa E260 icon in Explorer as a "Portable Audio Device". Double left-click this icon to browse the player.
2. You'll find a "PPI NAND" sub-folder. Again, double left-click on this sub-folder.
3. You'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it.
4. Your music should appear as individual files or folders. Delete this to remove the file(s) from the player
1. Your player should appear as a Drive letter and entitled either as a "Removable Drive" or as "Sansa E260"
2. Double left-click on this drive letter to browse the player
3. You may find your music files immediately on this folder, or you'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it and view your music files.
4. Delete the music files you want, and they should be removed from the player
Deleting files through Format:
1. Formatting the player erases all files in the player, and oftentimes this is the best option to ensure that all files are removed and any corruption eliminated. Also, it is best to format the player when in MSC mode.
2. When the appears as a drive letter (under MSC mode), right-click on that drive letter and select "Format". On the "Format" pop-up window, click "Start" to begin the format process.
3. Follow the on-screen prompts and safely remove the player from your PC when the "Format Complete" display appears.
4. Unplug the player from the PC and when the player is powered up, the message "No Files" should appear on the player's LCD screen
5. Switch the mode back to "MTP", or continue to use "MSC". Note: It is best to use "MTP" when you are transferring subscription music to the player
I hope this helps. :)
Jan 25, 2008 | RCA TH1101 MP3 Player
Can't remove songs from mp3.
if you want to remove ALL songs from you sansa go to my computer right click the icon that refers to your sansa model and click format. this will delete all pictures, videos, voice recordings, preset radio stations, and music. this is the only way i have find to delete music permanently. before doing this make sure you have your files backed up. also you must be in MSC mode to do this.
Jan 01, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260
Dec 31, 2007 | SanDisk Sansa e260 MP3 Player
Deleting songs
I have the e260 4g. To delete songs I use the MSC mode, so I can see the player as a regular windows folder and then select the songs that I want to delete
Just follow the steps as indicated in
How to delete music files from your sansa mp3 player
Dec 08, 2007 | SanDisk Sansa e260 MP3 Player
Cant delete my songs
Cant tell you what to do, but if it were me I would format and start fresh.
Nov 29, 2007 | SanDisk Sansa e260 MP3 Player
How do i delete songs off of my mp3?
Hi there. There are 2 ways to delete songs from your Sansa E260: By browsing the folders containing the songs, or by formatting the player. To browse the player, it's important to know first that the player has 2 modes: MTP (Media Transfer Protocol) and MSC (Mass Storage Class). Music files saved on one mode would not be seen in the other mode when browsed through Windows Explorer. You can switch modes by navigating your E260's menu using the following: Menu >> Settings >> USB Mode Next, plug your player in your PC and open Windows Explorer. You should first set your Explorer to "Show hidden Files and Folders" by going to the "Tools" menu (located on menu lists on Windows Explorer window), then choosing "Folder Options", then enabling the "Show Hidden Files and Folders" radio button Deleting Music files under MTP Mode: 1. Your player should appear as a Sansa E260 icon in Explorer as a "Portable Audio Device". Double left-click this icon to browse the player. 2. You'll find a "PPI NAND" sub-folder. Again, double left-click on this sub-folder. 3. You'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it. 4. Your music should appear as individual files or folders. Delete this to remove the file(s) from the player Deleting Music files under MTP Mode: 1. Your player should appear as a Drive letter and entitled either as a "Removable Drive" or as "Sansa E260" 2. Double left-click on this drive letter to browse the player 3. You may find your music files immediately on this folder, or you'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it and view your music files. 4. Delete the music files you want, and they should be removed from the player Deleting files through Format: 1. Formatting the player erases all files in the player, and oftentimes this is the best option to ensure that all files are removed and any corruption eliminated. Also, it is best to format the player when in MSC mode. 2. When the appears as a drive letter (under MSC mode), right-click on that drive letter and select "Format". On the "Format" pop-up window, click "Start" to begin the format process. 3. Follow the on-screen prompts and safely remove the player from your PC when the "Format Complete" display appears. 4. Unplug the player from the PC and when the player is powered up, the message "No Files" should appear on the player's LCD screen 5. Switch the mode back to "MTP", or continue to use "MSC". Note: It is best to use "MTP" when you are transferring subscription music to the player I hope this helps. :)
Apr 21, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
