Question about Fuji FinePix A345 Digital Camera
I cannot take the picture at all
It turns ON and again turns OFF automatically, I had tried with new batteries also, but still persists same problem. Only I can view the pictures stored in the camera, if i want to take a picture then it turns OFF.
    Problem Solver:
  • 14 Answers
Try turning off your flash, if its possible... then if it persist again, maybe you have an hardware problem inside you camera
Posted on Jan 14, 2009
Tv not turning on
reset the r.control, take out the battery and put again the code and try it.
if the problem persist, clean the contacts battery, and replace by new ones.
clean the keypads. test the remote control with digital cameras or webcan cell see the picture, the LED from r. control must be ON, when you touch any KEY, othewise proceed as indicated above.
Jul 04, 2013 | Televison & Video
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
My camera is shutdown while the lense is out. What to do?
I think the battery is the first thing that you should consider about. Seems like your camera has no power even to make a picture. Have you check the battery power? If the camera got low bat you should charge first and try to turn it on again.
If you have make the battery full but the problem persist, maybe your battery already drop/broken so you need to buy the new one. But if you have a friend who have the same camera as you are, you can borrow his/her battery to check out weather this is battery problem or not.
Hope this help and be kind to rate please.
(^_^)
Jan 08, 2011 | Sony Cybershot DSCW310 Digital Camera
Turns on and won't turn off has a picture of a battery and a flower
Try to push the ON/OFF button longer or harder. If the problem persist, take the batteries off then put in again into your camera.
Picture of battery shows your battery stats full/empty.
Picture of flower is indicator that you use "MACRO" mode, this is mode when you have to take a small picture with near range between object and lens while capturing the picture, not suggested for taking daily pictures. If you don't need this function you can turn off the "MACRO" mode, certain camera have dedicated button to adjust it, but see the manual to make sure.
Hope this help and be kind to rate please, thank you.
(^_^)
Jan 06, 2011 | Cameras
My display screen is blank.why
Ifthe screen of the Camcorder is not working, please follow thetroubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button above the hand strap.
Note: In the above picture, 10 represent the reset button.
If the issue persists again, please perform LCD screen Calibration and check ifthat helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, pleaseremove the battery pack, turn the Power switch to ON for more than 15 seconds,turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps,service is required.
I hope this information will help you to resolve the touch screen issue of theCamcorder.
Dec 04, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
When I turn my Sony Cybershot dsc-p72 on, i am able to view my pictures, but when i try to take a picture the screen is black and it makes a whirring noise. Then the camera turns off automatically. How can...
Confirm if you're using a fully charged Battery with the Camera. Check if you're able to playback the images normally. Then, try to reset the Camera by either pressing the Reset button when the Camera is in ON condition or by removing the Battery and pressing the Power button for 1 minute and reinsert the Battery. Unfortunately, if the issue persists your Camera requires service.
You can create the service request at the following page: www.eservice.sony.com
Feb 15, 2010 | Sony Cyber-Shot DSC-P72 Digital Camera
I can turn the camera on and when I go to take a picture it takes one and turns off.. on the four indicator lights the far left one blinks yellow..
Hi Dear,
This issues seems to be because of discharged battery. As the battery is not charged enough to take more than one shot. Hence it automatically switches off you camera after one shot.
Please change your battery to full, and then try to take some shot.
Let us know if the problem persist.
Have a nice day.
Nov 06, 2009 | Fuji FinePix J10 Digital Camera
Black screen
Turn the power off and on again message is displayed when the Lens mechanism is stuck or when there is an internal malfunction. To resolve the issue, try turning off and on the power for few times. If the issue persists, try power resetting the Camera.
To power reset the Camera, remove the battery from the Camera. Press and hold the power button of the Camera for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery to check the operation.
You can also try Initializing the Camera by selecting the INITIALIZE option from the SETUP1 Menu of the Camera.
If the issue persists, service may be required.
Thanks for using FixYa
Nov 24, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Canon S2IS " change the batteries" problem
This worked for me after having the persistent "Replace the batteries" problem for about a year straight.
1. Reset the camera, according to the instructions in the manual. (Power on, hold MENU for 5+ seconds, selectOK, wait, turn camera off).
2. Remove the date/time battery for
two minutes (the tiny one in the battery compartment in its own little plastic holder). Replace after 2+ minutes.
3. Important: Insert freshly charged batteries into the camera.
I tried everything short of getting a new camera, and this was the ONLY thing to work for me. Its also simple enough that it takes 3 minutes to do, in case it were to ever happen again while on vacation, etc.
Good luck and I hope this helps.
Eric
Sep 27, 2008 | Canon PowerShot S2 IS Digital Camera
When I turn on my panasonic digital camera DMC-LZ7 (with fresh batteries) it attempts to focus but cant then displays a message saying "turn off camera and turn back on again". If i do this, the same...
Looks like a problem with the CCD sensor. Try removing batteries, and SD card for 5 minutes. Replace new batteries and try again.
If issue persists, you will have to get the piece serviced.
May 24, 2008 | Panasonic Cameras
Fuji FinePix A345 Digital Camera Logo
90 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
