Question about HP OfficeJet 7310 All-In-One InkJet Printer
HP+ officejet 7310
"Lid" will not come down , so machine will not work. Could it be the hinges? What is the solution?
  • BASIL FLASHMAN May 26, 2009
    Thanks so much for your help. Will try this when I get it out of the garden shed!
    The other is no problem at all.
Try pushing on the hinges one at a time, a downward motion will help. I am assuming you mean the access to the ink cartridge area.
Posted on Jun 15, 2007
Where is the cartridge located in the HP OfficeJet 7310?
  1. Lift the access door.
  2. Press down and lift up the green and black latches on the inside of the HP all-in-one.
Jul 11, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Our HP OfficeJet 7310 is giving the error message, "Phone off-hook". We have tried restarting it.
I had this same problem. I changed the phone cord to a 2 conductor DSL phone cord. Problem solved. Try it. It should work for you.
Jan 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Hinges for top cover for HP officejet 6210- Q5820A
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Sep 06, 2009 | HP Officejet J5780 All-In-One Printer
HP 7310 it can not power off, got an error message. the machine does not work
Pull the power cord... if it does the same thing after plugging it back in it is probably toast.
Sep 29, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Officejet 7310
Sounds like there is something going on with the paper sensor flag that resides in the top cover of the automatic document feeder. Need to make sure it is moving freely. It is spring loaded so it should move freely and spring back in to place. Sounds like your may be sticking in the up position after a few sheets. When the ADF lid is down these sensor flags should go in to holes in the bottom of the ADF. Hope this helps..
Inkworks
May 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet 7310 All-in-One Scanner problem
If the HP service cant help, then try to get a exchange, the machine usually have a warranty.
Jul 10, 2007 | HP OfficeJet 7310 All-In-One InkJet...
OfficeJet 7310 FAX issue
Did anything happen prior to the issue? It almost sounds as if the DC controller (main board) has gone bad. What happens if you try to make a copy on it?
May 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
60 people viewed this question
Clive
Clive
