Question about Dell Optiplex GX150 Tower Computer - 1GHz - 512MB Ram 40GB Hard Drive CDRW - DVD - 17" Trinitron Mon... (GX150TWR1G51240CDRWD) PC Desktop
RAM installation I recently upgraded my dell optiplex gx150 from windows 2000 to windows xp and in the process I added a 256 stick of pc133 sdram. When I started my computer back up it told me that the case had been opened and that I could press f1 to retry boot or f2 for setup utility. So I went into setup and reset my chasis intrusion detector and then hit esc and then it rebooted but when it rebooted I got the same new memory detected press f1 to retry boot or f2 for setup utility. So I took out the new piece of RAM and redid everything and it still gave me the new memory detected press f1 to retry boot or f2 for setup utility. So I have hit a wall and I have no Idea what else to do if it wont detect the original stick of RAM so please any help would be appreciated.
  • 4 more comments
  • hunter5555 Jan 15, 2009
    I have tried everything that has been suggested so far but none of it has worked. I also have gone to the dell site but none of it helped. I tried taking the RAM out and putting it back in and pressing F2 and I got the same press f1 to reboot or press f2 to enter utility setup and so I tried to press f1 but it gave me the same message. So does anyone have any other suggestions.
  • hunter5555 Jan 16, 2009
    Yes it is taking me to bios and yes it is detecting the memory. I also thought maybe i didnt save when i exited but thats not the case either because I redid everything and made sure I did and nothing changed.
  • reruss Mar 06, 2009
    trying to wipe clean and load th OS. I keep getting F1 retry.
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    OK, when you are selecting F2, it is taking you to the BIOS setup, correct?
    Within it does the BIOS detect your RAM? There is a menu item for Memory or System Memory.
    Are you doing a Save and Exit when leaving the BIOS?
  • Wayne Mineard
    BTW, here is a link to your computer's service manual in html.
    http://support.dell.com/support/edocs/sy...
  • Wayne Mineard
    Are you sure you are getting the RAM seated into the slots all the way? The tabs on the ends should click when they are seated properly.
    Try the original module again. You will have to hit F2 every time you make a change or open the case. (That's a pain, I know.)
    Comment back.
  • 728 Answers
Hi hunter555,
First off, you've done a lot of work for nothing. What you need to do is put back the new memory. When the Dell Bios boots, it confirming that it has detected the new memory. What you need to do is hit the F1 key to reboot and continue on to the XP installation. When you open the case, it will say the same thing. Don't worry about it, it's only confirming that the case was opened. Typically, I shut off the case intrusion detection, only because I'm always adding things to the machines and it's just a extra step I have to take to boot. However, it's good to know that your bios is confirming that you've opened the case, and that you've put in new memory. You want to make sure that the setup recongizes the entire memory in the banks. So, go to the system information page and make sure that it's reading the original and the additional memory 256k you added. Otherwise your done.
Good Luck
Mark
Posted on Jan 14, 2009
  • Mark Taylor
    Mark Taylor Jan 16, 2009
    Hi hunter555,
    Just for kicks, when you turn on the machine press the F8 key continuely on post. Post means from the time it beeps, until it comes up with the dell logos, just keep hitting the F8 key. If it gets to a screen that asks you what you want to boot from, click on your hard drive and see if that makes a difference. Hopefully it will by pass the memory issue.
    Thanks
    Mark
Dell Optiplex GX110 currently runs 128mb sdram pc125 cl3.0 . Am I correct to assume maximum upgrade would be 2 x 256mb sdram pc133 non-ecc unbuffered 3.3v ? Maximum memory per slot being 256mb ? Is my...
If I remember correctly, that Dell has two memory module slots, so 2 512 mb modules of non-ecc pc133 memory is the max that the system board will allow.
This is controlled by the system board chipset, and not by the bios.
Dec 15, 2010 | Dell OptiPlex GX110 PC Desktop
I have Dell Optiplex GX150 with Windows 2000 Professional. It worked fine untill I changed to XP. Then no sound at all. Now I changed back winsows 2000 and still no sound at all. The sound hardware tell me...
download and install the xp soundcard drivers for the gx150 here-
http://support.euro.dell.com/support/downloads/devices.aspx?c=uk&cs=ukdhs1&l=en&s=dhs&SystemID=PLX_PNT_P3C_GX150&os=WW1&osl=EN
Aug 01, 2010 | Dell OptiPlex GX150 PC Desktop
How to install upgrade sdram 128 pc133 for gateway 500
PC 133 Max ram for your model is 512MB - two 256 Memory sticks. Open the case, remove the menory in there (one clips on the side of each module) take note of the way the module comes out - replace with your new ones - reboot and that should be that.
May 10, 2010 | Gateway Essential 500 PC Desktop
Internet connection
pls inform your connection at LAN it maybe in The IP address promblem..the same address you can entr so that u can use and internet anytime..
Jun 26, 2009 | Dell Optiplex GX150 Tower Computer - 1GHz...
Ram upgrade
you need to make sure the ram is compatable, it looks like an old machine so chances are its using sdram pc100,
check the ram your trying to make sure its not pc133. let me know what each piece of ram has on its sticker
Mar 23, 2009 | Dell OptiPlex GX200 PC Desktop
Memory upgrade
First step : Make sure the memory you purchased meets the following specifications
"168pin PC133 SDRAM DIMM" which should be easily accessible from wherever you bought it.
If not, then you can find memory here. that the company guarentee's will work with your system. Also - You want to make sure the memory that was in your system to begin with is identical to the memory you are sticking in it to get it to 512MB Systems that are this old with "PC133 SDRAM" are very picky about what kind of ram you stick in them. Make sure wherever you purchase your memory from, has a guarentee that it will work in the make/model of your computer.
Mar 14, 2009 | Compaq Presario 5000 PC Desktop
DELL OptiPlex GX150 Upgrading
The fastest processor you can install in a GX150 is a Pentium III 1.13 Ghz processor.
The Socket 370 was a design used only for P3 processors.
Max RAM for that system is 512MB no way to upgrade past that.
If you paid $100 for a GX150, you paid way too much (You can buy a refurbished Dell Dimension C521 for $225 at their refurb site)
Jan 26, 2009 | Dell OptiPlex GX150 PC Desktop
Boot problem with Dell Optiplex GX150
To reinstall Xp from the CD you need to press F2 and go into the BIOS then select the boot order configuration and make the CD the first boot device and the hard disk the second boot device.
After installing XP, if you wish you can go back into the BIOS and change the boot order to boot from the hard disk first.
Dec 13, 2008 | Dell System Board for Optiplex GX 150,...
Memory upgrade
Dell dimension 4100's only support a maximum of 512MB ram.
2 - 256MB PC133 SDRAM modules - 1 in each slot
Nov 20, 2008 | Dell Motherboard Dimension 4100 Intel 815...
Finding ram
try to get a eraser to clean the contact of you're new ram!
May 13, 2008 | Dell Optiplex GX150 Tower Computer - 1GHz...
Computers & Internet Logo
241 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
