Question about Epson Stylus Photo R320 InkJet Printer
General error listed
Something has fallen into my printer; model R320. I believe it has cause a miss alignment or something. I have tuened the printer up-side-down and an earring and a pen cap has fallen out. However, the printer still makes a loud noise, as something is still jammed in there. I would like to take it a part, I just want to be able to put it back together... correctly!
Buggs
  • Epson Master
  • 419 Answers
Unfortunately the R320 is like many Epson inkjets in that, once you start taking it apart you run the risk of knocking the main unit out of alignment and when/if that happens you need a service center to get it realigned.
Chances are there is still something trapped down the paper input tray as this is a favourite location for stuff to fall in (entire bowl of Pot Pourri was my favourite!! :) ) so perhaps a little careful examination of that area with a strong light and some long tweezers are in order.
Failing that you could try locating a service manual and try taking the back portion of the case off but as I said, be careful as you may just brick the printer.
Good luck and hope that helps somewhat.
Posted on Feb 15, 2009
My printer will not print. I get a message saying General Printer Error 0x610000f6 Refer to Printer Documentation. I get the message on both my printer and my computer. When i click the error bubble on the...
Hi there, regarding with the problem that you have..the error message that you are encountering with that machine is something about to work on with the printhead..because the printhead is the one causing the problem why is that the error message keeps on popping up, i believed that the printer model that you have is already out of warranty..the printhead is not replaceable if the printer is out of warranty.. well in that case, quite frankly the printer is already faulty.
you can definitely call HP by dialing this number 1-800-474-6836 and let them see what they can do in their end..
Thanks!
Aug 03, 2011 | HEWLETT-PACKARD Photosmart Premium C309n...
Epson R320. Had a "end of life" message so I held done the Power/Maintainence/Stop buttons for 10 secs and nothing happend. Held them again and unplugged it, plugged it back in and pressed Power and now...
The R320 is not compatible with the keypad press routine if I remember correctly so you really need a utility that can work with it.
I've had a quick check and found that the A10_IPR is capable of handling the reset for that model but for completeness here's the link for all the current info I have on the R320 in terms of resetting and fitting an external waste tank which you'll want to consider to avoid the printer flooding with waste ink.
Hope it's of some use but let me know if you're still borked after trying.
Martin
Aug 01, 2010 | Epson Stylus Photo R320 InkJet Printer
Any info on r320 general error fix . Had a paper jam and cant reset error. epson support usesless just say tech it to an authorized dealer to get it fixed.
1. you may have paper debris in the roller gear and therefore shut down.
2. you roller or transfer gear is damaged and needs replacement.
Apr 15, 2010 | Epson Stylus Photo R320 InkJet Printer
General Error Message
The "General error" message on the Epson R320 (as with most other Epson inkjets) can mean a whole host of things.
The most common ones are:
  • Printhead carriage blocked
    (something is blocking the printhead from moving left and/or right properly)
  • Cleaning/Parking pad area blocked
    (the printhead can't reach it's normal resting position)
  • Disconnected sensor
    (a ribbon cable has become disconnected or a sensor has failed so the printhead or paper location is not detectable)
  • Cartridge chip sensor issue
    (one or more of the cartridges has not been installed properly, has a "bad" chip or the sensor wires in the printhead carriage [where the cartridges sit] have been damaged)
If you can provide a bit more information on the error, possibly from the status monitor software that might give a bit more of a clue but hopefully the points above will give you a few places to look for possible causes.
Mar 15, 2009 | Epson Stylus Photo R320 InkJet Printer
General error on my epson stylus photo r320-
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Epson Stylus Photo R320 InkJet Printer
General error
i have some problum of epson r230 printer general eror please send me this problum solution
thanks
Oct 20, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus R320 - cant align the CD tray to print....keeps showing error.
This printer has a bad system tray. If doesn't work in regular way, try inserting the cd tray from the back using the back slot and see what happen (usually works)
Oct 03, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson r320 System error. Press and hold both Power and Stop buttons for 7 seconds
This could be the Ink Overflow Protection Error. If it is you may need to get a Rescue Kit for your machine form http://www.TheServiceManualShop.com Does the status monitor or LCD indicate that parts inside are past there service life?
Aug 23, 2007 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R320 InkJet Printer Logo
82 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
