Wallpaper and screensaver settings on desktop
After i start the system my wallpaper and screensaver setings are changed to some default setting with the name modified theme
    Guru:
  • 829 Answers
Hi are you connecting the laptop to a lan , If yes it will happen because admin guys will have deployed from server.
Posted on Jan 14, 2009
How do you get Windows 10 free update from Windows 8 to operate the screen saver?
How to customize Screensaver in Windows 10
RECOMMENDED: Click here to fix Windows errors and optimize system performance
There were times when computer monitors used to suffer from image burn-in issues caused by showing the same image for a long period of time and people used to install a screen saver to avoid the issue. The computer screens today no longer face the burn-in issues, but people still use the screen saver on their computer systems for fun's sake. Windows 10 comes with a six built-in screensavers. Let us see how you can customize screensavers in Windows 10.
Read: Are Screensavers necessary and still needed.
Screensaver Settings in Windows 10 You can get to your screen saver settings directly by typing 'Screen Saver' in the taskbar search box in the lower left corner of your system. Click on 'Change Screen Saver' and it will take you the Screen Saver settings right away where you can adjust the settings according to your own preferences.
Alternatively, right-click on your Windows 10 desktop, and select Personalize to open Personalization settings. Next click on Lock screen in the left pane.
Scroll down the Lock Screen settings and click on Screen Saver Settings. The following window will open. Here you can adjust the settings according to your preferences.
By default, Windows 10 offers the following six screensavers - 3D Text, Blank, Bubbles, Mystify, Photos and Ribbons - nothing new here. Select the screensaver from the drop-down menu and change its defaults Settings, if any are available.
For instance, the 3D Text screensaver lets you customize the text as well as a few other options.
The Photos screensaver lets you display your favorite photos as a screen saver.
Once you are done, click on save and exit.
Create Screen Saver Settings Shortcut
If you access the screensaver settings frequently, you can create its desktop shortcut as follows: However, it is easy to change the settings but if you change your screen saver often, it would be better to create a Screen Saver Settings shortcut on your desktop.
To create the shortcut, you have to right-click on your desktop and click on New > Shortcut.
Type control desk.cpl,,@screensaver in the location space in the wizard.
Click Next and give a name to your shortcut. Click Next and you are done. Give it a suitable icon of your choice.
Use this shortcut to change or adjust your screen saver settings whenever you want, quickly.
You can also create a shortcut to launch or change Screensaver state for a specific screensaver.
Nov 29, 2015 | Microsoft CompuRegister POS-1000 POS...
The text on my pc keeps going blue, how can I stop it?
Windows allows you to change the themes of your computer. This includes the wallpaper, the screensaver when your computer is idle, any noises it makes, and even the color of the toolbars and windows. Sometimes, however, when you restart your computer, the theme will revert back to the Windows default theme, which is called Aero. This can be because you have not disabled Aero, because your performance settings are using too much energy, or because your screen resolution is too high or low for the theme you are using.
Screen Resolution b> The higher your screen resolution, the sharper the images and text will appear. Sometimes, however, the of the wallpaper for the theme is not the same as the screen resolution. This can cause your theme to revert back to the default. To fix this, click the "Start" button. Then click "Control Panel." In the "Control Panel" window click "Adjust Screen Resolution" under "Appearance and Personalization." Select the resolution that is the same as your wallpaper. b> Performance Settings b> If your computer is running on high performance settings, your computer's energy will be used quickly and Windows may automatically change the screen saver to keep the energy from running to low. To change your performance settings, open the "Control Panel" and click "System and Security." Then click "Change Battery Settings" under "Power Options" and select "Power Saver" or "Balance." b> Disable Aero b> Aero is the default theme setting for Windows Vista and Windows 7. If you try to change your theme and it reverts back to Aero, it is because Aero is still not disabled. To disable Aero, right-click on your desktop and click "Personalize." A window of all the themes on your computer will open. You will see "My Themes," which are any themes you have created, and "Aero Themes" under it. To disable Aero, click "Save Theme" under "My Themes" to make your current settings default, or select one of the themes under "My Themes." This will make that theme the default. b> Troubleshooter b> If you still cannot figure out why Windows changes the theme back to the default after restarting, you can use Windows's built-in troubleshooter. The troubleshooter will find the source of the problem and automatically fix it for you. To use the troubleshooter for your theme, open the "Control Panel" and click "System and Security." Then click "Troubleshoot Common Problems." Under "Action Center," select "Appearance and Personalization." The troubleshooter will run. When you restart after it completes its action, your theme should stay the same. Hope this helps.
b>
Dec 15, 2012 | Computers & Internet
I have acer aspire one d255e notebook, and i want to change the dekstop background but i cant make, there are no choices that i can change the wallpaper, my operating system is windows 7 starter
Dear user,
Unforetunately you cannot do anything to your desktop background because that is the default feature of Windows 7 Starter Edition.
You have to upgrade at least Home Premium of your Operating System for you to change it .
May 09, 2011 | Computers & Internet
How to delete photo from wall
If you are talking about wallpaper you need to right click on desktop and go to display setting and then go to screensaver and desktop background setting
You can change or remove the desktop background
Nov 24, 2009 | Computers & Internet
How do I use my display setting, the desk and the screensaver?
right click on the desktop from mouse and then go to properties. now use the desktop tab to change the desktop settings like wallpaper and icons. and use screen saver tab to change or edit screen saver settings.
dont forget to vote
Oct 27, 2009 | Computers & Internet
Desktop times out to password-less lockout?
change the power setings so that it never goes into standby
http://www.dotnetcurry.com/ShowArticle.aspx?ID=158&AspxAutoDetectCookieSupport=1
Oct 12, 2009 | Microsoft Windows Vista Home Premium with...
Cannot get rid of an unwanted program .
here's manual antivirus xp 2008 removal
http://www.2-spyware.com/remove-antivirus-xp.html
If you are having problems with your desktop or getting the nasty message when you boot up follow the instructions below, but use the above link to remove the virus. YES THIS IS A VIRUS AND NOT A VIRUS REMOVAL TOOL!
First you need to stop the program from loading on startup. This is what you do to stop it:
Start, run
Type msconfig
Go to Startup tab
(if you've totally removed the antivirus program, you will not find these files and you can skip to the gpedit.msc step)
Uncheck lphc35dj0e1an
Uncheck rhc75dj0e1an
Click apply, then ok
Restart computer
Then you need to delete the main files this program uses. Delete the following file:
C:\windows\system32\lphc35dj0e1an.exe
Delete the following folder and all contents:
C:\program files\rhc75dj0e1an
This should remove the program from your system but you probably still have a warning message displayed as your wallpaper in Windows and the virus removed the ability to change the wallpaper or your desktop settings.
To restore ability to change your desktop settings and select a different wallpaper and screen saver do the following:
Start, run
type Gpedit.msc
Navigate to User configuration, Administrative Templates, Control Panel, Display
Right click on Remove Display in Control Panel
Click on Properties and select Disabled
Do the same steps to change the following attributes to disabled:
Hide Desktop Tab
Prevent changing wallpaper
Hide Apperance and Themes tab
Hide Settings tab
Hide Screen Saver tab
You should now be able to use your computer normally and change the wallpaper/screensaver to something other than the warning message Antivirus XP 2008 set it to.
Jul 19, 2008 | Computers & Internet
Wallpaper & Screensaver of Nokia N72
. Tell me how to put a wallpaper in enlarged form on the desktop of my phone...when i set a photo as a wallpaper it sets but the upper & lower strips remains same.....
2. another poblem is that how to put a screensaver in my N72 mobile....
Plz solve these problems as quickly as possible..
Mar 20, 2008 | Nokia N72 Cellular Phone
Computers & Internet Logo
257 people viewed this question
David Payne
David Payne
