Installing a dell 1320c lj color printer s/w on a windows XPPro machine using the CD s/w for a network IP application. When I run the s/w, I get install shield wizard error [-5009 : 0x8002802] and the install terminates. I have read and tried several installshield corrective actions with no success.... Suggestions please!
  • 59 Answers
I think is not compatible with your windows make sure the printer box said compatible with your computer or windows
Posted on Oct 15, 2009
How do i get service for a Dell color Laser Printer 1320c
Pcmacprinter.guru We can help with all printers and
Parts needed.
Oct 19, 2014 | Dell Office Equipment & Supplies
Dell 1710n need cd
Hello you can download the installation software here:
http://www.dell.com/support/drivers/us/en/04/Product/dell-1710n
Please select your windows system.
Remove previous installed programs, before you install the new software.
The setup for the static ip, you have to select this under the install of the printer program.
Good luck
Feb 01, 2013 | Dell 1710n Laser Printer
My Dell 1320c is print reds as yellow! What can I do?
Hello
Check your toners, maybe some colors (like cyan) is empty. You can use this guide on how to change them:
Dell 1320c Maintenance
Sep 07, 2011 | Dell 1320c Laser Printer
Dell 1320c print spool issues
Today I installed my new printer Dell Color Laser Printer 1320c. I cannot print as documents sent to spooler. I tried reinstalling. o good. I disabled spooler...no good. I'm a technophobic with little spare time, running own business and cannot print the documentation I need. Any help out there?
Jul 02, 2011 | Dell 1320c Laser Printer
On my 2 year old Dell 1320c the black is not dark but only gray. I put in a new toner but that did not help. Other colors seem to be good. How do I fix it?
You might try restoring the defaults on the printer. Double-click the Status Monitor Console icon on the Windows task bar. The Printer Selection window opens. In the Printer Selection window, click Dell Color Laser 1320c.
The Dell Color Laser 1320c Launcher opens.
Click the Tool Box icon. The Tool Box opens. Click the Printer Maintenance tab. In the upper left window, select Reset Defaults. Click Start. The Password window appears. If you have not set a password for the printer, click OK. Otherwise, enter your password and click OK.
Oct 21, 2010 | Dell 1320c Laser Printer
How do I change the ip address of the Dell 1720 dn printer to work with my network?
Ok the following instructions will help you reset the ip address of your printer however you must use the origina driver cd to do this. Follow the instructions below if you have no print server involved with this network. If you do use a print server let me know ok?
Print and Check the Network Setup Page
  1. When the Ready/Data light is on solid, press and release Continue to print a menu settings page and a network setup page.
  2. Under the Standard Network Card heading on the network setup page, make sure Status is Connected.
If Status is Not Connected:
    • Make sure the Ethernet cable is firmly plugged into the back of the printer.
    • Plug the Ethernet cable into another wall outlet.
  1. Under the "TCP/IP" heading on the network setup page, make sure the IP address, netmask, and gateway are what you expected.
  2. Ping the printer and verify that it responds. For example, at a command prompt on a network computer, type ping followed by the new printer IP address (for example, 192.168.0.11):
ping xxx.xxx.xxx.xxx
If the printer is active on the network, you will receive a reply.
  1. If your printer doesn't respond, or if the IP address is not what you expected:
    1. Insert the Drivers and Utilities CD into your computer.
    1. The Drivers and Utilities CD should launch the installation software automatically.
If the CD does not automatically launch, click Start® Run, type D:setup.exe (where D is the drive letter of your CD), and then click OK.
    1. When the Drivers and Utilities CD screen appears, click Set IP Address Utility.
    2. Select your printer from the "Configure Print Servers" list, and then click TCP/IP Settings.
    3. Make the necessary changes, and then click OK.
    4. Click Close.
    5. Print and check the network setup page to verify your changes.
Install Printer Drivers for All Clients
  2. The Drivers and Utilities CD should launch the installation software automatically.
If the CD does not automatically launch, click Start®Run, type D:setup.exe (where D is the drive letter of your CD), and then click OK.
  1. When the Drivers and Utilities CD screen appears, click Network Installation - Install the printer for use on a network.
  2. Select Install printer on one or more remote computers, and then click Next.
  3. Enter your Administrator user name and password, and then click Add.
  4. Select the clients or servers, and then click Next.
  5. Select the network printer you would like to install, and then click Next. If you do not see your printer listed, click Update to refresh the list or click Add Printer to add a printer to the network.
  6. Select your printer from the list. If you would like to change the printer name listed, enter a new name in the Printer Name field.
  7. If you want other users on the network to access this printer, select Share this printer with other computers, and then enter a share name that users will easily identify.
  8. Click Next.
  9. Select the software and documentation you want to install, and then click Install.
  10. When the Congratulations! screen appears, print a test page to verify the software is installed correctly.
  11. Click Finish to exit.
Aug 09, 2010 | Dell 1720dn Laser Printer
Used to work fine until router was replaced. Now, network can't find printer. Samsung CLP315w printer, Windows 7 and XPpro on 2 laptops.
Hello!
You must not have configure your printer to be shared that is why you can't find it in your network.
To share printer:
- go to Control Panel
- open Printer and Faxes
- select or right click your printer and click sharing
- on the Sharing menu, click share printer (that's it)
but if the problem still occurs, try checking your Windows Firewall settings, to do this:
- open Windows Firewall
- at WIndows Firewall menu, click Exception tab
- in Exception tab, try to check if Printer and File sharing is enable.
Note: to find what are shared on a particular computer:
- at RUN command, type the ip address or computer name
(\\10.0.0.23 or \\samuelcomputer)
Hope this solves your problem.
Jul 31, 2010 | Samsung CLP-315W Laser Color Printer
Lost CD for Dell Laser Printer 1320c installation setup
Check this link and click on the "Download Now" button. The driver is 8MB.
http://www.soft-go.com/download_driver/Dell-Color-Laser-1320C_137.html
Have a great day!
May 05, 2009 | Dell Office Equipment & Supplies
Dell 1320C
On page 30 of the 1320c manual it says this signifies the coming end of the PHD (print head device). I cannot find a part number or reference to the PHD on the Dell web site pages connected with this printer
Jan 30, 2009 | Dell 1320c Laser Printer
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
