Question about Canon PowerShot S2 IS Digital Camera
"change the batteries"--but they're new batteries!
My camera also says "change the batteries" when I try to turn it on. I have tried changing the batteries several times, with brand new batteries and it just says the same thing. I can view the pics on the camera, but when I try to take a pic while in view mode to turn the camera on, i just get the "change the batteries" message on a black screen. Ikes' solution didn't work for me. Any suggestions? Might this be a CCD problem?
  • 1 more comment
  • donshe Oct 27, 2008
    I am having the same problem. It doesn't matter what kind of batteries or how fresh. Cannon tech support had me "reboot" the camera, but that did not fix the problem. The average repair cost through Cannon was $130.00, or I could buy a refurbished upgraded model for a little more.
  • rooseboomfan Nov 16, 2008
    I have the same message on my camera (same model of course). I've tried several kinds of batteries (rechargeables and non-rechargeables) and it still doesn't work! After taking 10 pictures, it says CHANGE THE BATTERIES!
    I am thinking of buying a new one too! ;)
  • TanYah Dec 27, 2008
    I have the battery error problem also, but it seems intermittent. Some days it will work, others it will fail with the battery message. At the camera shop, of course, it worked fine. I would like to know more about the comparator out of calibration idea given above. What can be done about the comparator; can it be replaced? Can it be recalibrated?
    A possibly unrelated possibly related problem is that the auto focus seems not to be focusing the pictures. Many pictures seem out of focus.
I had the same issue which cleared itself up when I used digital specific batteries (theoretically higher power) as well as replaced the cr1220 battery (in a small gray plastic slot next to the 4 AA batteries).
Posted on Apr 14, 2008
Hi Bogdan, this seems to be the right direction. I have the same problem with the same model. What I noticed (and what basically prooves your exmplanation) is that in case I get the message, I take out the batteries, clean the contacts, and put them back into the camera. The camera usually (unless the batteries are really empty) stops giving me the "Change batteries message" and works fine for some time. I usually get this message on camera startup after I haven't used the cammera for some hours or days. I yet have to test if a bit of (electric) contact spray on the batteries will help with the problem. Thanks, Ingo
Posted on Aug 12, 2007
    Novelist:
  • 198 Answers
Hello Well this was allwais a tricky problem. It's pretty hard to diagnosticate this as it can involve about any component in the camera - except the ccd sensor - that's funny to add. But let's start with the begining. A typical alchaline (non rechargeable) battery has 1.5 Volts therefore if your camera needs 4 of them, the resulting tension would be 6 Volts. Now take a look at your rechargable batteries to see what tension they provide for each element. You may find a value of 1.23 - 1.3 Volts. Four rechargeable batteries will give you 4.92 - 5.1 Volts. As you can see, there's a difference here. But however the camera is suposed to work even if there is a voltage difference as big as that. Every camera works with rechargeable batteries and every rechargeable batteries will have the same property of having 1.23-1.3 volts. But now let me explain what happens when the camera says "charge the batteries". There is an internal comparator (hardware component) that by measuring the tension at the pins of the batteries and their internal resistance will try to "guess" what's their current charging state. It's made out of electronic components, it may fails or become decalibrated and therefore may produce false warnings. Therefore, it will figure out that the 4.9 - 5.1 volts aren't enought for it. That time the gap between the rechargeables and the alchaline normal batteries get's deeper. Let's try to do this in an organised fashion. Please try to connect 4 new alchaline batteries instead of your rechargeables. Check to see if they work better then your rechargeables. If they work, it means that the comparator inside your camera was slightly decalibrated. If they don't work it means that the comparator in your camera was.. badly damaged or decalibrated. But let's not make things too quick. Plelase try this simple test and reply here. I will take it from there and explain you what must be done further. Good luck. I'll reply to your comment as soon as possible.
Posted on Jun 13, 2007
I have a sony dcr-dvd108. the battery is fully
it might be battery to used and it's charging quick and loosing power to quick. have tried to change battery for new
Aug 24, 2009 | Sony Handycam DCR-SR300 Camcorder
My camera will not turn on at all try changing battery already with a new battery
when i turn camera on ...the display screen will only show for about 2 seconds. Have new batteries.
Jun 03, 2009 | Kodak EASYSHARE M1063 Digital Camera
When putting in new batteries the "change battery" sign comes on
try new Alkaline batteries or fully charged NiMH batteries, you may need to clean and adjust the springs in the battery compartment
this tips may give you more details
http://www.myfixtips.com/blog/digital-camera/why-my-camera-keeps-saying-%e2%80%98change-battery%e2%80%99-even-with-new-batteries-176.htm
May 14, 2009 | Canon PowerShot A520 Digital Camera
Charged batteries saying that batteries are low
Check you battery charger. Is it plugged in tight> Is it plugged into a GFI outlet and is that outlet turned on. Make sure the cord is seted tightly into the charger as well.Try reseating your batteries carefully in the charger and charging them again.
While you are doing that, try some regular batteries in the camera and see if the camera works. Be sure to change the ssetting for batteries when you change the type of batteries you are using.
If your rechargeables will not charge then you may need either new rechargeables or a new charger.
Aug 20, 2008 | Cameras
Samsung S730
Try to remove your batteries for a minute and then reattach them again.
Jan 07, 2008 | Samsung Digimax S730 Digital Camera
Wont turn on!!!
My problem is this; i changed the battery after i had signal that battery should be changed. I changed the batteries with new one but when i press the on/off button, the camera will turn on.
I put in new batteries again and is still the same problem.
Mar 11, 2007 | Vivitar ViviCam 3765 Digital Camera
Stuck on change batteries
it seems that the camera section is haveing troube, may be in the lense movement or initilizing system. if the camera does not initilizes while swithcing on it turns itself off by giving low battery warning.
Nov 01, 2006 | Canon PowerShot A520 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
228 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
