Question about Baby Lock BL1556
Babylock buttonholer thread jamming
I have a babylock sewing machine with a one step buttonholer but the threads keep jamming and i don't have the manual for it. is there any specific way to thread it or is there anything wrong with it? i have tons of buttonholes to do for school projects and its a hassle to try to do them all on the school machines. thanks so much
  • 4 Answers
SOURCE: buttonhole lever
If you remove the cover on the upper left portion of the machine, while looking from the left to the right.....Above the BH lever area, you will see a round cam with a post through the middle. Rotate the round can ( with fingers on it), and try again. This will change the angle position on the lever, and hopefully correct your problem. You may have to go a couple of clicks in either direction.
Posted on Nov 26, 2007
  • 24 Answers
SOURCE: serger/sewing machine
You probably are in need of a new bobbin case they are plastic and oif you have broken a needle lately it may have gouged the case and the top thread is getting caught and bunching up underneath. Visit www.stevessewandvac.com you can contact them and have a bobbin case sent to you.
Posted on Aug 13, 2008
  • 67 Answers
SOURCE: how to thread bobbin, insert in machine correctly. Lost manual.
go to link: http://www.youtube.com/watch?v=YL433PhG05c
a vidio is here that will show you the route to follow for your automatic threading to work. You may need to watch it a few times as it is demonstrated very quickly near the begining only once.
Posted on Jan 18, 2009
SOURCE: tension settings for the babylock sewing machine
I found that the tension setting of 1 worked. The main problem was the machine had thread wound around behind the bobbin. I had to take the plates that are under the foot out, clean out the thread, oil the machine and use a spool of thread that had more weight than the little spool I was trying to use.
Posted on May 17, 2009
  • 14 Answers
SOURCE: on a babylock elegante the bobbin thread shows,
Have you reset the tensions for this machine, look in your manual and follow directions. If this is an Elegante there is also a set of instructions on the machine. On the LCD screen there is a picture of a sewing machine with a question mark, touch it, find Troubleshooting and touch that then find the problem you are having and read. If this does not help take it to a Brother dealer and have it reset so as to keep you machine in good running order.
Posted on Jul 07, 2009
Printable Baby Lock Imagine Serger threading guide
Babylock has a quick reference threading guide and the user manual on the Imagine product page: https://babylock.com/machines/serger/imagine . The direct link to the threading guide is https://babylock.com/resources/5024/download ; the user manual is https://babylock.com/resources/5023/download . The step by step directions are in the User's Manual starting on page 10 (page 12 of the PDF). You should print pages 10-13 and then use the portions of the guide that are appropriate for the type of stitch you are using.
I hope this helps.
(Sergers threading is a bit more complex than a regular sewing machine threading pattern.)
Apr 14, 2018 | Baby Lock Sewing Machines
How do you use the buttonhole foot on a babylock companion 1550
1.Mark position and length of buttonhole on fabric.
2.Set button on the base and slide base forward to secure button.
* If button does not fit on the base, adjust slide on base to diameter of button plus thickness of button.
a= Length of button + thickness
3.Pass upper thread through the hole of buttonhole foot and attach buttonhole foot to machine.
Bring upper and bobbin threads to the left under foot.
4.Position fabric under presser foot so that the center line mark is in the center of the needle opening in the buttonhole foot. With the main part of the foot pushed to the back, lower the presser foot lever.
5.Lower the buttonhole foot lever so it is positioned behind the raised finger on the foot (see step 5 illustration). a
Note:Machine will not start to sew if buttonhole lever is not lowered properly or buttonhole foot is not positioned correctly.
Note:If machine does not reset for second buttonhole, be sure the presser foot raised finger is pressed against the lever.
6.Hold upper thread lightly and start the machine.
Ref. :babylock.com/downloads/manuals/
Oct 05, 2017 | Sewing Machines
Thread keeps breaking on Babylock BL600
since the machine is a babylock I suggest having the machine
serviced to see if the machine has a timing problem or some part
is out of aligment.
Nov 06, 2012 | Sewing Machines
I have been trying to make a buttonhole but the top thread keeps breaking and the threads are all snarled up underneath the material. what am i doing wrong? i have a brother ls2125 machine maria
Firstly have you interfaced the material that you are buttonholing on? You will never get a good buttonhole otherwise. Also start each new project with a new needle matching the size to the weight of fabric. Good guide available here http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/
Top thread breaking is usually because the tension is too tight or the thread is catching somewhere in the thread path from the spool to the needle. Also check that the needle doesn't have a burr on it somewhere, or is blunt.
Thread snarls underneath the fabric is usually caused by top thread tension issues. You will need to rethread top and bottom and CHECK that the thread is in tension correctly. So lower the pressure foot and pull the top thread just before the needle - does it feel hard to pull? If not, then the thread is not in tension. Rethread top again, checking the tension dial is set to 5 and the thread is correctly pulled between the tension discs. And always hold the two thread tails at the back of the sewing area as you start each new seam to avoid these being pulled down into the bobbin area and getting jammed up.
So, rethread, test sew and get the top tension sorted, a nice straight stitch happening, then try the buttonholing sequence again.
Apr 26, 2011 | Brother LS-2125 Mechanical Sewing Machine
I need to learn how to make a buttonhole on my Husqvarna 210 electronic sewing machine.My manual is gone.
You may be able to still get that manual, check with your dealer. If not you can call Viking at: 1-800-474-6437 if it's out of print for a photo copy of the original owners manual.
To make a buttonhole do the following:
1. Turn the selector dial to the top position, That is the first step of the buttonhole.
2. Turn the stitch length dial (the bottom dial) to the picture of the buttonhole, it's between the 0 and the 1 on the dial.
3 Put on the "C" foot and put the tension dial, (the small dial just above and to the right of the needle) on 4.
4. On a test fabric, sew about an inch or so and stop. Turn the selector dial down one click and sew the bar tack of the buttonhole. Just do a few passes, don't build up alot of stitches here.
5. Turn the dial down another click to the 3rd step, the right side of the buttonhole and sew until you reach the place where you started the left column of the buttonhole and stop.
6. Turn the dial UPWARD one click to the bar tack position again and do another bar tack like you did at the top of the buttonhole. Don't build up alot of stitches here, about three passes does the trick.
7 Remove the fabric from the machine and when you cut the threads, leave a tail about 2 inches or so of the thread. From the back side of the buttonhole, pull gently on the thread and a loop from the front thread will appear on the backside. Pull the front thread to the rear and tie off the threads and then cut them close to the knot you tied and the buttonhole will not come apart.
Oct 14, 2009 | Husqvarna Viking 1
Buttonholer on Singer 2639 sewing straight ahead
set you machine for "zigzag" then: try your buttonholer again.
Also; the thread tension can be adjusted by a small screw in the side of the bobbin for the bottom loop of the stich or, the tensioner on the side of the machine head for the top loop
May 28, 2009 | Singer 2639
Tension settings for the babylock sewing machine
May 15, 2009 | Baby Lock BL1556
Kenmore 385 model Automatic Button Hole Apparatus Jams Thread?
Practice and practice some more! Use the same fabric and interfacing as your project and a NEW needle (the correct needle) This is for the Sears Kenmore 385 automatic button hole maker. Make sure you pull the bobbin thread through the Guide Block - it is that simple. Make sure you pull your thread to the back of the machine though the presser foot slot - the correct presser foot. Account for both thread tails before starting to sew. Keep thread tails to the back of the machine 4-5", insert fabric under presser foot keeping thread tails clear. Mark button hole and sew.
Mar 30, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Problem while sewing buttonhole with a thick thread
You will need to use a size 18 needle or even better a size 18 top stitch needle. It has a larger eye.Tighten the tension to about an 8 and try it. You may have to lengthen the stitch length to make it sew satisfactorily.. If it won't work on 8 go to 9 and if it still won't work, wrap the thread around the bobbin winder guide (on the left top of the machine) for more tension. It is very hard to sew heavy duty thread on a household machine.
sewman7
Jul 06, 2008 | Brother LS-2125 Mechanical Sewing Machine
Buttonhole
When a machine does an "automatic buttonhole the feed does not move for a few stitches and maay jam if there are too many stitches made in this position. Is it an automatic buttonhole or can you choose how many stitches for your bartack? You ask about 0.5 well that is halfway between 0 and 1 on the stitchlength and this is indeed the recommended setting for buttonholes. If you are doing a manual buttonhole set your machine to this for the sides and zero for the bartacks but you only need about 6-10 stitches on the bartack. Fininsh it off securely by setting to straight stitch and stitch length zero for about 4 stitches to lock the thread in.
Jun 25, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
