Question about Acer Aspire 4520-5582 Notebook
Can not connect wirelessly with router - Acer Aspire 4520-5582 Notebook
  • kachurak
    kachurak May 11, 2010
    details!
    errors anything???? more info!
My wireless signal on my Acer aspire 5223 stop working after purchasing it a month ago. It shows on the laptop under the wireless network connection that I have excellent signal strength from the Netgear router I am using and even shows that the laptop is connected with the router wirelessly. But for some reason a yellow bubble with an exclamation mark (!) inside of it shows up indicating there's a problem and I'm not able to get on the Internet. I tried using a ethernet cord from the router and still wasn't able to get on the Internet. I also tried a few times unplugging the router and modem for 60 seconds and once everything was hooked back up, I still was having the same problem. Also when this problem occurred an unidentified network/public network icon appeared on my Network and Sharing Center when originally the laptop was connected under a home network with the home icon. Please help me.
Posted on Apr 21, 2011
    Guru:
  • 829 Answers
The list of wireless routers that are available in Windows is very limited and the signal strength of any router that is detected is weak. This can occur when the Lite-On USB Wireless 802.11 b/g hardware and Windows are not able to fully synchronize the signal strength data. Figure 1: Example of detected wireless devices when the antenna cable wire is connected to secondary port can not connect wirelessly with - c01153759.jpg Figure 2: Example of detected wireless devices in the same environment when the antenna cable wire is connected to primary port c01153760.jpg To correct this error , download and install Lite-On USB Wireless LAN Driver Update (sp35177) (in English) from the HP Web site. This update should only be applied if your PC has the Lit-On USB Wireless LAN adapter and is exhibiting the symptom. As a work-around, you can connect the wire that runs from the wireless antenna port to the primary port on the cord as follows: CAUTION: This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
  1. Open the side panel.
  2. Find the wireless networking board by following the antenna wire connected to the wireless networking antenna port on the back of the computer. Figure 3: Wireless networking hardware can not connect wirelessly with - c01153761.jpg"http://i.fixya.net/uploads/images/c01153761.jpg" alt="c01153761.jpg" class="h_mi" /> 1 - Wireless network board 2 - Antenna wire 3 - Wireless networking antenna port
  3. Very carefully, disconnect the small wire from the board by gently pulling the end of the wire away from the board.
  4. Connect the wire to the other available port on the board. Figure 4: Avcan not connect wirelessly with - c01153762.jpg/b> c01153762.jpg
  5. Replace the side panel, connect the power cord, turn on the computer, and use the computer again to verify that wireless signal strengths have improved.
Posted on Jan 14, 2009
Wireless router connection
IF the ROUTER has wireless "enabled", and your device/computer has wireless (and the wireless is ON) then you should see the router's name when you search for "wireless connections" click on the name and enter the password for the router connection and should be able to connect, IF you can't see the router's name then unplug the router and wait 20 seconds to 1 minute, then plug the router back-in wait for the wireless "light" to come back on, and try again. Hope this helps...
Sep 08, 2014 | Dell Dimension Computers & Internet
Need to connect DI524 for wireless connection to internet
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
May 16, 2011 | D-Link AirPlus DI-524 Wireless Router
How Can i maintain who can access my wireless connection I have neighbors who can access my wireless connection.I dont want no one other than me the psp and the ps3 connecting to it
you will need to enable security on the wireless network.
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Feb 24, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
Iam not able to get the internet on my laptop. i have a desktop which has internet. i have the belkin wireless g plus.
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Dec 03, 2009 | Belkin (F5D5231-4) Router
AFRAID OF SOMEONE IS LOOKING MY COMPUTER
Very, very highly unlikely. It doesn't work like that.
Netgear is probably the manufacturer of your wireless card, and the rubbish software they give you is freaking you out.
Nov 18, 2009 | Actiontec (GT704WG) Router
How to set up the router? can only connect to the Internet when the laptop is connected directly through the router
The wireless router needs its wireless settings configured and also the wireless card in all the laptops needs to be configured with the router’s wireless settings so the laptops can communicate with the wireless router.
Nov 15, 2009 | D-Link DIR-615 Wireless Router
Belkin Nimo wireless router internet drop outs
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Sep 29, 2009 | Belkin (F5D5231-4) Router
Can i use Bluetooth USB Adapter to connect PC to wireless router?I purchased a new PC that's connected to a wireless router for internet. I want to connect my old PC to the same wireless router. I don't...
Hi, to connect your computer to the wireless network of the router you need to have a wireless adapter. The bluetooth adapter will not work in this case as the router does not communicate with the bluetooth signals.
Purchase a wireless adapter like NETGEAR WG111
Rate it, if it helps.
Regards
Anand
Aug 03, 2009 | Computers & Internet
Cannot connect wireless device
If you have the correct wireless security and the laptop wont connect wirelessly, the best thing that you can do here is to access the router setup page and change some wireless settings on the router like the wireless channel , I advice you set the wireless channel to 11 then after that try to connect your laptop again to the wireless network and by the way change also the SSID or wireless network name of the router....
Nov 04, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Acer Aspire 4520-5582 Notebook Logo
353 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
