Question about Goodman GMS90703BXA Heater
Goodman furnace blinks four times
What does this mean and how much will it cost to fix. Can i fix it myself.
If the main limit switch is bad, the part is cheap and you can replace it. If the main limit switch is not bad and is activating for a reason, you probably need a professional.
Posted on Jan 18, 2009
What does code blinking five times mean
need to read inside diagram, will tell u what lights mean.
Jul 10, 2013 | Goodman Manufacturing MSG12CRN1N -...
1993 goodman status light 4 times blinking
Witch blower is running, the inducer or the systems blower?
System blower could mean the the high limit is opening and shutting down the systems gas train, I would check this out first.
The other problem could be with the pressure switch for the gas train, it is supplied from the inducer motor, check to see if it is operating fully.
HSI boards do go from time to time, this sounds more like a system control problem.
Jan 24, 2008 | Goodman GMS90703BXA Heater
I have a Goodman GMPN080-4 furnace. The light on the board blinks 3 times. The furnace won't light at all. What could be the problem?
Hi 3 blinks should mean it is the pressure switch there should be a code in the manual or inside of the door
Jan 30, 2010 | Goodman Heating & Cooling
Furnace main fan comes on but the furnace doesn't come on. The indicator red light blinks four times. What does this signify?
You have to get in to the main circuit board. At the bottom of the circuit board it will tell you what the flashes mean, in very small print. Read this print for you codes.
Dec 25, 2009 | Goodman GMS90703BXA Heater
Goodman Model GMNT100-4 Auto Power Down and Up until Temp.
Keep in mind all furnaces and circuit boards are not the same. Look on the back of the door to the blower compartment. You should find the list of diagnostic codes. Look up four blinks it should narrow down the problem. Although from the discription you gave it sounds lie the high limit control. When a high limit appears to be acting up it DOES NOT mean that the high limit needs replaced. The high limit just may be doing its job. This means that the furnace is overheating. Check your filters. Are all of your registers open? Is your blower set on the right speed? Is your blower going bad? Is the blower motor capacitor bad? Is your evaporator coil restricted? Just changing a high limit switch does not always solve the original problem!
Good luck....
Apr 01, 2009 | Goodman Heating & Cooling
Goodman furnace went out. Light blinks four times
Your main limit switch is activated. Maybe for good reason. This switch keeps the furnace from overheating. I have the same problem right now and I think my a/c coil may be blocked, limiting air flow through the heat exchanger and the furnace. Does your gas and main circulating fan come on for a few minutes before the switch activates and the light begins blinking?
Check your furnace filter and any return air ducts in your home - see if they are blocked or restricted.
Jan 14, 2009 | Goodman GMS90703BXA Heater
Four blinks goodman furnace
yes you can and it is on the heat exchanger just inside the front panel it is about 1and1/2 by 2 inches with two wires connecting to it, it has two screws holding it in place, it looks like it is a peice of flat plastic
Dec 21, 2008 | Goodman GMS90703BXA Heater
Goodman furnace 4 blinks
In the compartment with the blower moter there is a little (button) with two wires going to it.(it is attached to the top (you will have to look up in the compartment) if the unit is installed up and down and not on the side.) (If it is in sidways it is in the section between the two comartments). anyways.... on mine there is a little reset button right between the wires.... press it and see if it makes a click sound. try your start up procedure and see if the problem goes away... I don't know if MY equipment got too hot or if the switch is failing... but it worked for me.
Dec 21, 2008 | Heating & Cooling
Three blinks - what does it mean
The safety limit inside the blower section has tripped.
Oct 31, 2008 | Goodman GMS90703BXA Heater
GOODMAN CMA80905CXBA FURNACE. INDUCTION BLOWER NOT ENERGIZING. GETTING 3 "BLINKS" FROM DIAGNOSTIC LIGHT (LOW PRESSURE SWITCH OPEN). THE A/C WORKS & THE BLOWER FAN COMES ON WHEN THE STAT IS IN...
the pressure switch is closed before the draft motor closes it.the board is telling you that this is not right.pull the wire(either) off of the pressure switch to see if furnace tries to light.if it does,you should replace the pressure switch.
Oct 02, 2008 | Goodman Heating & Cooling
Goodman GMS90703BXA Heater Logo
136 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
