Question about Hotpoint Ultima WF860 Front Load Washer
Wont finish washing cycle
My washer will not finish a cycle on any program.after rinse it displays the figure 1 and will not progress to the spin stage.
  • badfer18 Feb 22, 2008
    mines draining well (no blockages) but persists with this same problem on the final spin,motor does go round but never picks up adequate speed.Witsend!!
    President:
  • 1,462 Answers
Suspect not draining. if not then problem could be the filter. at back, remove the small panel at the bottom. you will see a hose from the bottom of the tub to the pump. remove this hose at the tub end and the filter is inside.be carefull, if machine has not drained, a lot of water will come out. disconnect from mains of course
Posted on Jun 13, 2007
SOURCE:
Spin speed is slow
call the technician as the program is not progressing to high spin after the rinse cycle
Jan 21, 2017 | Speed Washing Machines
My Asko washing machine wont go into spin cycle it just keeps on washing after 3 hours I had to turn it off now what
call a technician in
the problem is most likely in the program board not progressing the wash cycle
Jul 12, 2016 | Asko W6021 Front Load Washer
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Why is the machine Not rinsing and spinning?
something is blocking it from draining so it wont spin and it wont rinse because it wont spin
Jun 10, 2014 | Brandt WFH1176 Front Load Washer
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
Wash doesn't progress to rinse and spin
This is one of 3 faults
1 you may have a problem with the heating cycle check element
2 you might have a water valve not working
3 there may be a program fault
These videos on how to change an element and water valve will help
Jul 22, 2013 | Bosch Classixx WFL 2066 Front Load Washer
Does not empty at end of wash cycle (not blocked or pump)
faulty program board not progressing
call a technician
Jan 01, 2018 | Hotpoint WMA46 Front Load Washer
The spin cycle wont start as the rinse cycle finishes i here two clicks 1 to 2secconds appart and then nothing
Not sure which model you have, but if it spins after the wash cycle, and not after the rinse cycle, it is more than likely the timer.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Washing machine not spining
You may have a problem with the rotor position sensor. This sensor is situated on the motor windings and should really be replaced by a qualified tech.
Nov 04, 2007 | Fisher and Paykel IWL12 Top Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
249 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
