Give me a codes of visual basic in converter measurement,,like area,weight,distance,volume,temperature,speed...
    An expert who has written 2 tips or uploaded 1 video tip.
  • 113 Answers
You should know first the value needed to convert- eg 1Liter = 1000ml
this code may be paste on command button or keypress on the text box.
Text2=val(text1) * 1000
Posted on Mar 23, 2010
How many milimeters in an ounce
Millimeters measure distance.
Ounces measure weight.
Cubic centimeters (CC) are commonly used to measure small volumes.
There are 1000 cubic millimeters in 1 cubic centimeter.
One ounce of water is about 28.35 CCs or about 28350 cubic millimeters.
Oct 17, 2017 | In Office Equipment & Supplies
I need to convert 300 grams of mascarpone italian cheese into something i can understand
Don't forget cups are measurements of volume not weight. It was so the old west cowboys could cook using their tin mug as a measure. The problem with converting weight to volume is as follows, a cup of sugar is heavier than a cup of flour. Whole almonds have air spaces between them. This site is a flour site, but lower down, cups of various ingredients by weight. With the two sites listed, you can convert everything. Good luck, I am a trade chef.
300 grams is 10 1/2 ounces
200 grams is 7 ounces
This calculator site will convert everything including grams to ounces and using the 'VOLUME' tab, grams to cups.
Kitchen Calculator MyKitchenCalculator com
Dec 10, 2016 | Kitchen Appliances - Others
Convert 264 sq ft to linear feet
Hi Mona:
I'd like to be able to help so will need to clarify the intent of your question. Bear with me while I explain.
- 264 sq ft is a measurement of area.
- Example: a room 11 ft wide by 24 feet long would have a floor area 11 X 24 = 264 sq.ft
- 264 linear ft is a distance measurement, and indicates the distance between 2 points.
- Example: A house that is 66 feet square has a perimeter of 264 linear ft. (4 x 66 = 264)
If you can take this information and apply it to your question, I should be able to give a clearer answer.
Hope this helps
Jun 11, 2015 | Heating & Cooling
How to convert cubic meters to square foot
That is something that cannot be done (cubic to square). You can convert cubic meters to cubic feet or square meters to square feet as follows:
Multiply cubic meters by 35.3146 to get cubic feet
Multiply square meters by 10.7639 to get square feet
Apr 01, 2011 | Office Equipment & Supplies
The ads for this device state that it uses the Pythagorean theorem to figure the distance of a 3rd side, if you can measure the other 2 sides. I How do I use this feature?
1) There is a big difference between Bosch promo manual and Bosch operation manual:
2) Online promo manual says: Combined Indirect/Pythagoras for measuring total height from a distance
3) Online operation manual shows no instructions for Pythagoras measuring.
And shows no button for displaying E value or height.
4) Operation manual shows:
Length Measurement** and tells you to measure the height while promo says tool will calculate height E
Area Measurement*** shows rectangle only and not triangle
Volume Measurement
Area or Volume
Rounding of Large Calculations
Continuous Measurement (Tracking)
5) I would contact Bosch directly:
6) Until you get satisfaction from Bosch, the Bosch device gives precise menasurements that can be entered into a Pythagorean calculator online, which defeats the purpose of a jobsite tool: But you can access online calculator via cell phone while on jobsite.
Feb 19, 2011 | Bosch DLR130K Laser Distance Measurer
Weight of 8 litres in pounds
You can't convert litres to pounds, at least not directly. The litre is a volume measurement, not one of weight (mass, actually). A litre of one material may not have the same mass as a litre of a different material, so a simple conversion factor doesn't exist.
If you know the specific gravity of the material you want to measure, you can convert the volume to a weight. Water is defined to have a specific gravity of 1.0, and 1L of water = 1 kg. One kilogram is approximately 2.2 pounds (you can look up the conversion factor if you need more accuracy). So if you are dealing with water, 8 L is around 17.6 pounds.
If you aren't measuring water, find the specific gravity of your material, and multiply by that value. A liquid with a specific gravity of 0.75, for example, would have mass of 0.75 kg per litre, so 8 L of that material would weight 0.75 times (or 75%) of 17.6 pounds. But without that specific gravity figure, you can't convert litres to pounds.
Feb 09, 2011 | Office Equipment & Supplies
Please convert volume of 4.5 cubic meter into the ton weight carried by a small vehicle
Cubic meter is a measure of volume. Ton is a measure of weight (or mass). The weight of 4.5 cubic meters of something depends on the density of that something. 4.5 cubic meters of air weighs a fraction of a ton. 4.5 cubic meters of water weighs 4.5 tons. 4.5 cubic meters of lead weighs more than 50 tons.
Feb 04, 2011 | Canon Office Equipment & Supplies
How many square meters per tons
Square meters is a measure of area (distance squared). Tons is a measure of mass (or weight). It makes no sense to try to convert one to the other. It would be the reverse of asking "how many pounds in an acre?"
Jan 21, 2011 | Office Equipment & Supplies
I want to convert the distance/speed from miles & mph to km & kph to assess the distance and speed after running?
Manual is here:
SETTING USER DATA The Sportline TraQ is equipped with an advanced Pedometer that measures Steps, Speed, Distance, Calorie Expenditure and Exercise Time. In order to ensure exercise data is as accurate as possible, you must enter your personal profile. 1. Scroll to User Data (display will read AGE) by PRESSING the MODE key. 2. PRESS the RESET key to enter the programming sequence. 3. Adjust Age by PRESSING the INFO key. PRESS the MODE key to Advance to Set Weight. 4. Select Weight Units (LB or KG) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 5. Select Units of measure (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 6. Select Stride Length Units (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 7. Adjust WALK Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set RUN Stride Length. 8. Adjust Run Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set daily step GOAL. 9. Adjust daily step GOAL PRESSING the INFO key and advancing to next digit by PRESSING the MODE key
Jan 02, 2011 | Sportline 370 Traq Motion Sensor Pedometer...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
