Question about Nikon D300 Body Only Digital Camera
Shutter speed won't go over 5 frames a sec. on d300
In the ch shooting mode my camara will not go over 5 frames a second.  Even with the mb-d10 battery grip with the aa batteries.  I would like to be able to shoot 6-8 frames a sec.  Any sugestions
  • poolguy22 Jan 14, 2009
    Thanks, it turns out I can't shoot more than 5 frames per sec in raw in jpeg not a problem.
  • 859 Answers
Even if your camera is rated at shooting more than five continuous frames at a time, those are stored in a memory buffer in the camera, when the buffer is full the camera writes the images to your flash memory card. How fast the memory card can accept the data will determine who fast space is made available in the buffer for a sixth or seventh shot.
The main limitation on how many images can be shot in continuous mode is based on the storage capacity of the memory buffer and also how fast images can be written to your inserted memory card.
So, the higher the resolution the image the more space it takes in the memory buffer. Should you shoot in a smaller resolution you should be able to shoot more frames continuously. However, there are a few variables involved. If the Camera is preset at the factory to not store any more than five images no matter what the resolution than there is no way around this encumbered feature. And, or the speed at which the memory card you use can accept written data will also decide how fast the buffer is cleared for new data.
The highest speed flash memory conforms with Version 6 and has a write speed of 188x.
So, the things to double check is if a limitation is built into your camera of five images and no more than five no matter what the resolution. This is not uncommon. The second is the speed at which data can be cleared from the buffer and written to the memory card, less common but a newer standard now that faster flash memory cards are becoming available.
Now, all that being said, There are 'firmware' updates released from time to time that make adjustments to camera features than can change these variables
Most Nikons use Compact Flash so see if you can get a high speed card that is version 6 compliant. But, first, check the sony support site for your camera and see if 5 is the limit no matter what. And if so, see if there is a firmware update under downloads at the support site that increases the number of shots that can be stored in buffer while being written to the flash memory card.
I have a client wtih a D60 who when she switched over to 133x Compact Flash was able to shoot more frames faster in continuous mode.
Please don't hesitate to use the comment text box below for any further assistance, such as the support page at Sony for your camera if you don't have in in yoru manual. Or any information you may need regarding shooting in high speed mode and what format to use. Most Pros that consult with me are using JPEG uncompressed. If you have questions please provide more detail on how you have your camera setup and under what conditions you are shooting in when attempting to capture more frames per continuous mode shotting.
Posted on Jan 14, 2009
  • Glenn Rogers
    Glenn Rogers Jan 14, 2009
    Keep your eye out for a firmware update that may increase the buffer for continuouse shooting and also suggest to Sony that they increase the number of shots in continuous mode as an option released as a firmware update. I only suggest this, but suspect the hard coded program in your camera may not be changeable in a practical sense.
    Good Shooting,
Film fast fowards 12 frames at a time. what could be the problem? it has a mb-21.
12 frames, in how long of a span? When you're first loading, or when you're holding down the shutter release?
The high-speed winder has a speed of about 5.7FPS when in Ch mode, if that's the issue, just rotate the dial on top from Ch, to S. If it's something else, please clarify. There's a small button next to the dial you'll need to disengage the lock.
It's got S(ingle) Ch (high speed continuous) Cl (Nornal continuous) Cs ("Silent" continuous) and Self Timer.
Jul 05, 2011 | Nikon F4s 35mm SLR Camera
I mounted the Canon 580EX II to my Canon 5D Mark II. When I using Manual Mode, I can't set the shutter speed more faster then 1/200 sec. Is this problem normal/limitation of it?
Yes. If you were able to set a faster shutter speed, then you would not expose the entire frame and would have the shadow of either the first or second shutter curtain (or both) partially masking the frame.
At higher speeds, the shutter is never fully exposed: before the first shutter curtain has finished travelling across the frame, the second one has stated it's journey. All SLR's have this issue and on some older models you could only use a maximum 1/60th of a second.
In practice though, in dark conditions the "slow" shutter speed does not affect exposure as the true exposure will be determined by how much light the flash puts out, and it puts this light out in as little as 50 microseconds (50 millionths of a second) for a modern electronic flash bulb.
Faster shutter speeds can be used successfully, but only with flashes which operate in high speed mode. What they do is to make the flash burst seem longer by rapidly firing the flash bulb many times. This trick can ensure that there is sufficient light to expose the frame at the highest shutter speeds. Shutters which operate at, say, 1/4000 may seem fast, but compared to the speed at which a single electronic flash burst operates, it's an eternity.
May 11, 2010 | Canon Speedlite 580EX II TTL Flash
Shutter frame rate drops to about 1 per sec on CH with MB D10 while using any auto focus lens. 14-24,24-70 or 70-200 and an older 20mm auto focus. With no lens or a manual focus, very old 55mm Micro, lens...
Wow, that's weird. Does it do it with the auto-focus switch on the body turned to manual? I shoot a D300 and know pretty much everything about it there is to know and the D700 is basically the same camera with a full frame sensor. The only things I know of that drop CH frame rate are shooting in 16-bit raw and it shouldn't kill it like that, using full-auto with tracking will also cause a lag in auto-focus but that still doesn't seem right here. If it only does it with the auto focus on then it may have trash on the AF screen in the camera and needs to be cleaned. Try setting the body switch to manual focus, remove the grip and shoot jpeg and see if it still happens. If it does, reset the menu settings and try again. If it still does it than you probably need to give it a trip to Nikon. If it quits than start putting things back one at a time until you figure out what is doing it.
Somebody told me that Nikon will clean the pro cameras for free once a year while under warranty, I haven't looked into it yet to make sure.
Nov 01, 2009 | Nikon D700 Digital Camera
My eos40d on sports mode is not shooting at its proper speed at 6.5 frames per second. it shoots 2 frames per second and the piture cones out orange and not focus I only have this camera four weeks any...
6.5fps is only the manufacturer's indicative maximum. The camera will not always perform at this speed when conditions aren't suitable (too dark, for example). In Sports Mode, the camera decides the correct shutter speed for that scene. If it's not a very bright day, shutter speed has to be lowered (slow) to compensate for the lack of light. This results in a lower frame per second.
If you want to test the max fps, set your camera on Tv, and set the speed to 1/1000+ on a bright sunny day. Set the Drive Mode to AI Focus or AI Servo. If at 1/1000th of a sec, the Aperture value blinks in the viewfinder, you don't have enough light. Increase the ISO. You should be able to achieve 6.5fps. That's my experience anyway. Good luck.
Sep 18, 2009 | Canon EOS 40D Digital Camera
Shutter speed actomatic change
If you move from mode to mode, the camera will remember the settings from the last time you were in that mode and reset to them. This is handy if you are in shutter priority shooting sports at a high shutter speed, and then want to take a picture of something that's not moving fast, like the crowd. You just pop it into aperature priority with a remembered settings of a higher f stop.
I use this to shoot the scoreboard, which has a fairly slow refresh rate and usually comes up blank if I shoot it at a shutter speed higher than about 1/100.
Sep 02, 2009 | Nikon D300 Body Only Digital Camera
Shutter is lagging with sb-800 flash attached. flash goes off, 3 sec later shutter goes
Have you checked the flash mode?
I have no problems with the combination D300 SB-800.
I assume you don't have a picture if the flash goes off before the shutter open(?)
If you do check the menu e2 Flash shutter speed you can set it at a few seconds in spite of the fact that the flash sync (e1) is something reasonable like 1/250
The flash shutter speed is set to 1/60 in my camera...
Aug 21, 2009 | Nikon D300 Digital Camera
I wanna take a picture but i dont know how to make the camara wait 10 sec before it takes the picture
Self-timer shooting:
This function lets you take pictures using the self-timer.
Fix the camera securely on a tripod for self-timer shooting. This function is useful for taking
pictures when you want to be included in the photograph.
1 Select [ON], and press Z.
2 Press the shutter button fully to
take the picture.
• Pressing the shutter button halfway
locks the focus and exposure.
• The self-timer lamp lights for
approximately 10 seconds, then starts
blinking. After blinking for approximately
2 seconds, the picture is taken.
• To stop shooting while in n mode,
press the shutter button fully again.
• To cancel the self-timer, press Z.
• The self-timer mode is automatically canceled after one shot.
• If sequential shooting is attempted in self-timer mode, the camera shoots 5
frames at most regardless of the setting.
Hope my info fixes your problem,
Thanx for using fixya,
Sep 26, 2008 | Olympus Camedia D-595 Digital Camera
How do you set up sequential shooting on an Olympus E500
Single-frame shooting o Shoots 1 frame at a time when the shutter button is
pressed. (normal shooting mode)
Sequential shooting j Shoots 4 frames or more at 2.5 frames/sec. (in SHQ,
HQ or SQ) for as long as the shutter button pressed.
Focus and exposure are locked at the first frame.
1 Press the </Y/j (Remote control/
Self-timer/Drive) button.
2 Use the control dial to set.
o Single-frame shooting
j Sequential shooting
3 Press the shutter button all the way to
take the picture.
Press the shutter button fully and keep it
pressed. The camera will take pictures in
sequence until you release the button.
Sequential shooting is not possible when [NOISE REDUCTION] (g P. 95) is set
to [ON].
During sequential shooting, if the battery check blinks due to low battery, the
camera stops shooting and starts saving the pictures you have taken on the card.
The camera may not save all of the pictures depending on how much battery power
The above comes from page 62 of your user manual.
Aug 23, 2008 | Olympus Cameras
Continuous High (CH) Shutter Mode on Getting Two Frames
I have just the opposite problem I can't get more then 2 shots per shutter click in any mode in my D 200?
Jul 20, 2008 | Nikon D200 Body Only Digital Camera
How do I figure out actuations on my camera?
Pre-PMA 2004: Canon today announced the impressively specified EOS-1D Mark II which features a new 8.2 megapixel CMOS sensor, it can shoot at just over eight frames per second and has a 40 frame JPEG image buffer (20 frames in RAW mode). This means that shooting at full resolution at full speed the camera is buffering 69 megapixels per second (or 100 MB/sec). Other changes include the addition of a USB port, an SD slot, the removal of the external white balance sensor as well as some subtle body styling changes.
Feb 25, 2008 | Canon EOS-1D Mark II Digital Camera
Nikon D300 Body Only Digital Camera Logo
142 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
