Question about UltraLast For HP Pavilion DV6000 and 2000 EA UL-HPEV088L
The processor of my laptop is rynning very slowly
It takes lot of time for start up & shutting down
    Guru:
  • 829 Answers
Boot the system , go to run and type msconfig and enter
go to services check disable all . and reboot the system. let me know after you do this you still face an issue.
Posted on Jan 14, 2009
My mini desktop is gatewaye1vision,amd not turning on but the power supply turn on how to fix
The first thing to check is to see if you have a dust problem! A lot of times the problem is that the processor heat sink is full of dirt. Take the fan off of it and do a good cleaning. Check to see if the air intakes are fouled. Intel processors have a safety feature that shuts down when the heat is too high. This is why it starts at first then shuts down. The heat is still an issue so the processor won't try and start again until the temps come down.
Jun 15, 2016 | Computers & Internet
Why does my laptop keep shutting down?
lot's of possibilities, Either your laptop has Virus, or the processor over heating, means it will probably need to di-assemble and replaced heating compound.. called thermal paste..
Jul 28, 2013 | Acer Aspire 5733-6607 Intel Core I3-370m...
ACER APSPIRE 5742 TAKE ABOUT 10 TIMES TO BOOT UP.
If there is extreme heat inside the laptop, this happens. Clean the fan and put new thermal pste/thermal pad to processor and chipsets. Also check for power button problem or any stuck keys in the keypad.
Hope this helps
Dec 11, 2012 | Acer Aspire 5742 Notebook
Black screen,no cursor wont start
It's most likely your ram... but it could be that your laptop fan was not working properly and you had processor issues, then the processor gave out... was your laptop running slow before this issue happened... Also did you receive blue screen error messages? One other thing would your laptop just shut down? If any one of these things happened either one could be your issue... If you could give me more symptoms, that would help a lot.
Dec 06, 2012 | Acer Ferrari 1100 Notebook
Hp g62 overheating
A good clean of the intake and exhaust vents is a good place to start.
Next up is to ensure that your notebook is raised off of the work surface (table) to allow greater airflow through the notebook to cool it's components.
Use a pencil or eraser, some-thing that will lift the notebook and not restrict airflow.
Another solution is to purchase a notebook cooler, some units have a built-in fan which will help a lot.
Take care!
damnor01
Sep 12, 2012 | HEWLETT-PACKARD G62-347NR Laptop
Slow start up and shut down
You didn't mention what version of Windows (Is it Windows, or is it Linux / other?) that you are using. For laptops in particular, windows sometimes gets confused as to which power saving state that the laptop should be in.
Next time that windows is running, you should see an icon of either a battery, or of a power plug in the area next to the clock (lower right corner). If you LEFT click on this, there will be a list of various power schemes that are available. MAX BATTERY will reduce the processor speed the most, while ALWAYS ON turns off power saving altogether, and allows the laptop to run at full speed.
If your fan always seems to be on, or seems to be cycling on and off rapidly even though you are doing little with the computer, then you might need to have the fan and heatsink cleaned out (consult a computer shop). When the processor starts to run hot, the motherboard will begin to slow it down regardless of the power scheme.
You might also be looking at a program that is loading during startup (did you just happen to install Open Office by chance?) that also takes a while to unload while shutting down. Consider what you have recently installed, and check your startup menu (click start >> programs >> startup ) to see what is being loaded there.
Feb 13, 2011 | Dell Vostro 1510 Laptop
Unexpected shut down of my laptop
It is quite possible that the laptop is overheating and the processor has a thermal shutdown circuit. Take a can of compressed air from an office supply store and blow the dust and hair out of the ventilation grills on the laptop. Once you do this, reboot the laptop and make sure the laptop fan is running. If a system has been run hot for a period of time, it is also possible that the thermal paste on the processor has dried up and has "caked" on the processor/heatsink lowering the efficiency of the cooling properties. In that case, the heatsink would need to be removed and a new layer of thermal paste applied.
May 24, 2010 | Computers & Internet
Laptop keeps shutting down for no reason leaving blank screen
If your laptop cuts the power off (shuts down) from time to time that may be overheating problem. Dust is blocking the air outlets on the fan and processor cannot be cooled down properly. Thermal protection shuts your laptop down when it reaches some certain temperature. Most likely you will hear your fan spinning full speed before the shut down and the bottom of the laptop is hot.
Best solution is to take it apart, remove the fan and the heatsink, clean them thoroughly, apply new thermal compound and assemble the laptop. Easy solution (though not the best one)is to buy compressed air can and blow it through the vents of the laptop. It will help for some time but occasionally it will start again.
Sep 06, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Crash!!
Could be Heat, sounds like the system is shutting down to protect the processor. Let it sit shut down over night and see if it runs longer when it's cooled down. Is the fan running?
Aug 29, 2008 | Acer Aspire 5315 Notebook
Computer Shuts down
Well your processor may be damaged..
dont worry may be it is not damaged so what do you do is that open the cover of your computer.... Then start it and keep the cover opened making sure that you can see the processor fan running...
See that if the processor fan is running...
then with the help of a torch see that may be the fan is being restricted or it is moving slowly.
this slowness of the fan heats up the processor and makes it shut down you PC
if the is running slowly take out the fan using the user guide of the processor and then lubricate it with motor oil.
it IT Does not work then there is a problem with your processor so please check by placeing another supportive processor and check it!
Dec 13, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
UltraLast For HP Pavilion DV6000 and 2000 EA UL-HPEV088L Logo
59 people viewed this question
Top UltraLast Computers & Internet Experts
David Payne
David Payne
Are you an UltraLast Computer and Internet Expert? Answer questions, earn points and help others
