Question about Samsung DLP HL-P5663W 56" TV
50 inch samsung tv has red tint n dis colored
Model number hnl5065w
  • 14 more comments
  • brandonbeasl Jan 14, 2009
    My brother inlaw works for Best Buy and he thought that the problem was the color wheel. He's the only person to look at it. The picture comes in, but it's mostly red and discolored.
  • brandonbeasl Jan 16, 2009
    ijust took pic of it do u got email i can send it couse the people on the tv have like red heat vision like wheres theres black n comeing off there face
  • brandonbeasl Jan 17, 2009
    this is wat it looks like
    and heres more
    do u see what im talkin about likha
    i dont get wat ur sayin but if i took in wat would i tell them to fix n wat u think it coast to fix
    or where would i get the part at or u got part number?
    k i can fix if u tell me so where do i start
  • brandonbeasl Jan 18, 2009
    just wondering if u gonna tell me how to fix or tell me where to get new part thanks get back to me soon
  • brandonbeasl Jan 19, 2009
    sorry to bother u again but what if i just bought a new ASSY
    I WONDERING
    IF I GOT A NEW ASSY PCB. POWER PART NUMBR BP94-00087A THANKS
    r u positive its not my color wheel i was told i dont have a correction amplifier can u pleas help me i would like to wach tv someday
  • Anonymous Jan 22, 2009
    hey u dont know **** ************* u make me by **** for my tv that my tv dont have u r a likey man that i dont kno u likha
  • racheltn Mar 29, 2009
    hi i am an electronic tech. and have the same problem with my t.v.. it is a samsung and model # is HL- T4675S. could you show me where to began? thnx.
  • Anonymous May 02, 2009
    alma, I have a samsung tv and red color is not adjusted, what can i do to fix it.1080i
  • 790 Answers
Hi
please try to reset the color settings then hit the tint color adjustment, if nothing change, you have a problem with the RGB Section that is need to replace some small parts!
Thanks!
Posted on Jan 14, 2009
  • 1 more comment
  • carlos fernandez Jr.
    carlos fernandez Jr. Jan 17, 2009
    can you take a picture or video? you cab upload here to see what exactly is your problem.
    Thanks!
    Hi
    This is defective ceonvergence correction amplifier... maybe the resistor are burn and need to replace. or the convergence output Ic...
    Thanks!
    you need a qualified technician to fix this issue. now if you are electronics technician i can teach you how to fix this issue!
    Thanks!
Samsung DLP tv white color turned to yellow
go into menu reset picture settings to default
red , tint or gamma is off
Nov 15, 2016 | Samsung Televison & Video
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
Have a 50 inch hlp506w model samsung projector tv. it had wavy lines through it, and then turned off. it is continuing to try and turn on with the standby/temp and lamp lights flashing. replaced lamp...
Change the tv Ballast board too.This board only job are to help it to ignite the tv projection lamp. This tv also have a colors wheel design into it too.If tv have colors pictures flashes or Black& White flashes within it pictures or tv have grinding noises or humming sounds,than the tv colors wheel it is warp and dead.This tv colors wheel must be replaced,because the colors dis wheel is warn out.
Jul 05, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung big screen tv model pcl542r has a green or red tint to picture
This is for the 50" Vizio TV,
It sound like the control board has a problem. There is two way to fix this.
- Upgrade the firmware of the control board, If you can find the firmware upgrade device.
- Replace the control board (I think this the best solution)
Feb 08, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Color problems
if you have hd cable or satellite box make sure the component cables are properly connected(green red and blue) and matching same color in source (cable box or satellite and tv as well)
also make sure in tv menu that color and tint are 50%
Jul 03, 2008 | Sony KP-57WS500 57" Rear Projection...
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Mar 20, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Phillips model 50p8341 titanium-finished 50-inch Red tint to picture
Your Red CRT may be on its way out. Try turning down the G2 screen control on the red CRT just a little. That should help for now. A new red tube wil be a reality in the future.
Jan 21, 2008 | Philips 50P8341 50" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
1,599 people viewed this question
Henry  Thomas
Henry Thomas
