Question about HP Photosmart 335 InkJet Printer
My printer will not read my photo cards
Printer is not reading phot card and has a code on small screen that reads co620004
    Guru:
  • HP Master
  • 829 Answers
Issue When using a large-capacity memory card (usually 128 MB and higher), the printer appears to lock up or freeze, and the printer may display an error message. Solution Allow the printer to completely read the memory card when it is first inserted before performing any action on the printer. If the memory card reader LED is blinking green, that means that the card is being read by the printer. Wait for the LED to stop blinking.
Posted on Jan 14, 2009
Why does it say file error in some pictures when I go back to see what photos I have taken after a few days.
Computer may not be reading the cameras media properly. Or the media card may be corrupt. If you have seen the photo previously that may be the problem. If you never saw the phot before in your camera it may not have written properly to the camera media. I'd take the media card out and see if my computer could read it directly from the computer card slot. If not, replace the media, and make certain to check to see if the camera has saved the photos from time to time.
Feb 19, 2015 | Samsung Cameras
Printer does not read memory cards or card reader
Here's the list of compatible digital media memory cards:
  • CompactFlash I & II
  • SmartMedia Card
  • Sony Memory Stick, Memory Stick PRO
  • Secure Digital (SD) Card
  • MultiMediaCard (MMC)
  • Microdrive
  • 4 Built-in Card Readers
  • xD Card
  • Sony Memory Stick Duo (with adapter)
Aug 11, 2011 | Lexmark P315 InkJet Photo Printer
Printer wont read SD cards does read sony memory
If it does not seat (fit) properly, why say the printer will not read SD cards? It certainly will read SD cards that are supported. You can still upload to computer and print from there as you suggested.
Dec 27, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
My printer (Canon MP830) will not read my memory card from my camera. an SD card. You can print straight from the card. I press "Memory Card" as the source on the top of the printer and select "Print while...
Did you let the camera format the sd card before you took your pictures? Have you tried another sd card? Its possible the pc did not close the card properly so the printer does not see it. I would try another card before going any further. Make sure your setting on the printer is set to read only (in "Other" settings) if at read/write you will not be able to print.
Aug 17, 2017 | Canon PIXMA MP830 All-In-One InkJet...
Protection problem
Easy solution:
1) Put the sd card into your computer
2) Copy all the photos to your computer. User Windows Explorer to just drag the folders from the card.
3) Format the card
If you insist on having the photos back on the card, then just copy them back to the card using Windows Explorer reversing step 2.
Aug 26, 2009 | Sanyo VPC-E760 Digital Camera
R300 will not read 2gb sd card
Hi
R300 doesn't support 2gb SD cards and there are no software updates that will make it read a 2gb sd card.
Hope this help
Dec 22, 2008 | Epson Stylus Photo R300 InkJet Printer
Problem printing pictures
That card is probably too big for that card reader in the printer to read. You have to have a card reader that can read Secure Digital High Capacity cards. The most you can probably get out of the card reader on the printer is either 1 or 2 gb secure digital.
You might be able to get away with using the pictbrige connection on the printer and print that way as long as the memory card is loaded into the camera.
If that doesn't work you will have to get a card reader that can read SDHC cards.
Jul 04, 2008 | Epson PictureMate (C11C618001) Deluxe...
Compactflash memory cards
If it will not read ANY type of flash media it would suggest the reader or main board is faulty.
If it reads some type but not others, look down into the card slots with a torch and check to see if any of the pins are bent over. This is a common fault most notably encountered when the machine fails to read CF type cards. You will see two rows of pins in the slot. Chances are one of the pins is bent or been pushed inwards. If you are REALLY steady with your hands you can use a very small (jewelers) screwdriver to straighten the pin. If the pin has receded, it almost impossible to fix it.
Aug 18, 2007 | Epson Stylus Photo R320 InkJet Printer
Printer isn'treading card
According to Lexmark's website, the printer will not read a memory card larger than 256MB. They specifically mentioned xD cards, but not cover the other types of cards. I have a 512MB SD card, and had the same problem, so I would guess it can't read anything over 256.
Aug 07, 2007 | Lexmark P315 InkJet Photo Printer
HP Photosmart 335 InkJet Printer Logo
234 people viewed this question
Ben Johnson
