Question about Cannon Digi Troll(Tm) Iv Eelectric Downrigger
Cannon Digitrol 1V bottom tracking not working
Have a Cannon Digitroll 1V downrigger. Have a problem with the bottom tracking feature which has stopped working. When I push menu then run the depth is indicated but the downrigger does not release cable to the specified depth. Does not move at all. Is there a sequence to reset the electronics
  • 76 Answers
Here is the user manual for your downrigger:
DT IV Downrigger
The programming starts on page 12.
Best of luck!
Posted on Sep 27, 2009
Cable jumps off of roller at end of boom
I've had the same problem with my electric Walker down-riggers, the line guides didnt work well because of the crimp for the cannon ball return pully snags on the guide, the best I came up with is a cannonball snubber similar to ones used with Dipsey-Divers, made heavier for cannonballs, hope this helps
Jun 04, 2012 | Electric Cannon Mag 10 Hs Downrigger
Looking for parts & service: mag 10A cannon downrigger
Your best bet for price is looking on ebay, there are lots of links off of an inquire.
Apr 12, 2010 | MAG Cannon Mag 5 HS Downrigger
Good morning I write from italy congratulations for the site I wanted to ask if I change the cannon digitroll from feet to meters thanks
I believe they only come in ft......Thanks for the kind words about the site. I am glad to try help others,I find it all comes back to 'ya..
Catch a big one !!!!
Dec 24, 2009 | Cannon Digi Troll(Tm) Iv Eelectric...
Cannon downrigger
score along the seam with a razor knife just below the cover where the screws are you need to reach an 1/16th inch deep insert a screw driver into the rubber gromet where the power cord goes in and pry open the cover be very carefull not to use any of the insides as a lever and use finess not brute force
Oct 04, 2009 | Cannon Digi Troll(Tm) Iv Eelectric...
My new cannon lake troll line counter doesn't seem to work? What is up, am i doing something wrong. This counter is on the boom and not as simple as the easi-troll...HELP
Make sure the cable is actually running in the pulley. The pulley is geared to the counter, so if the cable isn't turning the pulley, the counter won't be working.
It is quite possible to add a simple counter like the Unitrol series. (key #'s 12 & 13)
Here's a schematic for both:
Cannon Laketrol
Cannon Unitrol
Hope this helps!
Sep 27, 2009 | Cannon Lake Troll Manual Downrigger
A)will not work at all,had radio shack test out the fuse and switch;said they were fine,direct wired motor to batteryand the motor worked fine in both directions and b)have another downrigger that once the...
I may be able to suggest a cure for downrigger #1. The switches sometimes have several terminals and they work differently than they look.
For example, if you have 6 terminals, 3 on each side of the switch. The left bottom and right bottom are a pair. The middle two are a pair and the top two are a pair. Then you have terminals that are separate on the right side with the middle terminal being common and the pair being right lower and middle, right upper and middle with corresponding left side action.
This point being that the switch for unit #1 is good as tested by Radio Shack. Its where you stick the wires on the terminals that is the problem.
You need a multitester and use an OHM setting without juice flowing through your wires. This way you can figure out the pairings of the terminals without burning something up.
Aug 21, 2009 | MAG Cannon Mag 5 HS Downrigger
Used (older) Cannon Digitroll II Manual or advice
I have the quick start manual for digi-trol II. I will try to scan it and post later today.
Jun 20, 2009 | Cannon Digi Troll(Tm) Iv Eelectric...
Cannon Digi Troll(Tm) Iv Eelectric Downrigger Logo
444 people viewed this question
Top Cannon Boating Experts
ray gallant
Fabrice Wolters
Are you a Cannon Boating Expert? Answer questions, earn points and help others
