Question about Linksys Wireless-G WRT54G Router
Cannot access router webpage
I have a WRT 54G wireless router which I have been using as LAN router for about 2 years. Now I want to enable the wireless network in order to add a laptop but cannot access the webpage of the router.Two years ago, I was able to access the router just fine, at 192.168.1.1 The LAN configuration I have now consists of a PC Windows XP, the WRT 54G and a DSL modem. I can access the webpage for the modem OK, but not the webpage for the router. Please help, I need to connect my new laptop to test it before the 7 days of return expire. Thank you Floarea
  • Cris Radu Jun 18, 2007
    Thank you for your suggestion, I followed it but the situation did not improve.
    So,I disabled my McAfee virus scan and set the McAfee Firewall to Open Setting ( because it did not have an option to actually disable it).
    But I got the "Page Cannot be Found".
    Then I tried a couple of connection changes, here they are:
    1. PC connected to Linksys router connected to DSL modem. In this situation I tried 2 things
    First I triedhttp://192.168.1.1 but page could not be found.
    Then in the Command Window
    ping 192.168.1.1 for which I got :
    Request timed out.
    Request timed out.
    Request timed out.
    Request timed out.
    2. PC connected to Linksys router ( DSL modem disconnected). In this situation I tried thehttp://192.168.1.1 again but got page could not be found, again.
    Destination host unreachable.
    So, we still cannot access the router page, even though we are currently connected to the Internet, through the same router.
    Can you help?
    Thank you
    Floarea
  • Anonymous Nov 01, 2007
    I tried typing in http://192.168.1.1 and keep getting a message that website is unavailable.
Make sure your firewall and anti-virus are switched of then try and connect to the webpage
Posted on Jun 13, 2007
  • gmd duncan Jun 13, 2007
    It's worth a try GMD
Wireless 2.4ghz router for wifi
Wrt54g can be used as either a wireless router or access point. I am not familiar with your broadband service, but if it has a data port just connect it to Internet port.
Nov 02, 2017 | Linksys Wireless-g 2.4 Ghz Broadband...
I need to reset the password on my linksys Wireless GBroadband router WRT 54G without ruining my wireless set up in my house!
Use an Ethernet cable to connect your computer directly to the router.
Access the web-server "inside" the router.
Login to the router, with the current ID/password.
View the wireless settings:
* SSID
* encryption-level ('WPA' or better, please)
* network password
and change it, if you need to.
Feb 21, 2011 | Linksys Wireless-G Broadband Router
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys Wireless-N WRT150N Router
Hello, I have a Linksys Router model No. WRT 160N and have problems with the wireless signal. Doesn't appear the wireless symbol ON and I have connected already the modem cable. The modem is OK cuz I can...
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
Then do this
1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte)
2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router.
4. Log-on to the Linksys WRT-160N Router with these log-on credentials:
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router.
Sep 15, 2010 | Linksys WRT160N Wireless Router
Belkin g wireless modem router f5d7634 always disconnect
try to reduce the MTU settings on your router.
If possible upgrade the firmware of the router.
Click here for more info about the networking
Oct 07, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Connecting a linksys wrt54g to a netopia modem
Is this an ISDN modem?
Generally: Netopia Ethernet out -> Linksys WAN port with a standard ethernet cable.
(Not the yellow LAN ports! - They are for your computers/printers.)
Dec 28, 2008 | Linksys Wireless-G WRT54GS Router...
Wireless router installation
Please see my response to this question. Your university's connection is most probably a LAN connection, so you'd need to follow the instructions as if you had a cable internet connection (unlike DSL, a LAN connection and cable internet connection don't require authentication with the ISP).
Jan 07, 2008 | Linksys Wireless-G Broadband Router
WRT54GS DEVICE-NO INTERNET CONNECTIVITY
You didn't specify if you're using DSL or cable internet.
With DSL, keep in mind the software1.gif on the PC is what "dials out" to the ISP with your name / password, and you MUST set the name and password in the router. Otherwise, ONLY the computer that has the software installed (verizon, etc) will be able to connect.
Also, make sure that ONLY the LAN is connected from the router to the modem, and not both the USB and LAN.
If you're using a cable connection, you don't have to do this, however, most newer Linksys routers come with a 'setup' disk, which MUST be used regardless of connection type.
Oct 09, 2007 | Linksys Wireless-G WRT54G Router
ROUTER CONNECTIVITY
Ok, do a troubleshooting session.
Unplug the router from the internet modem.
Try at first to connect using a Network cable from you PC to one of the LAN sockets.
Can you access http://192.168.1.1  with your web browser?  (the configuration page)
     If yes it is possible that the router has the same address as your adsl modem.
    change the router address to something 192.168.0.1 instead of 192.168.1.1
     Save your changes. Plug your WRT to the adsl modem and try again.
     Does the internet work now with a wired connection ?
If the above does not work can you "ping" the machine ?
      ping 192.168.1.1
if none of that works try doing a hard reset... heres a little guide (off the DD-WRT wiki)
http://www.dd-wrt.com/wiki/index.php/Reset_And_Reboot
What is the difference between 802.11g and 54g?
54g implements the latest draft of the IEEE 802.11g specification. The two primary distinctions between 54g and 802.11g are: 1) 54g is designed to enable 54 Mbps connectivity. The 802.11g draft specification makes 54 Mbps connectivity optional, and simply requires up to 24 Mbps connectivity to comply with the specification. 2) 54g products are based on the same wireless LAN chipset, which means they are interoperable. Because the standard is not final, it is not yet possible to test for 802.11g interoperability.
Feb 16, 2006 | Belkin (F5D72304F5D7000) Router
Linksys Wireless-G WRT54G Router Logo
308 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
