Question about Nikon Speedlight SB-800 TTL Flash
When i take pictures flashes comes for one time and then for three it does not then again for one
  • Anonymous Mar 15, 2009
    I have the same problem; just started happening last night.  I know the batteries are good.  The flash ready light comes on, I try to shoot, and the flash goes off, but is really underexposed.  If I wait quite a while, 30 seconds or more, then I can shoot one properly exposed, but if I wait just long enough for the flash ready light, the next 3-4 are going to be underexposed.  I have fresh batteries in it and the the additional battery chamber.  I use Sanyo Eneloop batteries (Love them).  Thanks so much!
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Do you have fresh batteries? I know this can sound like a dumb question to ask but it has to be asked. Sorry, I don't mean to offend.
    Worldvet
    Scholar:
  • 170 Answers
The problem is typical of not having enough power in the battery. Are the batteries fully charged? Are you using Alkaline batteries? If so, get a good brand of rechargeable NiMH batteries. I recommend Sanyo Eneloop. It costs more, but it's worth the trouble.
Also, I hope you got the 'quick refresh battery adaptor' with the SB800. You can put an additional batery in this chamber and attach it near the main battery chamber after pulling out the cover. This will certainly improve the flash recycling time.
Posted on Feb 04, 2009
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
I have a SONY KF-WE50 rear projection tv, a few weeks ago it started to turn the pic and sound off while the green light was flashing around 30 times. After the light finished flashing both the picture and...
the green is the reboot process and is normal.
the red light is an error code indicator.
count the blinks of the red light...it cant be 30 times (I think)
it will blink a sequence, pause, then do it again for a total of three times.
count carefully, it gives you three chances to catch the number it is blinking.
Apr 13, 2011 | Sony Televison & Video
LCD TV HAS THE PROBLEM, THE PICTURES ARE FAINT AND THE COLOURS UNCLEAR, SO PLEASE HELP ME TO SOLVE THE PROBLEM
you might have some dust inside the light engine you should dust out your TV set and if you clean the TV and still have the same problem then I would say you have a problem with your optical block
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!!
Oct 11, 2010 | Sony KDF-E50A12U 50" LCD HDTV
The power light flashes 3 times the pauses, then three times again. No Picture. If I unplug the power and plug it back in then hit the power button it acts like it trys to come on then pops off and fashes...
Thats the error code for Convergence shutdown. You can get the PT53WX53 convergence repair kit from www.tvrepairworld.com which is the correct one for your model. The kit contains the parts and the CD with instructions.
Nov 25, 2009 | Panasonic PT-47WXC43 47" Rear Projection...
I have no picture on my sony KDF-50WE655
check the fan again with a flash light. I had this same problem and changed out the large fan behind the bulb...no more problem. my brother has the same tv and he has had to replace the fan at least three times.
Jun 08, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sonyy w55 flash works but shot come really dark
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
Aug 21, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Flash on Cyber-shot DSC-W50 not working properly
hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and
Dec 27, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Nikon Speedlight SB-800 TTL Flash Logo
88 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
