Question about Maytag MEC5430 Electric Cooktop
Regular spill stain problems
Can anyone recommend a good solution to remove water spill stains from the cooktop? I don't seem to have the same problem with oil stains, and I've tried almost every cleaning solution out there but it seems to keep on setting at every spill. Would appreciate any info. Thanks.
    Scholar:
  • 145 Answers
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Posted on Aug 23, 2009
SOURCE:
I cleaned the sump of my DCS 36 inch cooktop with easy off as instructed but it left a black stain on the aluminum bases. I have asked DCS for some help but it's been over a month a they don'
Youre gonna hit me... Soak it with lemon juice then clean with water. And next time you gotta clean metals, use vinegar+salt or sugar + olive
oil.
Jul 05, 2012 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
How do I clean my new electric Jenn-air cooktop with its glass top? Do I need a special cleaner for the glass?
  • Step 1 Wipe up spills as soon as they happen with a clean dry towel. According to the Jenn-Air website, for glass top cooking surfaces, you should do this even if it is hot since it will be harder to clean up later. Be careful not to get burned.
  • Step 2 Use a cooktop cleaner once it is cool. You can also use dishwashing detergent and water or just a baking soda paste (made with water).
  • Step 3 Apply the cleaner to a sponge, cloth or paper towel. For more stubborn stains, you can use a non-abrasive or "scratchless" pad.
  • Step 4 Rub the soiled areas until clean. Rinse well, especially if you used the baking soda paste as that can leave a residue.
  • Step 5 Use a razor blade for burned on and crusty stains that will not come off using the previous methods. Jenn-Air states to hold it at a 30-degree angle to carefully remove the stain.
  • Or you can use this on the link below.
    http://www.amazon.com/Blue-Ribbon-88100-Cooktop-Cleaner/dp/B000HM5INA
    Good Luck and please rate 4 thumbs up for the free answer
    Jun 25, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    Cant get food stains removed from top of stove i use a special cleaner and a special scrub and it still doesnt come off. it can be any kind of stain. the new stove tops are very hard to clean. any help...
    I recommend a product called of all things "barkeepers friend". It comes in a can with holes in the top to sprinkle the powder out of.
    Moisten the stubborn area and sprinkle this product on the stain then add enough water to make a paste. Make sure the paste covers the entire stain. LET IT SIT FOR AT LEAST TEN MINUTES. Then rub with a wet cloth. It always works for me and I have a black stove.
    Jul 27, 2009 | Stoves 12 in. (1248-1100) Electric Cooktop
    Has anyone figured out a way to remove the dark stains that you can't get out on the ceramic top with the recommended cleaners?
    no any kind of chemical u can use to remove the stain,coz its normal for ceramic hob cooker coz of pots n pons every time u use.
    Jul 02, 2009 | GE 30 in. Profile JP350 Electric Cooktop
    Burnt on stains on the inside glass door of my kitchenaid oven
    DeBruce Polish should remove those types of problems and also render the surface more "Cleanable". This stuff really works on glass anomalies.
    Check out debrucepolish.com.
    DEBRUCE METHOD on You Tube
    Apr 11, 2009 | KitchenAid 32 in. KECC508 Electric Cooktop
    My Jenn air range top is becoming stained.
    Mar 26, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    Stains on black cermaic oven top
    Use DeBruce Polish I guarantee great results, also perfect on stainless steel go to debrucepolish.com
    Mar 06, 2009 | Wolf Range 18 in. SPR-100 Gas Cooktop
    Staining of kitchenaid glass top digital control unit
    Have you tried using a razor blade scraper. Also I have found Ceramabrite cooktop cleaner to be a very good product. There is also a less abrasive scouring pad available specifically for glass cooktops.
    Jan 02, 2009 | KitchenAid 30 in. KECC506R Electric...
    Cleaning glass cooktop surface
    I used Mr. Clean multi-surface and the green, back side of the sponge. Turned on a light to show visible stains better, and scrubbed away. It didn't scratch the glass and got it out quick. Hope this helps.
    Jul 20, 2008 | Jenn-Air JED8430 Electric Cooktop
    Soapy water stains under sealed glass cooktop 4 rround burners about 6 years old
    You should never use large amounts of water on any electrical appliance. If the moisture is under the glass, it will need to be replaced.
    always unplug electricity before attempting to repair on any electrical appliance
    Sep 08, 2017 | Cooktops
    Maytag MEC5430 Electric Cooktop Logo
    154 people viewed this question
    Top Maytag Cooktops Experts
    Harry Miller
    Level 1 Expert
    Marvin
    Marvin
    Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
