Sir,
when i try to format my pc ,it ask for drivers through third party like floopy disk.
i provided the drivers from motherboard cd but it is not taking & i'am unable to do formatting.please provide a solution.
mother board is psvd2 vm -se .
Reboot your computer. Go to your bios setting by pressing Delete key multiple times 'til it enters to your Bios Setting setup. Find the Boot Sequence menu. Set it to CDrom, floppy, Harddisk drive(HDD). Save the settings by pressing F10. Save and Exit it. Insert your Operating System disc. A message will appear "Press any key to boot from cd", you can Press the Enter key. Wait 'til the windows set it up.
*Drop me a comment so I can assist you if you have problems.
You have to chose the driver for your operating system and create a floly disk with it.
To create a floppy disk boot with your motherboard CD and chose the option to create floppy disk (WINXP)
If you are using windows Vista you can directly chose drivers form CD.
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
hope this helps
drive
drive select format
hope this helps
