Question about Canon PIXMA MP830 All-In-One InkJet Printer
Wont scan from adf. also bends corner of paper when printing
Wont grab paper from ADF.
    Guru:
  • 829 Answers
F your printer is unable to pick up paper and the feed rollers are turning, remove the rear access door and clean them with a cloth moistened with water.
Posted on Jan 14, 2009
Cannot print screen shows ADF.what does this mean?
Hi!
ADF stands for Automatic Document Feeder and it means the device mounted on top of your pixma that allows multiple pages to be scanned/copied/faxed one at a time automatically.
Now why does it not print? The machine "believes" some document is inserted in the ADF in order to be scanned/copied/faxed, and wants that operation to be completed before it accept any print job. Please remove, if present, any paper from the ADF. Maybe its only some small piece of broken paper or even dust on the sensor in the ADF.
Aug 08, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
HP OfficeJet 8500 ADF detects load, but does not detect feed. I have a brand new HP OfficeJet 8500. The ADF detects a document is loaded when I stick a piece of paper in it to be copied/scanned/faxed, but...
Remember that if you start to fiddle you void your guarantee, I know its a pain, but if I were you repack and either contact customer services and obtain a return invoice number if purchased over the internet and return to sellers. If purchased from a shop, return with your prove of purchase.
Mar 19, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Fi-6130 not grabbing paper, displays Code: DS32002
My scanner is Fujitsu M4097D. I just have problem with ADF: Error Code DS32002: Paper jam in the ADF. Here is my solution: 1. Bend two white platin pieces down a little bit in order to "sensor" the paper scanned. This problem is occurred after I am scanning 50 thick pages. Until paper count 42, it is stopped with error code DS32002. Hope help anybody having this problem.
Jan 06, 2010 | Fujitsu ScanPartner fi-5120C Pass-Through...
How to print using ADF feeder?
You take the paper with face to print Up and the top of the paper towards the interior of the ADF. You can also put a stack of papers. When you press the copy/scan command from the machine console or the computer, the automatic document feeder starts.
Jan 06, 2010 | Brother MFC 6490CW InkJet Printer
Paper jams when using the ADF. Canon IC D780
When using ADF
Note:
* Set a document on the Platen Glass if you want to scan it at optimum quality,
* The area (range) within 0.08"/2mm from the top edge if document cannot be printed since the machine cannot scan it.
*Do not load the following types of documents in the ADF. They will jam.
-Wrinkled or creased paper
- Curled paper
- Torn paper
- Paper with holes
- Carbon paper or carbon-backed paper
- Surface treated paper
- Onion skin or thin paper
- Photogragh or thick paper.
1) Remove any documents from the PLaten Glass.
2) Open the Document Tray.
3) Load the document in the ADF.
Load the document with the side you want to copy, or scan face up in the ADF.
4) Adjust the Doument Guides to match the document width.
Note :
Ensure that the edge of the document stack is in line with the Paper Size Mark imprinted on the Document Tray.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Nov 30, 2009 | Canon Office Equipment & Supplies
Canon MX330 - trying to use ADF. No doc inside on
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
Sep 11, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper is not feeding into the top.
I also was not able to copy, scan or fax multiple pages through the ADF of our HP Officejet 7210 AIO, but it would print well from the computer.
It would either grab several pages at once, or not grab paper at all. The device was trying to work but had poor traction action. Not sure if that's the same issue you are facing, but if it is, this is what fixed my 7210: I purchased part number C7309-60091 which is the feed roller assembly, and part number C7309-60076 which is the separation pad from Encompass Parts, and replaced them. The ADF works great now. The HP Officejet 7210 had only 5,000 pages printed on it, so I chalked it up to our very dry atmosphere here.
Jul 10, 2009 | HP Officejet 7210 All-In-One InkJet...
The ADF Konica Minolta causes paper jamp or may bend 1 corner of
check there are two locking claw for uper cover of adf one is broken check and replace if necessary
Apr 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
ADF will only feed one sheet then stop
no,just try to clean the roller of the ADF at the same time the separator pad.make sure that you are using paper that is 24lb weight coz if you are using paper that is so thin if may cause also an issue that the ADF could not pick-up...if the issue is still occuring return/replaced the printer...
send feedback for further troubleshooting...
Aug 23, 2008 | HP Officejet 6310 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
227 people viewed this question
old marine
old marine
