How to correctly use ducted air cond control Avion/micron? brand
My house is 10 to12 years old it is fitted with ducted air cond system universal brand 3 phase 16.kw, 3 Zones, 10 outlets, approx 28 square home I am wondering if I am using the wall control properly to get maximum performance I have no manual to understand the operations how can I work it out. Note I recently had it regased and the dampers checked but on a cold day! It does not work very well????
Thanks Steve
    Scholar:
  • 89 Answers
Well Steve
The fact that it was cold shouldn't make a difference if the service tech knew what he was doing. ok now as far as getting it to work correctly. before you start any work on this thing. please dear god make sure the power is off to it and you check it with a multi-meter. just recently i got lit up by 480 volt 3 phase. 3rd degree burns on my arm and hand and many other things. so please cut the power off at the braker. ok you want the wall mount in a central location about eye level or just under. the universal highth is 5'5 but its all up to you. another thing you can do is change your remote to an all electronic one. you can pick one up for as little as 15$ most are simple though some can be a pain. also make sure that both the evap coils and condenser coils are clean. ensure that all fans are working corectly and that your compressor is pumping right. unless your pretty AC savvy you will have to have a tech come back out. the bad thing about AC systems is its never just one thing. good luck hoped this helped you
Jason
Posted on Jan 14, 2009
How to replace a/c air filter on 2010 camry
Hi Yip Jimmy, Depending on the type of air cleaner housing fitted to your vehicle flip back the two clips on top and open the housing, you will then be able to remove the air cleaner element and slide in the replacement. Make sure it fits in the correct, way where it seals If the earlier version is fitted, loosen the clips holding the ducting and twist the whole duct carefully to loosen it. They have a habit of breaking so be careful. Flip open the two clips and lift the lid. It has two hinged flanges on the side closest to the fender. Once it is at the correct angle, the whole lid comes off. make sure the element is fitted correctly and the seal is good all the way around and fitted correctly and reassemble. You're done! Regards John
Jul 02, 2012 | 2009 Toyota Camry
Where is low port to recharge ac?
Near the firewall you have both air cond pipes coming out. There is a black cap on the larger of the two alum pipes. It is under the air filter housing and should be able to see it without removing the air filter housing. That is the low pressure side.
The high pressure should run along the chassis rail and near the radiator there is another black cap on a smaller alum pipe.
Remember always yes always vacumm the air cond system for at least 3 hours to dry out the air cond system correctly. If you don't if will only work for a short time before playing up again.
Some shops don't do this and wonder why a car keeps coming back for more gas. Good for them bad for customer.
Jun 16, 2011 | 2003 Ford Ranger Regular Cab
Have an approx 20 year old Honeywell ducted air conditioning unit in my just purchased villa. It is not working. Am having trouble finding someone to quote to repair it. I live in the southern suburbs...
If its 20 years old it would benefit you much more to replace it, see the energy star website and it has information on when replacement is the best solution. Over 10 is the general rule of thumb if it over 10 then replacing the equipment will benefit you so much more than a repair. Also honeywell doesn't make equipment anymore and i cant say vie seen one but that doesn't mean its not out there, vie seen Chrysler air conditioners in houses and honeywell dose make controls but not equipment anymore (in fact this is the first honeywell unit vie heard of).
Oct 01, 2010 | Honeywell Heating & Cooling
Got a pyrox comfort control ducted gas heating system cant heat house above 19 dec have to keep hitting reset button every 10 mins, have cleaned the filter still doing the same, have heard the comfort...
on the reset switch there should be a temp. cut out take a temp. reading and see if it is realy getting as hot as the switch is rated for maybe the switch is bad
Aug 11, 2010 | Heating & Cooling
We have a one year old home and started to notice
do you have floor or ceiling vents, and does your house have concrete flooring or do you have a crawl space under depending on the answer because if you have a unit that is all outside then the duct may not be sealed
Jan 08, 2010 | Ruud UBHC Air Conditioner
High pressure air cond line has frost about 10 feet inside home
You have a low freon charge or a blockage in air flow. Check the filter if it is clean then there is a low freon charge in your system in which an a/c tech will be needed.
Good luck on repairs
Dave
Jan 06, 2010 | Amana PTH123B35AJ Air Conditioner
Operating instructions
the em switch is back up heat
Jan 30, 2008 | Heating & Cooling
Heating & Cooling Logo
161 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
