Question about RCA F32695BC 32" TV
Lacking red RCA Home Theatre Premier F32695BC shows little if no red in the tint for adjustment when viewing any channel but the red is fine in the initial setup screens. The picture is perfect on the far left and far right 2 inch sides of the screen but the middle of the screen is predominately blue or green depending upon how the tint is set. Don't think its the red gun itself since the red is perfect in the setup screens. Is this something that can be corrected in the hidden adjustment screen with different values? Any suggestions?
  • 790 Answers
Hi
in this case you have defective CRT Circuit System, CRT means The Cathode Ray Tube... Circuit system. this need to diagnose the System IC. if you know how to repair electronics appliances i can teach you how to fix this issue..
Thanks!
Posted on Jan 14, 2009
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
Hi, I just bought a Philips HTS3540 home theatre system and I am having problems hearing the TV (Sony Trinitron) through the home theatre system. The DVD / CD / Radion work fine on the philips, but I...
Ok my situation is similar-i did exactly as u described here bobhifi and it worked initially . Then after some weeks suddenly the Aux display now shows 'AV1 Coax' and no sound is coming out of my LG DVD speakers except under Tuner and DVD modes. Pls help
Mar 28, 2011 | Philips Televison & Video
I have an RCA G32705 TV and it will not turn on anymore. It worked fine a few hours earlier, now it makes a squeeking noise. Any suggestions?
Hi - it's a good set, I have a 32695 which is a year older (1999). Top of the line Home Theatre Premier series. Common problem, it is the EEPROM chip on the circuit board. Very common problem to lots of RCA, GE, and Proscan. Shows up with age and yours is about ten-years old. If you like the set (I like mine) you might want to seek out an estimate for inhome service. I'll bet it will be well over $150.
Feb 27, 2011 | RCA G32705 32" TV
GREEN TINT TO ALL DVD'S PLAYED
Your red component cable needs replaced or your red component input in either your DVD player or TV needs replaced.
Jun 13, 2009 | Panasonic SC-HT730 System
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
Connect the PS3 with HDMI to the Home theatre.
Connect the TV digital optical out put to the optical input cable of HT-BD2R provide your tv has a optical digital out put
You have the option of channeling the out put through either optical or HDMI in PS3.Go to the set up and set the audio out put to HDMI
Nov 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
PROBLEM HOME THEATRE SYSTEM HTDS490
Hi, Ive had the same problem and after talking to Samsung Tech Support, I re-checked all my speaker wires and thier connection... one wasn't quite making proper contact so I adjusted it and PRESTO all better!!!!!
Sep 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Home Theatre System
well u can run direct tv to tv then the tvs master digital out to the rca digital in or anlog rca cable
Jan 27, 2008 | Audio Players & Recorders
Rca home theatre big screen tv
# 1 above you have covergence problems ,there is a service flash from rca to fix your fault,ask your tv shop. fault # 2 above turn off the color and adjust your screen settings for a grey picture,set brightness and contrast to middle settings. # 3 fault read #1 cause if your auto focus will not correct you require service there is a harness connector that looses connection and causes several fualts on the 52" rca's you can repair the fault but if you miss the harness replacement you will do it again.
Dec 01, 2007 | RCA 32F531T 32" TV
Televison & Video Logo
100 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
