Question about HP Pavilion ze4145 Notebook
Fast dying battery and not charging
Ok i got this computer like 5 years ago, bought it (5 months old-new from Best Buy) from a friend who took very good care of it.. this computer was originally sent in (2 months old) to be fixed for overheating. came back and no more problems with over heating. was later sent in (about 2 years old) to have the hard drive replaced under warranty) the original battery was shot. wouldnt hold charge and wouldnt work unless the power cord was plugged in. got a new battery (about 3 yrs old) just before the warranty was up. so now i have the newer hard drive, newer battery.
my issue is... the battery will *sometimes* stay charged for a full hour. most of the time the "full" charge (as indicated by the green light on the front) only lasts about 30 mins. nd takes about 15 min to "fully charge again" outside of that the power cord only charges about 30 percent of the time. use to have to wiggle it a little and it would charge again.. recently i've had to tape it to the side of the computer (so it doesnt get wiggled) to keep it charging.. now... if i set it down or pick it up... anything that might jar the jack just a little tiny bit.. it stops charging. which is now getting frustrating because if i dont notice that its no longer charging, the battery goes dead and the computer goes into stand by (i have it set to go to stand by at 10%) sometimes it warns me that the battery is low (Warning set for 30%) and sometimes it doesnt. i did notice that the jack is loose... when i wiggle it.. now it actually moves the little peg inside that the power cord goes over..
the only other issue i have had.. is that the hole that the screw goes into to hold the top part in place... the bottom broke off... so when i open the computer too far... (farther than 90 degrees) the mesh part above the keyboard area pops up. just the side where the power button is. hasnt been a problem.. not to worried about that part unless its part of the power problem.
any clue as to what might be wrong?? or what i might need to fix? should i just cut my loss??
  • HP Master
  • 32,281 Answers
To fix the laptop would not be cheap, it needs to be pulled apart completely (it would be time consuming) to get to the motherboard and the power jack. You could do it yourself. I suggest you get a temperature controlled soldering iron for this job.
Because of the age of the laptop, I would put my money towards a new or a newer 2nd hand laptop. You could take the hard drive out of the old laptop and put it into a USB hard drive case and use it as an external portable hard drive.
Posted on Jan 14, 2009
Have your alternator tested
My 2003 Toyota Camry just killed, it started with a jump but something sounds drastically wrong. Had it towed...what could be wrong?
If it started with jumper leads OK, that's a strong indication it needs a new battery. It would not be unusual for a car to be sold with a weak battery. They last 3-5 years and then lose the ability to hold a charge, so you can drive the car around, but then it can still fail to start.
Since you have to buy one of these from a battery shop, ask them first to test the old battery and explain what is happening.
Jan 04, 2012 | 2003 Toyota Camry
I bought a new battery from cadillac dealer not even a year ago, and its dead again. They are wanting to charge me 250 for this. Shouldn't there be some type of warranty on this?
What king and type of battery? A delco battery ACDelco Professional 7-Year Battery Also available in 6-Year and 5-Year models50-month free replacement limited warranty* - one of the best in the industry!
Aug 17, 2011 | Cadillac STS Cars & Trucks
My battery does not hold the charge, i will charge it for 24/hour and it only last 5 minute, why is that, iI buy this product for wife when went to Iraq, and when i talked ton her on the phone three months...
NiCad batteries have this problem when they are recharged frequently after being only partially discharged. This is also the case when the batteries are left in the charger continuously - even if the charger is described as being "automatic". I have old 12v batteries that I have been using for 20 years, but I only charge them for a few hours, and only when they have run down enough to be useless. I prevent leaving them too long in the charger by using a timer that cuts the power to the charger after a couple of hours. A couple of years ago I bought new drills and chargers, and believed that the chargers would be automatic and so could be left plugged in. Those batteries only lasted a couple of years, while the old ones are still going strong. I now use the timer for any of these chargers, automatic or not - but I had to buy new batteries first. good luck, Al K
Jul 29, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
My camera will not charge. It was purchased just short of a year ago, so here is no reason for the battery to be broken. It will not charge at all when the memory card is inserted and when it is, the...
Hi, It almost sounds like the battery won't hold a charge anymore which means you need a new battery. Since the camera isn't quite a year old yet I'd suggest contacting Nikon and seeing if they'll do anything for you before you buy a new battery.
May 12, 2011 | Nikon Coolpix S4000 Digital Camera
Hi,problem is this If battery is in the laptop alone and at some stage charger is connected,charge light does not come on and battery continues to discharge. If laptop is then shutdown the battery...
dv4-1120us Notebook
if it runs with no battery , then its ok. see?
(does not prove internal charging chip is ok, see?)
but PC is ok on A/C line so use it. in A/C power.
learn too that letting any battery die flat , can kill it.!
best is to not walk away from any LT , running on battery only.
or risk damaging it. (the laptop tries hard to not do that but is not perfect science ,yet)
read up on cell reversal.. never flat line it on purpose and win !!!
next learn that batteries are short lived..
last a few years others months, that is what batteries do.
even car batteries can fail fast. (ask and old guy that)
all batteries are what I call "weak technology" "fails fast"
or imported from china, and are junk,. many are. so....
I always have 2 batteries, that way , having 2 good batteries
if one dies, its totally obvious, no? whats UP?
i have 2 batteries, too, so when on vacation, I dont go dry, see?
On some longer trips i carry 3, that is what laptops do best.
run with no AC jacks about.
May 13, 2017 | HP Pavilion dv4-1120us Notebook
Camera only takes 5 photos before dying
This new battery, if it is the exact type of battery recommended by the manufacturer then it is most likely not the battery. if you bought a similar battery it might be for even the minimum difference makes all the difference with digital cameras. for camera repair this company does a good job and you can even select your problem on their online quote.
Jul 08, 2010 | Canon PowerShot S500 IXUS 500 Digital...
My K800i battery dies very quick
Dear Friend,
                 U are saying that u have bought this mobile 2 yrs back so check wither ur battery has been expired and change it.Otherwise switch off ur mobile and put it in charge and check it out the normal standby for any mobile is 2 to 3 hrs.Kindly check it and revert back
May 06, 2009 | Sony Ericsson K800i Cellular Phone
My son's nintendo ds has been charging for a day now, but it
The battery is probably completely drained. Rechargeable batteries have a certain lifetime in which they can be charged to. The charge limit for a Nintendo DS is approx. 500 charges. When you pass this limit the battery will no longer work. Your best option is to buy a replacement battery at
After a year or more a rechargeable battery won't last as long as it did when it was new.
Apr 07, 2009 | Nintendo DS Console
Will not charge after battery ran out.
Well maybe your battery has just run out ,  because if youve had it for 5 months and supose your friends had it for 1 year then a battery tends to wear out , im sorry but thats all the advice i can offer , but i hope i helped.
Oct 12, 2007 | Motorola Mobility SLVR L7 Cellular Phone
HP Pavilion ze4145 Notebook Logo
139 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
