Question about PNY Verto GeForce FX 5200, (256 MB) PCI Graphic Card
Card not allowing more then 640x480 and 4bit colors.
I recently got a 'hand-me-down' Dell 2400. I replaced the RAM and have put in a new DVD drive, and picked out this video card so that it would be usable for me and my school work - any maybe a couple of old [old] school games.
Anyway, I install the card/drivers [have done both off the CD and newest from website with a system restore] and although the card works fine during boot and while playing in the BIOS, the issue comes when XP loads. It switches back to the on-board, and when I try to set the Geforce as the "Primary" card I can only get very low, unusable settings.
After what I have researched my thoughts are that the stock power supply isn't enough: 200w. Looking at newegg [http://www.newegg.com/Product/Product.aspx?Item=N82E16814133233&nm_mc=TEMC-RMA-Approvel&cm_mmc=TEMC-RMA-Approvel-_-Content-_-text-_-] specs I am guessing that the 200w power supply isn't enough for the card[?].
So my question is am I right in assueming the power supply is the issue here?
I don't mind investing in a replacement, as the recommened one still keeps me within my budjet on this computer [not spending more then $200 bucks]. I just would like to ask someone who would know better then me if this is the issue.
Spec:
Card trying to use: NY VCGFX522PEB Geforce FX 5200 256mb 128-bit DDR PCI
In Dell 2400:
P4 2.4gig
1gig ram
XP pro
200w power supply
Not sure what other specs needed.
thanks!
  • 1 more comment
  • ryb Jan 14, 2009
    Good call.
    The only options I have for the VGA in BIOS are "on-board" or "auto", the latter I am assuming picks whatever is on the PCI first [and this is it's default and current setting].
    I did a start up with everything unplugged put the HD and the new Video card and it is still not fully working.
    Could it really just be a dead card then? I think I am still within the time in which I could get a replacement - should I give that a try before I invest money into a new power supply?
    Thank you for the quick response.
  • ryb Jan 14, 2009
    I wish that I did have a friends computer, or any other to test it on.
    Thanks again, I think I am going to check into getting another of the same card. Even taking it into somewhere and having a techy install it [the new one], I would hate it if I were the one that touched the card the wrong way.
    Looking around it seems that the power supply is somewhat of a joke on these systems and I imaigne I would have to get another when I do get that second HD [Already it's supporting 1HD, CD, DVD/CD-RW and everything use it takes to keep a computer going], thus making the power supply something that I might just have to **** up and get.
  • ryb Jan 15, 2009
    Found my fix -
    So after everything I have done the past couple of days to get this to work, it all leads back to just not trying all the steps. The solution to my problem: Go into the Hardware/Device Manager and disable the On-Board card that way [along with having it PCI as default in the BIOS]. I was assuming that because the card was installed the Windows would use the PCI Video card as it's default, and that was not the case. It was still forcing the On-Board to take over.
    I feel silly...
    btw - I also upgraded my Power Supply anyway, I am going to need it for the size of HD I am going to want to upgrade to. If this was also part of the issue I cannot say, I am not going to put in the old one to check. But the card does require a power supply of atleast 250w, and from what I read around it was a good idea to upgrade to the 330w one anyway.
  • 14 Answers
If you have the option to disable on-board VGA on BIOS do it for test.
To check if you have enough power please try to boot with your CD/DVD dirves and extra HDD off.
Posted on Jan 14, 2009
  • ex-lunatico Jan 14, 2009
    I think that is better to double check your card, with everything
    unplugged but HDD, it should work. Anyway 200w PSU tight to your
    system... Can you get a PSU form a fiend for tests?
Will a NVIDIA GeForce gt 610 graphics processor work on a Dell Dimension 2400 PC Desktop
YES, Zian it will work....BUT,....................
1) It is a PCI graphics card, and uses a PCI expansion slot.
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2898922&CatId=319
The Dell Dimension 2400 Desktop PC's motherboard, has three long white PCI slots,
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/techov.htm#1105465
http://www.ebay.com/itm/Dell-Dimension-2400-Desktop-Motherboard-System-Main-Board-F5949-K5148-G1548-/190750417467?pt=Motherboards&hash=item2c699c623b
http://en.wikipedia.org/wiki/Conventional_PCI
If one of those long white PCI slots is open, you can use a PCI graphics card.
Concerned that the graphics card uses DDR3 graphics memory, and your computer only uses DDR Sdram ram memory?
Don't be.
The graphics card has it's own processor (Graphics Processing Unit), and graphics memory.
It runs independent of the system resources; the Processor and Ram Memory.
http://en.wikipedia.org/wiki/GPU
The concern is the Power Supply.
Original power supply's maximum rated Wattage is either 200 Watts, or 250 Watts.
The above graphics card requires a minimum system requirement/power supply requirement; of 300 Watts.
I would recommend replacing the Power Supply.
(Especially with it's age, if it is still the same one)
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1389575&CatId=1078
ONE thing though..............
Watch the 20-pin ATX main power cable connector, and the wires in it. Be sure they are in the standard place setup.
Check the pinout, and color code of the wires,
1) Dell Dimension 2400 desktop computer, 20-pin ATX main power cable connector pinout,
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/techov.htm#1105612
2) STANDARD 20-pin ATX main cable connector pinout, and color code of wires; as set by JEDEC,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
[Be aware that the ATX main power cable, and connector, you get with a new power supply; such as the above, will have a 20 =4-pin ATX main power cable connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
Use the 20-pin connector, tie the 4-pin power cable up out of the way]
For a time period Dell was making the motherboard's main power cable connector - Proprietary.
Meaning they has that motherboard connector wire pinout changed.
Colors of wires were in a different place, than the standard setup by JEDEC.
Orange wires are 3.3 Volts (DC)
Red wires are 5 Volts (DC)
Yellow wires are 12 Volts (DC)
Black wires are Ground wires.
Guess what happens if a 12 Volt Yellow wire, is plugged into where a Black Ground wire is supposed to be?
ZZZZZZzzzzt! Motherboard fries, processor fries, ram memory fries, and graphics card. (If used)
Check the color code of the wires, in the 20-pin ATX main power cable's CONNECTOR, for the Dimension 2400's power supply.
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 14, 2012 | Dell Dimension 2400 PC Desktop
Upgrades and advice!!!!!
2GB is the maximum amount of ram you can install in your Dimension 2400. Depending on how much ram you have in it now,.. you could get a substantial speed difference by upgrading. You can upgrade the video card if you want. If you want to upgrade to 2 GB and upgrade to a decent vid card,.. you are looking at about $180 for parts. you will need to determine if that is something you want to put into the 2400 or buy a new computer with substantial speed and performance difference for about $500 from Dell. If you have any further questions, please post a comment here and I will answer them for you.
Feb 08, 2010 | Dell Dimension 2400 PC Desktop
Trying to put new ram in Dimension 2400, but don't know how to remove cover.
Go to page 49 of the following manual and it will show you how to take off the cover to access the inside of the tower.
If I have helped you, please take the time to rate my help as it allows me to help others.
Regards
http://support.dell.com/support/edocs/systems/dim2400/en/F75560LRs.pdf
Aug 06, 2009 | Dell Dimension 2400 PC Desktop
Cant
in jeneral memory card meance card reader ( mobile/d igitalcamer/phone cards where we put photo song.....etc) it is as pen drive device we put data directly in pen drive but in card reader . we put data in memory card through cardreader. both are use in computer usb port. computer dected card reader as apen drive.
are you not saying about ram ? it is also called memory. it is use in mother bord slot. they are white and plastic.
Jul 12, 2009 | Dell Dimension 2400 PC Desktop
Unable to reboot system after upgrades
1. Check your RAM speed
2. Install the old RAm and see if the problem persists
Jun 24, 2009 | Dell Dimension 2400 PC Desktop
Does the dell dimension 2400 burn dvds?
Hi budliteman36
Dell Dimension 2400 series will not bur DVD, see the link blow for specifications.
http://reviews.cnet.com/desktops/dell-dimension-2400-pentium/4507-3118_7-30824846.html?tag=mncol;rnav
You can replace the CD-RW drive with a DVD writer. Here is a list od DVD-R-RW writers.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=89&name=DVD-Burners&
Cheers!
Mike
Mar 31, 2009 | Dell Dimension 2400 PC Desktop
Dell Inspiron 4100 won't play dvd, but will play cd's
You have problem with your cd-drive's lens.
May 20, 2017 | Dell DVD-rom DVD Drive
Dell 2400 ram upgrade problem
RAM can be finicky so first test all memory slots with a known good stick (your 512MB). Make sure you're starting from a complete power down and you get a POST beep (hopefully your system is set up to beep when it powers on) and everything loads up all the way through to your OS.
Once you do that with all your memory slots test with the new stick by itself in all memory slots. If neither of the memory slots work with the new stick but you verify that it works in another system you should then check your BIOS settings and RAM timings to ensure compatibility with your stick. If you can't find the timing on the RAM stick itself, look up the manufacturer's part number for the information.
Feb 03, 2009 | Dell Dimension 2400 PC Desktop
Installed New RAM, Now Have Display Problems (color)
It appears something has happened with the video card or connector especially if it displays fine with the onboard video and original memory. Disconnect power and reinsert the video card into it's slot.
Jan 13, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Capable of upgrading more?
well i would say you really dont need to upgrade everything is cool with your computer really so it would just be a waste of money
Dec 19, 2008 | Dell Dimension 2400 PC Desktop
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 Cloud storage services are great for sharing files with friends and families, keeping documents in sync between all your devices, and so much more. Free cloud storage is even better! Several backup services offer free online backup plans. DataAlign is known for having the finest free cloud data backup software in the world! Not just being simple and automatic it can be customized to a large extent and not to forget the scheduling capabilities that allows it to run at any time of the day. With several years of experience in its kitty, DataAlign is the trusted innovators in free online backup solution. DataAlign is proud to be known as a market leader in providing Server Cloud Backup Solution based storage and individuals is our primary motto. Our innovative platform has been designed while keeping you in mind. To provide Cloud Backup For Small Business optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Unlike other companies, there are no catch with DataAlign free cloud backup solution. With the kind of experience, you get with DataAlign, we strongly believe that you will eventually upgrade your account to a bigger one. And that makes us give awa Online Backup Pricing accounts as a free version with no strings attached. So drop your worries and and setup your free cloud data backup account with DataAlign. Just to clarify we will not ask for your credit card details upfront when you sign up for a free account. Keep using your free account as long as you need it. DataAlign has been designed with you in mind. You wouldn't require any technical skiil or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 28, 2018 | The Computers & Internet
See all PNY Verto GeForce FX 5200, (256 MB) PCI Graphic Questions
PNY Verto  GeForce  FX 5200, (256 MB) PCI Graphic Card Logo
111 people viewed this question
Top PNY Computers & Internet Experts
David
David
pankaj rautela
pankaj rautela
Alun Cox
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
